HELP ! - trouble taking Philips TV stand off - AVS Forum
post #1 of 4 Old 06-22-2008, 01:56 PM - Thread Starter
shrisinghvi's Avatar
I cannot get the stand off the new Philips - 42TA648BX bought at Costco.
I removed the 4 screws at the back and still the stand wouldn't come off. I have to get rid of the stand it comes with to wall mount it.
Any body else have this problem. i am so frustrated with it. Philips support wasn't much help either.
Any advise / tricks appreciated - I guess my only other option would be to return it back to Costco.
shrisinghvi is offline
post #2 of 4 Old 06-22-2008, 02:03 PM
ingramba's Avatar
hmm., maybe lay a towel over stand and gently tap off with a hammer? Might just be a tight fit, Good luck.
ingramba is offline
post #3 of 4 Old 06-22-2008, 02:24 PM - Thread Starter
Just afraid if i try too hard, it may break....
Did it come off easily for you guys after removing the four screws if you own philips?
post #4 of 4 Old 06-24-2008, 12:45 PM
spiritd's Avatar
i think you need to pull out the yellow thing too..
spiritd is offline
Reply LCD Flat Panel Displays
User Tag List
