Pick my next TV for me, buying in next 16 hours - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 06-06-2008, 10:09 PM - Thread Starter
Argetni's Avatar
I have a panny 42" plasma in the den that I love. 60 series I believe. Bought it 1.5years ago.
I need an 32" LCD for the bedroom, I had a Toshiba 32av500u but I returned it do to viewing angle issues.
Here are the choices, Sharp is $72 cheaper which is inconsequential in the grand scheme.
Panasonic TC-32LX85
Sharp LC-32SB24U
Buying tomorrow afternoon please advise.
Argetni is offline
post #2 of 17 Old 06-06-2008, 10:43 PM
hon143's Avatar
Where have you been, dude? There are multiple threads on the Sony 32XBR6, Samsung A550/650, and the Panasonic 32LZ800. Just read up on those threads and decide on your own!
hon143 is offline
post #3 of 17 Old 06-06-2008, 11:35 PM
Grentz's Avatar
Sammy A550, amazing set, just picked one up and its awesome
Looked better than most of the other sets in 2 stores I went to as well.
Grentz is offline
post #4 of 17 Old 06-06-2008, 11:36 PM
diabolyte's Avatar
panasonic or sony. both are probably best in their class.
diabolyte is offline
post #5 of 17 Old 06-07-2008, 12:54 AM
lcjrodriguez's Avatar
Panny isn't best in its class, Pio Elite is. Sony isn't best in its class either. The ln a650 is heh. A650 has been drawing comparisons to the 8g Elite, and it isn't even Sammys flagship lcd, not to mention has been recieving much praise from certified ISf calibrators, and major reviews.
lcjrodriguez is offline
post #6 of 17 Old 06-07-2008, 01:02 AM
hon143's Avatar
I wasn't aware that Pioneer Elite were LCD HDTV's. From Consumer Reports and other professional reviews, Panny and Sony's are usually tops in the LCD category. I don't recall Pioneer being in the LCD department.
hon143 is offline
post #7 of 17 Old 06-07-2008, 01:06 AM
diabolyte's Avatar
sorry, i was only referring to the 32" class which the OP wanted, so the sony or panny are probably the best in this class.
post #8 of 17 Old 06-07-2008, 01:06 AM
ResOGlas's Avatar
If you're choosing between that Sharp and the Panny, get the Panasonic. I've already experienced the horrors of Sharp's banding, and I'd never buy of of their LCDs again.
ResOGlas is offline
post #9 of 17 Old 06-07-2008, 01:06 AM
chadmak09's Avatar
What a hilarious statement. From who??
The 650 is nowhere near the PQ, motion handling, HD or SD processing, or viewing angle clarity of an Elite Kuro..
I can compare a gremlin to a ferarri but that doesn't mean they are in the same class.
Just becasue a set can produce a black level that is close to a kuro when the screen is totally black does not mean that its in the same class. What matters is how the shadow detail, color detail, and overall contrast looks when actually watching something.
I will admit the 650 is nice when a still image is displayed but when thing start to move it is hindered by ghosting and motion blurr just like most LCD's. After watching a Kuro for a while, I can't handle the motion blur of any LCD anymore.
chadmak09 is offline
post #10 of 17 Old 06-07-2008, 03:36 AM
potnhd's Avatar
buy a 81 series samsung best tv out right now for sure
potnhd is offline
post #11 of 17 Old 06-07-2008, 06:58 AM
Hynad's Avatar
Sharp's so-called banding issues are found mostly on their bigger sets. On a 32" it is a non issue.
Hynad is offline
post #12 of 17 Old 06-08-2008, 09:18 AM - Thread Starter
Argetni's Avatar
I bought the panasonic, got it for $250 less than WorstBuy sells it for too
Argetni is offline
post #13 of 17 Old 06-08-2008, 09:28 AM
TomGreen321's Avatar
It quite prevalent on the smaller sets as well.
TomGreen321 is offline
post #14 of 17 Old 06-08-2008, 11:34 AM
Hynad's Avatar
CNET reviews and my LC-32GP3U-R beg to differ.
Hynad is offline
post #15 of 17 Old 06-13-2008, 03:24 PM
Oihan's Avatar
It seems the LC-32GP3Us don't suffer from banding...but the 32D62U, 32D64U, and 32GP1U do.
Oihan is offline
post #16 of 17 Old 06-13-2008, 03:51 PM
TheBeginning's Avatar
Actually being that your misinformed, it has been rated very close to the Kuro in about all terms. So again read around before trying to disprove something.
TheBeginning is offline
post #17 of 17 Old 06-13-2008, 04:36 PM
bytor54's Avatar
At the price point I think you're shooting for ($700 - $800???)
I think one should definitely consider the Samsung LN32A450. It's the best picture of any 720p 32" set that I saw when I was shopping. Would have bought it at $750 or less if I'd hadn't wanted something bigger.
Sorry, don't have any opinion on the two sets you mentioned.
Good Luck!
PS. I f I'm remembering correctly, the sound also seemed pretty ok from this model what what I could tell in the store.
bytor54 is offline
Reply LCD Flat Panel Displays
