Official LNXXA650 Calibration/Settings Thread - Page 131 - AVS Forum | Home Theater Discussions And Reviews
post #3901 of 3908 Old 06-09-2013, 04:08 PM
Tk111's Avatar
Originally Posted by Evil4blue View Post
OK, this is what I'm running for regular TV. The Blacks are awesome and it doesn't burn my retinas with its brightness. The Colors look natual to my eye, but I'm fight some slight posterization in gradients. Anyone have a suggestion to fix that.
Mode: Standard
Backlight: 6
Contrast: 90
Brightness: 44
Sharpness: 16
Color: 50
Tint: G52/r48
Detailed Settings
Black adjust: off
Dynamic Contrast: low
Gamma: -1
Color Space: Native
Flesh Tone: 0
Edge enhancement: off
Picture Options
Color tone: Normal
Digital NR: off
HDMI Black level: Normal
Film Mode: Auto
Amp 120hz: Low/Medium
Plug & Play
Energy Saving : Low
What are your game settings?
Tk111 is offline
post #3902 of 3908 Old 12-29-2013, 03:26 PM
Tk111's Avatar
A
Originally Posted by Podol View Post
It seems less aggressive in AMP than before upgrading, and corrects few bugs including erasing 'favorite channels'.
Regarding contrast ratio, 71F's dynamic CR's are better in my measurement.
But A650 is better in panel's static CR with turning off any dynamic backlight control.
71F(Korean Model# F81BD)'s Max CR measured 27525:1(even better than Samsung's own 25000:1 spec) and then blacks read 0.012 nits that time.
That's close to Pioneer Kuro's blacks(0.013 cd/m² initially, 0.006 cd/m² after few seconds)
On the other hands, A650's max dynamic CR is limited to around 10K to 1, still better static CR than 71F.
Most new TV's from any major brand, IMO, have enough blacks and CR's unless you're watching it in a darkened room
A650 has around 2000 to 1 non-dynamic, static CR.(2291 : 1 for my measurement)
And that's pretty good enough and better than 71F, I think.
I assume Samsung changed their dynamic backlight control algorithm less aggressively this time and that's why 71F has more CR.
But A650's panels static CR's higher than 71F.
I'm not satisfied with A650's black uniformity, though.
Usually Samsung and Sony's PVA panels are better in black levels and uniformities comparing to LG's IPS panels.
A650 is still slightly better than LG's, but not as good as previous Samsung models.Quote:
Originally Posted by capa2000 View Post
Why are some setting not available to change? Is it because I am using HDMI? Can't select some settings like Warm2 and some settings are grayed out all together. Why is this?
C
If you want to choose Warm1&2, picture mode should be 'Movie', not 'Standard' or 'Vivid'.
anyone have the latest calibrated settings or thread number for this tv
Tk111 is offline
post #3903 of 3908 Old 03-06-2014, 11:52 AM
Desisuperman's Avatar
Quoted: 33 Post(s)
i don't want to start a new thread but I doo have a question regarding this TV
I just got rid of my Digital Cable and I'm now on Analog Cable.
I'm trying to output my audio to my HT Receiver in 'TV' mode (analog cable plugged straight into back of tv) Is this even possible? I've tried both the Optical Cable and RCA outputs to my receiver but I'm getting no sound whatsoever. Ive assigned the audio outputs on my Denon and I have TV Speakers set to off on the LN52A60 but I still get nothing. I thought once you set TV Speakers to off it automatically switches audio over to the outputs on the tv ?
Is anybody running a similar setup?
Desisuperman is offline
post #3904 of 3908 Old 03-06-2014, 01:31 PM
crakarjax's Avatar
Quoted: 56 Post(s)
I send audio out via optical to my receiver. Are you sure the issue isn't source selection in the receiver? I don't recall is there is a setting on the TV to enable optical output, but it should be pretty easy to find if there is.
crakarjax is offline
post #3905 of 3908 Old 03-06-2014, 02:24 PM
Quoted: 33 Post(s)
Thanks for verifying crakarjax that it is possible. I played with the receiver a bit more and finally figured it out!
post #3906 of 3908 Old 11-02-2016, 07:23 AM
Evil_Akuma's Avatar
Hey everyone, reviving this thread due to still being a proud owner of this TV. I am sure there are alot more who still use it. Wondering if anyone had settings for XBOX ONE ???
Evil_Akuma is offline
post #3907 of 3908 Old 11-02-2016, 07:48 AM
oryan_dunn's Avatar
Quoted: 122 Post(s)
Liked: 91
I'll take a look when I get home, but I have mine connected to HDMI 2 set to PC, and I think I'm using just a default movie mode.
Sent from my HTC 10 using Tapatalk
Give a man a fish; you have fed him for today. Teach a man to fish; and you have fed him for a lifetime
oryan_dunn is offline
post #3908 of 3908 Old 11-03-2016, 06:51 AM
Evil_Akuma's Avatar
Nice! Yes I am also on movie settings but not on HDMI 2. I changed to HDMI 1 yesterday. Do you have the XBOX ONE menu settings limited or rgb ? does this t.v support full rgb? or leave it at limited? Im trying to get the best settings for Titanfall 2 ( highly recommend this game btw, campaign on hard is nice ) All in all , some nice settings would be great!
Reply LCD Flat Panel Displays
Playstation 3 160gb System , Xbox 360 250gb Console With Kinect
