Where to Buy a Wall Mount? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-12-2008, 02:48 PM - Thread Starter
observeme's Avatar
I need a Wall Mount for a 46" LCD (Sony Bravia). I am having trouble finding a cheap mount that tilts and sits 3" or less from the wall. The monoprice mounts are cheap but sit 4" off the wall. Thank you.
observeme is offline
post #2 of 2 Old 08-12-2008, 02:56 PM
creemail's Avatar
Check out the Promunts UT-PRO310.
Solid mount...
Chris
creemail is offline
Reply LCD Flat Panel Displays
