Vizio VW37L - Questions. Opinions? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-26-2008, 03:28 PM - Thread Starter
blacklefthands's Avatar
I was thinking about getting the 42" but it is looking like I will need some extra money and so I am thinking of going with this set instead.
To people that own it... how far are you sitting away from it? Does it look crisp and clean at that distance? Does it have good blacks? How are the viewing angles? Any other comments?
And I have a question. I am trying to figure out the exact dimensions of the size of the screen itself. The Vizio webpage has dimensions, but I think it is for the entire TV, not only the screen. I am wanting to use a tape measure and compare the difference in size of the actual screen to my 27" CRT.
blacklefthands is offline
post #2 of 7 Old 04-26-2008, 04:18 PM - Thread Starter
Anyone?
post #3 of 7 Old 05-31-2008, 11:15 PM
joemamafresh's Avatar
I just put the 37' version in layaway tonight...they look really cool...have you got yours yet? if so, post back and let me know how you like yours...i'm kinda excited actually! i've got two months to get it out, but i don't think i can wait that long!
joemamafresh is offline
post #4 of 7 Old 05-31-2008, 11:22 PM
leavemealone347's Avatar
What is better series the VW or the VO?
leavemealone347 is offline
post #5 of 7 Old 06-01-2008, 04:05 AM
boswd's Avatar
The VO
boswd is offline
post #6 of 7 Old 08-14-2008, 05:15 PM
Why is the VO better than the VW?
post #7 of 7 Old 08-14-2008, 07:29 PM
boswd's Avatar
it's not light years better, the spec's are just about the same, The VO is better for analog audio outs but if you are hooking the VW up to a home theater system then it doesn't matter.
I like the look of the VO better and plus it comes with an HDMI, which is a nice touch. But the VW is just fine.
boswd is offline
Reply LCD Flat Panel Displays
