Official Sharp LC-37XD1E Owners/Calibration Thread - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-20-2008, 04:49 PM - Thread Starter
Joe Bloggs's Avatar
Quoted: 433 Post(s)
Liked: 118
(the 37" LCD HDTV with 1920x1080p resolution).
Please use this thread to discuss the Sharp LC-37XD1E and the best settings for best picture quality and other stuff concerning this TV.
Joe Bloggs is offline
post #2 of 3 Old 04-20-2008, 04:52 PM - Thread Starter
Joe Bloggs's Avatar
Quoted: 433 Post(s)
Liked: 118
I usually have the following settings on the TV - what do you think - about right?
Backlight: 0 to 2
Contrast: 22 or 23
Brightness: 0 usually
Colour: 3
Tint: 0
Sharpness: 0
Colour Temp: Middle
Black: On (when and why should this be off?)
DNR: Off
TruD(R): On
post #3 of 3 Old 09-14-2011, 11:40 AM
acid|burn's Avatar
Hi!
Wanted to ask if someone had this kind of an problem.
I use at Ext6 a PC, which is connected using DVI->HDMI, cable. Everything's working fine, watching all the movies using FullHD resolution.
Some time ago I bought an SD SAT receiver with an HDMI output.
I connected it to the Ext5 using HDMI-HDMI cable.
I can view it in SD and using an HDMI. That's OK. BUT the problem shows up when I switch back to Ext6 where's the FullHD PC is connected. The picture doesn't show UP!!
I can only get the Ext6 FullHD work again when I disconnect the Sharp from power and connect it back. When I restart the TV. The Ext6 is working, then I select the Ext5 (SD/HDMI) it is working, but when I switch back to Ext6 it's again black. And so on.
What do You think?
acid|burn is offline
Reply LCD Flat Panel Displays
