Official Samsung LNxxA530 Owner's Thread - Page 37 - AVS Forum | Home Theater Discussions And Reviews
post #1081 of 1095 Old 11-16-2009, 07:12 PM
Scott Greczkowski's Avatar
Quoted: 58 Post(s)
Liked: 101
My LN40A530 died last night.
Turned on the TV and the channels just kept changing by themselves. Like someone was holding down the channel down button on the front of the TV.
When trying to press any button on the remote the tv just beeps at me.
The TV has no buttons on the front only touch spots. I cleaned those off with rubbing alcohol and its still doing it.
I called Samsung and the lady on the phone told me changes are the mainboard would have to be repaired. She also told me that since I purchased my TV in October the work is not going to be covered by warantee and that I was proaby better off buying a new TV.
I did a Factory Reset with her while she was on the phone (press and hold EXIT on the remote for about 15 seconds) but that did not help.
The rest of the TV works fine. Has this happened to anyone else before? Any suggestions before I go TV shopping?
If I unplug the TV for a few minutes and plug it back in I get about 15 minutes of watching out of it before it spazzes out and starts flipping through the over the air channels.
Scott
SatelliteGuys.US / MultiChannel News
Scott Greczkowski is offline
post #1082 of 1095 Old 11-16-2009, 07:19 PM
Hakemon's Avatar
Never. Had my TV for more than a year now, and it's been working just fine, except for a couple times where it turned on, and you can hear the TV program, but not see it (HDMI).
Hakemon is offline
post #1083 of 1095 Old 12-28-2009, 03:09 PM
RScottS's Avatar
I had that problem, turned out another remote was having its buttons pressed by a book causing interference.
RScottS is offline
post #1084 of 1095 Old 12-28-2009, 10:45 PM
slosvt's Avatar
Quoted: 59 Post(s)
Liked: 29
Just posting this info for anyone who is looking for some settings. Measurements taken in HCFR with an i1 pro. Set is a ln46a530 with 1010 FW, C Panel.
Movie
Warm2
Backlight 3
Contrast 93
Brightness 44
Sharpness 5
Color 50
Tint G50/R50
Detailed Settings (All off)
Gamma -1
Color Space
R-26/0/3
G-26/41/0
B-3/7/74
Y-47/55/0
C-26/41/50
M-22/6/45
WB
R-Offset 29
G-Offset 26
B-Offset 29
R-Gain 30
G-Gain 25
B-Gain 25
Movie_After.zip 69.71484375k . file
slosvt is offline
post #1085 of 1095 Old 02-06-2010, 06:31 PM
NuSoardGraphite's Avatar
Quoted: 326 Post(s)
Liked: 298
Update:
That problem I was having with Speed Racer rented from On demand has been solved: It was without a doubt the On Demand feature that was at fault. I have recently purchased a PS3 and played Speed Racer on the console and it played flawlessly. No motion blur. No ghosting. And none of the ugly artifacts that I saw when I rented it via On Demand. Never again will I waste money buying On Demand movies. Netflix kicks buttock.
Stand tall and shake the heavens...
NuSoardGraphite is offline
post #1086 of 1095 Old 02-06-2010, 06:41 PM
sumstuf's Avatar
Why did you leave the detail settings off? Does it make a better difference without them running? I turned mine off too because I didn't want the tv doing extra work. It was like applying makeup to the picture. I'm just curious as to why you turned yours off.
sumstuf is offline
post #1087 of 1095 Old 02-14-2010, 10:31 AM
Quoted: 326 Post(s)
Liked: 298
Most likely because thats what A/V experts tell people to do. I personally have Dynamic Contrast on Low and Black Adjust on Low. Gives the picture a little extra zing without being too garish.
I also don't use Warm1 or Warm2. Just looks weird to me. I use Standard instead.
post #1088 of 1095 Old 02-17-2010, 04:14 AM
sapphire's Avatar
I got this problem.. when I set to 1920x 1080 in Windows 7 or any other O/S, you know there's 1920 vertical line run across the screen right?
The line in the most right is actually displaying the content of the line in the most left..
Why is that? I am using ATI 4850 video card. http://www.eworldsale.com/ews_product_8819_45603.html
I tried updating the driver, but no help
sapphire is offline
post #1089 of 1095 Old 02-18-2010, 04:42 AM
ebs89's Avatar
Hi, I am curious about the picture in picture capabilities of this tv. It appears that I can use any source (hdmi, component) but the other source has to be air or cable. The thing is my cable box connects to my tv via component. Is it possible for me to have the sources for both pictures be from component and hdmi as opposed to one of those paired with air/cable.
thanks
ebs
ebs89 is offline
post #1090 of 1095 Old 02-20-2010, 04:58 AM
sapphire's Avatar
@ebs, I can answer that, the answer is no. the PIP is basically useless since it can't even do HD air/cable.
sapphire is offline
post #1091 of 1095 Old 03-02-2010, 12:16 AM
john44a's Avatar
Does anybody have some settings for the sound they would like to share ? Thanks in advanced.
John
john44a is offline
post #1092 of 1095 Old 03-12-2010, 06:02 AM
romajc84's Avatar
I searched everywhere but can't find anything. Has anyone done an input lag test on this tv? Through HDMI 1, HDMI2/PC, Game Mode, VGA, etc?
romajc84 is offline
post #1093 of 1095 Old 12-06-2010, 02:52 PM
Hakemon's Avatar
Wow, just with the last couple months, mine has developed an odd "reverse burn in" effect.. Obviously not the same burn in that CRTs and Plasmas get, but this kind: http://www.techlore.com/article/1009...-TVs-Burn-In-/
Mine is of the C panel type that people chose to avoid, so I felt this info is important for people still looking at these TV's..
Hakemon is offline
post #1094 of 1095 Old 12-06-2010, 10:25 PM
Quoted: 326 Post(s)
Liked: 298
Yes, its Image Persistence, the LCD version of Image Retention that PDP's get.
My set does this too and has been doing it for 2 months or so now. I noticed it with 4:3 material played off streaming netflix. It goes away after a short period of time and its very, very faint, much more so than the IR I have seen on PDP. However, I now know its there and see it from time to time. I find it very annoying, so I just have to make sure I minimize the use of 4:3 on the set (and no, you can't stretch the 4:3 on streaming netflix, trust me I've tried)
post #1095 of 1095 Old 02-23-2016, 06:48 AM
King26's Avatar
Samsung tv HDMI picture problem
I just bought a Samsung tv off craigslist for a price that seemed too good to be true and now Im realizing that it really might have been. The picture when I plug in a HDMI device like my dish receiver or xbox is very grayed out, but when the tv is in regular tv mode or when the HDMI device is turned off, the colors are back to normal. I've tried adjusting just about all the picture options and nothing has worked.
Here are some pictures for examples. As you can see, when the xbox is turned off, the colors on the menu are full and bright, but when I turn the xbox on, the colors get dull and gray.
The tv is a Samsung ln46a530p1f
ID:	1272993   Click image for larger version
King26 is offline
Reply LCD Flat Panel Displays
