Biggest LCD under 36-inches wide? Any suggestions? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-30-2008, 03:50 PM - Thread Starter
Jonnydanger007's Avatar
My brother is trying to get a TV however it has to be under 36-inches wide. ( Possible 35 inches)
Do you know of any TV larger than a 32-inch LCD that will fit in the space?
Thanks for your help.
Jonnydanger007 is offline
post #2 of 4 Old 07-30-2008, 04:20 PM
mbyrnes's Avatar
Quoted: 93 Post(s)
Liked: 186
I found one Here
If you look hard enough I am sure you could find something that would fit. A 37" is the largest you will be able to get.
Why must it be so small?
Xbox Live: TheRealMaxPower --- PSN: TheRealMaxPower (no PS4 currently) Panasonic TC-P65VT60    Vienna Acoustic Mozart Grands    Pioneer SC-72   Sony BDP-S790 Xbox One S Astro Mixamp 2013   Soundblaster X7 (Sparkos Op Amps) Schiit Modi Multibit/Magni   LTA MicroZOTL2 AKG K702 65th Anniversary   Fostex TH-X00 Ebony DT990 Pro 250 ohm  Massdrop/Sennheiser HD6XX and PC37X Audio Technica ATH-M50x Antlion ModMic
mbyrnes is offline
post #3 of 4 Old 07-30-2008, 05:33 PM - Thread Starter
Originally Posted by mbyrnes View Post
I found one Here
There is a Cabinet designed for an old type of TV with doors that close.
Its an expensive piece of furniture that came with the room.
Thanks for the reply. I really appreciate it!
post #4 of 4 Old 07-30-2008, 05:50 PM
hhaller's Avatar
Quoted: 72 Post(s)
Liked: 51
You could maybe...maybe...fit a Toshiba 40RF350 or 40XF550 in there...I think they are a shade wider than 36".
Toshiba also makes the 37RV530, which is about 36.1".
Edit: After re-reading your first post, if you only have 35" to work with, maybe a nice 32" is a better option.
hhaller is offline
Reply LCD Flat Panel Displays
