Official LNxxA750 Calibration/Settings Thread - Page 28 - AVS Forum | Home Theater Discussions And Reviews
Old 10-07-2008, 05:59 AM
c888168's Avatar
What is the best settings for playing with PS3? I'm currently using the game mode, is that already the optimal setting?
c888168 is offline
Old 10-07-2008, 01:36 PM
studdad's Avatar
Originally Posted by sharkcohen View Post
How do you know that you hate a professionally calibrated display?
I like the contrast on a professionally calibrated display, but do not like the color temp. I have not had my set calibrated professionally, but have done two things to determine this.
First, I looked at several displays at several BB's that showed how a calibrated display compared to a non calibrated. In every instance, the contrast was great, but the picture was way too warm for my taste. Now, I realize BB is not the best source for a Professional Calibration, and if I were to have it done, I would not get it done by them, but I have to assume they got it at least close to D65, etc.
My second source has been the settings given by people, such as Zerog, in this thread, who have used calibration tools to get very close to what a professional would do. While every TV is different, I cannot imagine that their settings would look dramatically different on their set than on mine. I never like the look of their settings though. Again, too much yellow/warmth.
And finally, it has been stated by other professional calibrators and reviewers that Movie Mode with Warm2 brings you the closest possible to D65 on this set. On my set, it look horrendous.
Now, I realize and respect that you do not want to give out your calibrated settings to the group, but if you would like to give them to me, and have me try them out to see if I may be all wet, then I would be happy to do so. Again, I realize they will look slightly different on your set as opposed to mine, but the difference should not be all that dramatic.
52" Samsung 750, finally satisfaction
studdad is offline
Old 10-07-2008, 01:37 PM
studdad's Avatar
Optimal for lag, not optimal for picture.
studdad is offline
Old 10-07-2008, 07:31 PM
c888168's Avatar
so what is the best settings for ps3 that is both optimal for lag and for picture? thanks in advance
c888168 is offline
Old 10-07-2008, 07:32 PM
jwortiz's Avatar
Anyone upgrade to the new firmware version 2002.0? I just upgraded from 1009.1 and the colors seem brighter and sharper when using Zerog6's reference settings. Not bad!
If someone with a calibrator can double check, it would be greatly appreciated.
jwortiz is offline
Old 10-07-2008, 09:08 PM
studdad's Avatar
lol, that is not easy to say. Game Mode reduces lag by turning off a lot of settings that drag on the processor. You might want to try putting your tv in Standard Mode, and turning off everything, such as DNR, Edge Enhacement, etc., and see how the lag is for you. The advantage of this is you still have control over several settings that you don't have in game mode, and put minimal to no lag on the processor. But, this all varies depending on the individual. I have played FPS games with no problems with my Standard Mode settings, the same ones I use to watch tv. Others seem to have too much perceivable lag even in game mode. But I would say the vast majority have no problems with regular settings.
studdad is offline
Old 10-07-2008, 09:17 PM
strobeshow's Avatar
hey, im pretty curious as well. i took off game mode, and noticed a big improvement. im not experiencing lag, so i plan on keeping it on standard. i was just wondering if i should tweak with the settings, and if there were some ones that were good that you know of?
also, should i change the sound settings? in game mode, im sure it switched around the settings... so i was just wondering.
strobeshow is offline
Old 10-07-2008, 09:45 PM
c888168's Avatar
Thanks a lot, ill try both settings as well. Has anyone tried the new 2002 firmware?
c888168 is offline
Old 10-07-2008, 10:47 PM
studdad's Avatar
Not sure on the sounds, as I use an AVR. But in regards to settings, you can try mine on the previous page of this thread. To eliminate any additional processing, I would turn Dynamic Contrast off, unless you want to try it with it on. I would also try it with AMP on Low and AMP on Off, and see which works better for you. If your blacks crush a bit, but you like Dynamic Contrast, then try turning black level off. If you don't like Dynamic Contrast and have it set to off, but still are getting some crush, then again, turn black level off.
studdad is offline
Old 10-08-2008, 06:26 AM
KakimotoRift's Avatar
Still trying to get as perfect as possible.....so far these are my results
2008/10/08 KakiColor®_ver.081008 Results (A650)
CIE Graph HD REC.709
Gamma Graph @ 2.22
RGB Levels
D65 Balance
Luminance Graph
KakiC●l○r® Calibration w/ Calman
Current Setup:
*LG 55" LH95/LHX
-Semi-Gloss Coating
-Direct Backlit SlimLED w/ Local Dimming
-3360 LEDs w/ 240 Zones
*LG 42" LM7600
-Gloss Coating
-Edge-lit LED w/ Local Dimming
KakimotoRift is offline
Old 10-08-2008, 09:04 AM
zerog6's Avatar
It looks really really good.
If you want to get rid of that small spike at 10% of the gamma graph, you just raise the brightness by 1, maybe 2 points.
If you want to get the red in the color space triangle to the reference point, in the color space setting of red, you increase the red, and decrease the blue. If that doesn't help, you would need to increase the general "color" setting.
zerog6 is offline
Old 10-08-2008, 09:09 AM
sharkcohen's Avatar
I wouldn't trust what you saw at Best Buy. Using other peoples' settings makes no sense. Warm2 does NOT necessarily put you closest to 6500k. Jeff Meier had to use Warm1 on mine (and he has used Warm2 on other 6/7 series sets). It varies. I don't think you have ever seen a set properly adjusted to 6500k, and sharing my settings with you likely will not get you there, either.
I'm not telling you what to do, I just think saying you don't like D65 when you likely have never seen it is a bit odd.
sharkcohen is offline
Old 10-08-2008, 09:20 AM
Carlp336's Avatar
so which is the best calibration disc ?
(im multi format)
Carlp336 is offline
Old 10-08-2008, 11:15 AM
lotc's Avatar
Gamma Graph @ 2.22
RGB Levels
D65 Balance
Luminance Graph
are your settings posted anywhere?
lotc is offline
Old 10-08-2008, 11:25 AM
sharkcohen's Avatar
(im multi format)
HD DVD DVE (not the 'Basics' version). It's a combo disk and includes the original DVD DVE on the other side for DVD players.
Old 10-08-2008, 12:22 PM
zerog6's Avatar
Exactly, my 750 was closer to D65 in Warm-1. Even though I could calibrate it to D65 using Warm-2 either way, it was closer to D65 by default to Warm-1
zerog6 is offline
Old 10-08-2008, 12:30 PM
Carlp336's Avatar
hd dvd dve (not the 'basics' version). It's a combo disk and includes the original dvd dve on the other side for dvd players.
on the way !!
Carlp336 is offline
Old 10-08-2008, 12:33 PM
sharkcohen's Avatar
Also, studdad, color temp is only half the calibration story.
Old 10-08-2008, 07:03 PM
curly2004's Avatar
I just updated my firmware to 2002. Can someone please give the link to the Calibration settings for the 46" 750. I havent calibrated my tv yet. Thanks
curly2004 is offline
Old 10-08-2008, 07:04 PM
strobeshow's Avatar
i tried yours out. do you use it for games? because it made my games look a little bland. i put it back to what i had (pretty much standard, but around 57 brightness, and minor tweaks), and the games just seem to be more 'alive'.
Old 10-08-2008, 07:32 PM
jwortiz's Avatar
Nah! Don't do it. I was able to play with the TV some more tonight after upgrading to 2002 late last night and not happy. The colors ARE more vibrant, but when changing the country information, it still showed Canadian weather. Also, I couldn't access the additional content and got a black screen. Definately not ready for primetime. Someone goofed over there at Samsung.
Oh well.... I reverted back to 1009.1
jwortiz is offline
Old 10-08-2008, 08:07 PM
studdad's Avatar
Yes, I understand that, and I know Best Buy calibrations are not the best. And to tell you the truth, Movie Mode, even with a Normal color temp is too yellow for me. But hey, I may still consider giving it a try. Why do you say the NON Basics HD DVE is the best? Does that even come in a BD version?
studdad is offline
Old 10-08-2008, 08:09 PM
studdad's Avatar
Yeah, I use it for games and find it good, but everyone likes something different.
studdad is offline
Old 10-08-2008, 08:10 PM
sharkcohen's Avatar
No, it doesn't come in a BD version. It has alot more useful patterns, particularly reverse color ramp patterns that you can use to watch for color clipping so that you can be sure you don't have contrast set too high. The BD Basics disc does not include these patterns, and I find that baffling.
Old 10-09-2008, 07:31 AM
curly2004's Avatar
Old 10-09-2008, 07:54 AM
lostonetoo's Avatar
Well set up my LN46A750 lastnight with zerog6 setting, and I hope I got the right ones with all the changes he made, LOL. All in all it looks great. Want to say thanks to all you guys and gals that have posted info on setting up this TV.
Thanks....
lostonetoo is offline
Old 10-09-2008, 07:55 AM
Carlp336's Avatar
my HDDVD DVE comes in today. the wife will be out tonight.
im going to attempt to calibrate the 2002. FW on my 750. ill be using the X-rite OptixXR pro.. anyone be on aim to help out ? 6pm eastern
Carlp336 is offline
Old 10-09-2008, 12:57 PM
Zero HD's Avatar
I wouldn't be of much help but good luck, I upgraded to 2002 and am liking it except for the (temporary?) loss of the built in art gallery. Looking forward to your calibration results. What original firmware and panel revision did you have?
Zero HD is offline
Old 10-09-2008, 01:08 PM
Carlp336's Avatar
Originally Posted by zero hd View Post
i wouldn't be of much help but good luck, i upgraded to 2002 and am liking it except for the (temporary?) loss of the built in art gallery. Looking forward to your calibration results. What original firmware and panel revision did you have?
1009
Carlp336 is offline
Old 10-09-2008, 04:01 PM
Nelson35's Avatar
I too upgraded to the latest firmware last night (2002 i believe) and had the same problem as another member on this site - the Content screen goes blank! So i reverted back to 1009.1 - perfect. Hey Samsung - do you believe in testing before releasing firmware that could hose someone's shiny new TV? F##king idiots.
Nelson35 is offline
