Sharp Aquos Digital Audio Output not working for HDMI Input - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-20-2008, 06:34 PM - Thread Starter
BrandonR's Avatar
I have a new Sharp Aquos LCD TV (Model LC-32GP1U) and to keep things short, here's my setup:
Input 3 - HD Cable box connected via composite cables
Input 4 - Xbox 360 connected via HDMI
I have a digital audio cable connected to the TV's digital optical audio output going to a cheap home theater receiver's digital audio input. The cable box works fine with my surround sound system, but the Xbox isn't producing any sound through it (only through the TV's speakers). Since the cable box works, I know it's not a home theater setup/digital audio cable problems. So what's the problem here?
BrandonR is offline
post #2 of 4 Old 07-16-2008, 02:46 PM
Soundtweaker's Avatar
My optical out on my sharp LC-42D64U cuts out on certain channels.
TV speakers work fine. It must be something to do with the audio board on the TV.
On the phone with Sharp tech support now.
Soundtweaker is offline
post #3 of 4 Old 07-16-2008, 03:35 PM
flatfour's Avatar
On many larger Sharp TV's, you cannot use the TV to split the HDMI audio out over the optical. That optical out is solely for the ATSC tuner. I'm sure it has to do with copyright protection.
The TV should output audio over the 2-channel RCA jacks when you're giving it HDMI audio.
flatfour is offline
post #4 of 4 Old 09-09-2008, 01:26 PM
jobo420's Avatar
How exactly do you setup the tv to send the audio out through the 2-channel audio output? I have tried every type of input type I can (hdmi, component, composite) and can't find any setting that allows audio output. I'm not sure if it's just not working or if I'm missing something obvious. (I have the 42d64u sharp)
jobo420 is offline
Reply LCD Flat Panel Displays
