Problem With My Sony KDL-46XBR2 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-19-2008, 07:00 PM - Thread Starter
bicatmit's Avatar
So I have a KDL-46XBR2 connected to a Scientific Atlanta Explorer 8300HD cable box/dvr and whenever I change the channel, going from one resolution to a different a different one (i.e. going from Discovery HD's 1080i to ESPN HD's 720p), not only does it take a long time to make the switch, 80% of the time it results in the black and white static screen. I am able to hear the new channel's audio but the change in resolution usually ends up with that static screen. I fix it by turning the television on and off and then the new channel comes in fine. It's extremely annoying because I have to turn the TV on and off almost every time I want to change channels....and even when that static screen doesn't pop up, there's a delay of a solid 2 seconds in going from one channel to the other.
Any idea how to fix this? Thanks!
bicatmit is offline
post #2 of 9 Old 04-19-2008, 07:13 PM
schlick's Avatar
Use component out of the cable box.
schlick is offline
post #3 of 9 Old 04-19-2008, 09:21 PM
Terminader's Avatar
Quoted: 318 Post(s)
Liked: 556
Do you have any settings on your cable box related to Native format or fixing the output resolution choices? I had the same issues you describe until I modified by DIRECTV box so that it output Native 1080i format only. Now channel changes are almost as fast as my old CRT, despite the resolutions.
Terminader is online now
post #4 of 9 Old 04-20-2008, 10:15 AM - Thread Starter
bicatmit's Avatar
I'd like to continue using HDMI to connect the cable box to the TV.
As far as upconverting settings, I have it set to "Auto DVI/HDMI." The other options are "Upconvert-1," "Upconvert-2," and "Fixed." Should I be using a different setting?
bicatmit is offline
post #5 of 9 Old 04-20-2008, 01:04 PM - Thread Starter
bicatmit's Avatar
Anybody?
bicatmit is offline
post #6 of 9 Old 04-21-2008, 01:04 PM - Thread Starter
bicatmit's Avatar
Please?
bicatmit is offline
post #7 of 9 Old 04-23-2008, 04:23 PM - Thread Starter
bicatmit's Avatar
Bump!
bicatmit is offline
post #8 of 9 Old 04-23-2008, 04:41 PM
schlick's Avatar
see post 2...... And if you refuse to follow the suggestion, figure it out for yourself.
schlick is offline
post #9 of 9 Old 04-25-2008, 01:13 AM - Thread Starter
bicatmit's Avatar
There's gotta be a different way to fix the problem, right? Component is not an option for me.
bicatmit is offline
Reply LCD Flat Panel Displays
