Official Sony KDL-XXZ4100 Calibration Thread - Page 7 - AVS Forum | Home Theater Discussions And Reviews
Old 02-15-2009, 09:58 PM
Horo's Avatar
You serious the Z doesn't support full rang RGB.... I just ordered my 46z4100 it should be here in a couple of days. I play a lot of ps3 and watch blu-rays do you guys use the same setting for just watching tv and watching blu-rays or playing game?
Horo is offline
Old 02-16-2009, 05:30 PM
TheBrandon's Avatar
Quoted: 36 Post(s)
Unless something is jacked up on the test I ran. I am sure you will love your Z regardless. I went through 2 Samsung LN52a650 before I settled on the Z.
The TV Standard is 15-235 so this is obviously perfect for Blu Rays. I am not sure if the RGB input supports the full range though.
I use same settings for Blu Rays and games.
TheBrandon is offline
Old 02-17-2009, 01:56 PM
SICK OF IT ALL's Avatar
Has anyone else had problems with the graniness?
SICK OF IT ALL is offline
Old 02-17-2009, 02:37 PM
TheBrandon's Avatar
Quoted: 36 Post(s)
What is the source? Blu Ray exc? There are some Blu Rays that are just poor transfers and will result in unintentional film grain. Not a TV issue at all although I am not saying this is the case with yours.
Old 02-17-2009, 04:55 PM
PS3 Blu ray, and regular HD programming.
I noticed that it's only in certain scenes. And I'm not sure if the HD programming is affected by the fact that I have service through Time Warner, and I've noticed that on my W4100 (located at a different house) I don't have this problem and I have Direct TV. However I dont see how this would affect the blu ray.
Old 02-17-2009, 06:02 PM
Horo's Avatar
i just got my 46" Z4100 and just set it up. I'm still going through the settings can so can you guys help me out real quick got 2 questions. Where does it say the manufacture date at? and How do i find out what firmware i have?
Im going to watch a blu-ray then i wanna update if its needed and calibrate it and watch another blu-ray to see the difference =). So happy about my new tv
edit: seem like mines is DEC 08. I tried updating FW but tv wasn't recognizing my flash drive so i called sony and they gonna send me it. Awesome CS glad i went Sony
Horo is offline
Old 02-17-2009, 06:13 PM
nismo604's Avatar
has anyone used the calibration set up on certain Disney BD's such as Ratatouille? For brightness I have no problems, but for contrast I'm suppose to adjust the display till the white pattern disappears into the white background, but I can seem to adjust contrast to the point it disappears.
nismo604 is offline
Old 02-18-2009, 02:32 AM
jibstir13's Avatar
how did you find your build date and firmware version?
my tv gets here friday and i would like to check.
thanks!
jibstir13 is offline
Old 02-18-2009, 07:51 AM
dmullen's Avatar
My build date is on a sticker on the back of the TV, left side.
dmullen is offline
Old 02-18-2009, 10:09 AM
V42
V42's Avatar
Just wait until you try to ask any real technical questions or try to get information regarding any of the know problems. All you'll get is a response read verbatum from a script of standard debugging proceedures that are not specific to your questions .
Just hope you'll never need that kind of help . Generally you won't learn anything more from them than you could have found out by simply reading the owner's manual yourself.
V42 is offline
Old 02-19-2009, 12:39 AM
jibstir13's Avatar
thanks...i'll find out what my build date is when the tv gets here...
does anyone know what the average build to purchase time is?
Old 02-19-2009, 06:02 PM
TheBrandon's Avatar
Quoted: 36 Post(s)
Out of curiosity, what would you do with this information?
Old 02-20-2009, 03:27 PM
jibstir13's Avatar
i want to compare my time to the average.
Old 02-21-2009, 01:35 PM
Q of BanditZ's Avatar
Originally Posted by ibre34 View Post
My settings with 203R update,
Color Space Wide
My setting
Picture menu:
Picture Mode: Custom
Backlight: 6
Picture: 86
Brightness: 51
Color: 55
Hue: 0
Color Temperature: Neutral
Sharpness: 10
Noise Reduction: Off
MPEG Noise Reduction: Off
Advanced Settings menu:
Black Corrector: Off
Advanced C.E.: Off
Gamma: Off
Clear White: Off
Color Space: Wide
Live Color: Off
White Balance menu:
R-Gain: 0
G-Gain: -6
B-Gain: -11
R-Bias: 0
G-Bias: 3
B-Bias: -4
Motion Enhancer: Standard
CineMotion: Auto 2
Game Mode: Off
Video/Photo Optimizer: Video
General Setup menu
Power Saver: Off
Light Sensor: Off
Have you done 203R settings for Color Space Standard yet?
Great ISF Job by Chad B.
Q of BanditZ is offline
Old 02-22-2009, 11:03 AM
ibre34's Avatar
Quoted: 12 Post(s)
Last time I checked setting where the same for both Wide and Standard color space.
I am going to check again tonight
ibre34 is offline
Old 02-22-2009, 01:06 PM
Dralt's Avatar
ibre34, how do you do your calibration?
Dralt is offline
Old 02-22-2009, 02:30 PM
ibre34's Avatar
Quoted: 12 Post(s)
I used a colorimeter and ColorHCFR free software
ibre34 is offline
Old 02-22-2009, 04:28 PM
TheBrandon's Avatar
Quoted: 36 Post(s)
http://www.tireal.com/index.php?page=etft Have you seen this? Very good to me.
Old 02-22-2009, 05:01 PM
ibre34's Avatar
Quoted: 12 Post(s)
Can you post your results?
ibre34 is offline
Old 02-26-2009, 04:08 PM
STAR1034's Avatar
a 46z4100. Do we need the firmware upgrades?
If yes, do we need to download all of them?
Must they download in order?
Just turned it on a hour ago, the only issue I see is the color washout as you move away from center. Sony sent this unit as a replacement for our 50XBR1, did we make the right choice?
Tony
STAR1034 is offline
Old 02-27-2009, 09:37 PM
mhonkomp's Avatar
My question may have been answered before but I have missed it, but where do I find the version number of the software on my TV?
I have tried to run the software update form the menu on TV and it says "The Current Software version is NA, No update is available""
From the Product Support screen it shows HM-F-QN-B-CO
Am I missing something? I see from the Sony support link above that there is a file available dated 2/4/2009. SInce I just bought my TV on 2/25 so I expect it isn't on my TV. I was hoping there was a way to find the version from the menus since I already have the TV hung on the wall.
mhonkomp is offline
Old 03-01-2009, 01:57 PM
V42
V42's Avatar
... I was hoping there was a way to find the version from the menus since I already have the TV hung on the wall.
http://www.avsforum.com/avs-vb/showp...postcount=2274
HM-F-QN-B-CO >> (202r - factory installed)
as posted by others.
V42 is offline
Old 03-05-2009, 06:36 PM
Horo's Avatar
Has anyone called Sony for a copy of new firmware? i called them last month feb. 18 and they said they would send me a usb flash drive with the firmware but i haven't gotten anything yet.
Horo is offline
Old 03-08-2009, 04:43 PM
ibre34's Avatar
Quoted: 12 Post(s)
Why? you can download the firmware from Sony web site.. it´s the same firmware.
ibre34 is offline
Old 03-08-2009, 10:26 PM
Horo's Avatar
it doesn't read any flash drives i tried and i really don't want to go around stores looking for one that would work. I have a 128mb memorex one that didn't work and i tried a few of my friends too. Unless im doing something wrong...
edit: Got one to work im updated now
Horo is offline
Old 03-13-2009, 04:30 PM
mhonkomp's Avatar
Is there any way to downgrade back to my original firmware? I put on the latest, 203r a week ago and used the custom settings posted for that version by ibre34. And since I put that firmware on I have noticed more blurring. I have changed motion enhance to high and this helps some, but I still notice more now than I did with the default 202r (which is what sony told me I had when I called before putting 203r). I had ibre34's settings posted for 202r back when I had that version on.
Over all the color and everything else is working fine. I am just noticing more motion blur now. It is possible I am just being over sensitive. Has anyone else noticed this change since going to 203r?
mhonkomp is offline
Old 03-14-2009, 01:20 PM
halon's Avatar
Quoted: 48 Post(s)
Liked: 52
need help.
just got my 46Z today. after hooking up my ps3 i discovered that i have no sound. it is connected right to the tv via hdmi.
halon is offline
Old 03-14-2009, 02:07 PM
halon's Avatar
Quoted: 48 Post(s)
Liked: 52
nevrmind.
figured it out
halon is offline
Old 03-14-2009, 05:27 PM - Thread Starter
Cal1981's Avatar
Quoted: 236 Post(s)
Liked: 233
You cannot revert back to the factory firmware without a technician replacing the set's tuner board. Most of us have seen no negative impact from 203r but that doesn't mean that you aren't. You can try to go back to 202r. A number of us have gone back and forth several times. Your software level will not change but the firmware level will.
Cal1981 is offline
Old 03-16-2009, 11:32 AM
4302933's Avatar
I updated mine.
I had the TV one day then upgraded the firmware. I didnt notice any differences, but I didnt use it very long before upgrading. So I'm not a good judge.
Formatted the 2gig drive to Fat32, dropped the sony_dtv_package203r.p08 file on to the drive to copy it over. Plugged it into the TV updated. The update took awhile (20 min) and in that time the TV turned on and off multiple times, lights did some flashing things on the display below. Just hang on and wait till the TV says its updated. It takes awhile.
Flash drive I used (pic)
Updating....... (pic)
Yeah! New firmware version (pic)
I love the TV. I paid $1399 at BestBuy 03/2009 Model KDL-52V4100 Its a bargain for what you get. So far I have no complaints.
4302933 is offline
