Samsung LN52A650 - calibration...please! - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 40 Old 10-02-2008, 01:13 PM
Bonecrusher52's Avatar
Originally Posted by slumpey326 View Post
120hz can never be turned off. The tv is always running 120hz. AMP is just a special setting.
AMP is like 120hz on steriods, lol. I think AMP only should be used on any CG animation movie. You will be amazed by how the picture look on a animation movie with AMP on.
ÂOh, youÂre talking to me all wrong! ItÂs the wrong tone. You do it again, IÂll stab you in the face with a soldering iron.  Christopher Walken
Bonecrusher52 is offline
post #32 of 40 Old 10-02-2008, 01:35 PM
Chevy-SS's Avatar
What's the best way to get rid of the "soap opera" effect that is seen on some shows and DVD's?
Chevy-SS is offline
post #33 of 40 Old 10-02-2008, 01:55 PM
Originally Posted by Chevy-SS View Post
What's the best way to get rid of the "soap opera" effect that is seen on some shows and DVD's? -
Turn AMP off is the best way to get rid of soap opera effect.
post #34 of 40 Old 10-02-2008, 02:53 PM
slumpey326's Avatar
brief, and straight to the point.
slumpey326 is offline
post #35 of 40 Old 10-02-2008, 05:50 PM
Chevy-SS's Avatar
Thanks, I tried that last week. It helped a little, no doubt. Still got some of that live feed look though.
Chevy-SS is offline
post #36 of 40 Old 10-02-2008, 06:44 PM
If it continue to be a problem then I suggest you to reset your TV to default factory setting. To do this -
Factory Reset
1. Turn off the TV
2. Press 'Mute' '1' '8' '2' 'Power'
3. The TV will start and you will be in the SM (give it a few extra seconds).
4. Select Optionbyte
5. Select Factory Reset twice
After factory reset make sure you go to the picture setting and turn your AMP off. It should turn all judder by auto motion processor to off.
post #37 of 40 Old 10-03-2008, 05:37 AM
slumpey326's Avatar
Factory Reset
1. Turn off the TV
has anyone ever tried this factory reset in service menu and if so does it mess up what settings should look like.
post #38 of 40 Old 10-03-2008, 09:59 PM
No, it will not mess up your TV. It will reset all of your setting to factory default. You will only need to adjust your picture setting again because your old setting will be erased to default. After you reset your TV then why not try my picture setting and see if you like it much better.
post #39 of 40 Old 10-12-2008, 07:31 PM
slumpey326's Avatar
factory reset, may try this
post #40 of 40 Old 10-16-2008, 05:51 PM
Denophile's Avatar
anyone know how to turn on the red light on the bottom?
Denophile is offline
Reply LCD Flat Panel Displays
