Composite output into component input on TV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 08-20-2008, 09:09 AM - Thread Starter
bigtoque's Avatar
My TV (Samsung LN32A550) only has one composite input which I use for easily connecting my old video game systems (it's on the side and easy to access).
I just got digital cable and the box only has a composite and RF coax outputs.
The composite video looks noticeably better than the RF, but my problem is that I don't want to use up my only composite input for the TV.
Are there any way to send the composite output to the component input on my TV?
I suppose to could also use a composite switch...
bigtoque is offline
post #2 of 9 Old 08-20-2008, 09:14 AM
mes444's Avatar
You should get an HD box instead of just a plain digital box. It probably won't cost any more or just a small amount extra. Then you will have many more HD channels and you can connect your tv with component or HDMI for a much improved picture.
mes444 is offline
post #3 of 9 Old 08-20-2008, 09:17 AM - Thread Starter
bigtoque's Avatar
I wish that was the case.
The HD box is $350. My digital box was free.
The HD-PVR (that I wanted) was $600
bigtoque is offline
post #4 of 9 Old 08-20-2008, 09:26 AM
mes444's Avatar
Have you checked around for a different provider. Most cable company's HD boxes are just a few dollars more per month. Other than that, for your two composites, many places sell switches, but you are going to miss so much great HD stuff that way.
mes444 is offline
post #5 of 9 Old 08-20-2008, 09:35 AM - Thread Starter
bigtoque's Avatar
I looked at all my options. There's only one cable company (that I'm with), one phone company (that offers TV, but no HD (that I'm aware of)), and Bell for satellite (HD-PVR for $300, however a contract is required and I'm not willing to sign a contract).
I tried convincing the CSR at the cable company to give me the HD box and she said there was nothing she could do. I'm sure I would have got one if I had been with one of their competitors, however I just moved out and signing up for service for the first time.
bigtoque is offline
post #6 of 9 Old 08-20-2008, 10:00 AM
mes444's Avatar
Who is the phone co.? Many do offer HD. If they don't then.....
I think you need to go over the head of the first line customer service people and try to get ahold of some type of "retention" person. Retention people are there to keep you from leaving. So call your company and get with some upper level CS people and see about getting an HD box.
mes444 is offline
post #7 of 9 Old 08-20-2008, 10:22 AM
clicq's Avatar
You should get an HD box, but in the meantime... you might not be aware, but on the A550, but one of the component ports in the back doubles as a composite input -- it's the lower one of the two, and you just plug the yellow video cable into the "Y" port. See page 10 (12 of the PDF) of the manual where it talks about connecting a VCR.
clicq is offline
post #8 of 9 Old 08-20-2008, 10:37 AM
lzpoof's Avatar
Just plug the composite wire into the green component jack on the TV. The TV will recognize the input as 'AV#' instead of 'Component#' and it will use the green jack as if it was a normal composite jack.
This worked on my A630 for an Xbox last night and actually worked on my old Panasonic and Toshiba tube SDTV's.
lzpoof is offline
post #9 of 9 Old 08-20-2008, 11:24 AM - Thread Starter
bigtoque's Avatar
clicq & lzpoof,
I had no idea. Thanks so much!
bigtoque is offline
Reply LCD Flat Panel Displays
