Sony XBR6 32 inch wont work witjh DVI to HDMI adapter from PC?! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 06-09-2008, 11:12 PM - Thread Starter
recoil1's Avatar
Hi I'm a long time reader this my first post, I need help getting a Sony 32XBR6 to work as PC monitor using DVI to HDMI converter. I know for a fact that this DVI to HDMI converter works because I had a 32 inch 550 Samsung that worked with it without a hitch. I returned the Samsung and got the Sony and I do like it better and can use the Sony as my PC monitor using VGA but I cant get it to recognize the signal using the same DVI to HDMI converter that worked with the Samsung so if any of you guys have this same Sony and have been able to use your PC with DVI to HDMI converter or if you have any suggestions I should try please respond, thanks for any input.
recoil1 is offline
Reply LCD Flat Panel Displays
