Electrical Interfernce - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-10-2008, 05:24 PM - Thread Starter
baikalhunter25's Avatar
I have mounted my TV on the wall of my bedroom. The room is pretty small and I mounted the TV in the only possible place I could. The Problem: The TV is on the same spot the an exterior light is on. When the outside light is on, I get a nasty buzzing through the TV. Anyway to insulate against this? Any ideas would be helpful.
baikalhunter25 is offline
post #2 of 6 Old 07-10-2008, 08:30 PM
txrose's Avatar
Is the outside light fluorecent or incandescent?
If it isn't 720p or 1080i/p it isn't HD. If it is 720p or 1080i/p it may not be HD content.
txrose is offline
post #3 of 6 Old 07-11-2008, 06:27 AM - Thread Starter
flourecent
post #4 of 6 Old 07-11-2008, 07:44 AM
mes444's Avatar
You could try a line regulator to plug your tv and it's connected items into. Check out the APC LE1200, it's a surge protector and voltage regulator in one and not very expensive and it works very well:
http://www.newegg.com/Product/Produc...82E16812106005
mes444 is offline
post #5 of 6 Old 07-11-2008, 11:19 AM
mchalebk's Avatar
Can you replace the fluorescent bulb with incandescent? Fluorescent bulbs are, from an EMI standpoint, very noisy.
Brian
mchalebk is offline
post #6 of 6 Old 07-11-2008, 01:27 PM
nm88's Avatar
Is it compact fluorescent? Try a different bulb. Also try putting the two devices on separate circuits.
nm88 is offline
Reply LCD Flat Panel Displays
