Acer P243WAid 24" Monitor - Opinions? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 09-07-2008, 10:16 AM - Thread Starter
WhiteZero's Avatar
Acer apparently has a new TN pannel monitor out, the P243WAid model. I can't seem to find any reliable reviews on it, I'm guessing because it's so new. However, it has about 230 reviews on NewEgg, 79% of which are 5star rating, making it the most well reviewed 24" monitor on the site.
These Acer panels use "Adaptive Contrast Management" or ACM, which is basically their Dynamic Contrast. No idea if it's any better or worse than normal Dynamic Contrast.
I'm looking to upgrade my aging Samsung 215TW 21" and this Acer seems to be a good choice. Espcially since it has HDMI as well, which will be good for my XBox360.
Heres the specs:
Screen Size - 24"
Widescreen - Yes
Maximum Resolution - 1920 x 1200
Recommended Resolution - 1920 x 1200
Viewing Angle - 160°(H) / 160°(V)
Pixel Pitch - 0.27mm
Display Colors - 16.7M (6-bit + HiFRC)
Brightness - 400 cd/m2
Contrast Ratio - 3000:1 ACM
Response Time - 2ms(GTG)
Display Type - WUXGA
Input Video Compatibility - Analog RGB, Digital
D-Sub - 1
DVI - 1
HDMI - 1
Receiver: Yamaha RX-V671
Fronts: Sony SSF-5000
Rears: Sony SS-B1000
Center: Polk Audio CS10
Subwoofer: BIC America F12 12-Inch
WhiteZero is offline
Reply LCD Flat Panel Displays
