Official Sony XBR6 Series Owner's Thread - Page 122 - AVS Forum | Home Theater Discussions And Reviews
post #3631 of 3640 Old 10-29-2013, 11:08 AM
Babel-17's Avatar
You're very welcome! And thanks for posting that those settings work. Not only does hearing that make me feel good but it might help someone else down the road, looking for a similar fix.
Babel-17 is offline
post #3632 of 3640 Old 06-24-2014, 12:01 PM
habudab's Avatar
HDMI's don't work on my XBR 6 after a lightning strike. 300$ to repair.. not sure if it is worth it or should I just get a newer TV.. Any recomondations on a 40" tv that is as good or better than XBR-6 ?? might be worth getting something a little newer. just not sure if it is worth putting 300$ into a 6 year old tv?
thanks
habudab is offline
post #3633 of 3640 Old 08-23-2014, 08:04 PM
Lyons07's Avatar
Quoted: 108 Post(s)
Liked: 26
I need help, I'm trying to find out the screw size that I need to attach the TV stand that came with the TV? I can't seem to find the size.
Thanks Jerry
Lyons07 is offline
post #3634 of 3640 Old 08-23-2014, 09:03 PM
xekester's Avatar
Thread depth is 9/16th inch; machine screw. Sorry don't know the screw size #. Hope that helps.
Xekester
xekester is offline
post #3635 of 3640 Old 08-23-2014, 09:36 PM
Lyons07's Avatar
Quoted: 108 Post(s)
Liked: 26
Xekester
Thanks it helps. Hopefully someone will know the size of the machine bolt. Any help on on this would be appreciated.
Thank you
Lyons07 is offline
post #3636 of 3640 Old 08-26-2014, 02:05 PM
Lyons07's Avatar
Quoted: 108 Post(s)
Liked: 26
Thank you
I found them online!!
Lyons07 is offline
post #3637 of 3640 Old 03-24-2015, 02:59 PM
michaelwalsh's Avatar
So a couple of days back I saw the Geek Squad guy at the Best Buy next door start putting detritus from his installs into the dumpster, including a LCD TV (which he obligingly left by the side of it). Once he'd vacated the area, I went to take a look only to find a rather nice looking Sony XBR6 in the 40" size. I knew there was a good chance of something being wrong with it (I mean, who would throw out a perfectly good TV?), but I decided to drag it back over to my office and take a look. Turning it on, I found what I thought at first glance might be a bad T-con board, but after doing some research over the weekend I now think it might be at least one bad tab bond (though applying pressure to the top of the surround does nothing to change the presented image).
I find myself left at a bit of a crossroads with it. I could tear it apart and try the temporary tab bond fix you can find pretty readily via Google. But I don't know how long a fix like that might last, so I'd be disinclined to sell it on to someone, and I don't really need another TV of any description for our place. Or I could strip it and sell the parts on eBay - a good T-con board for these could bring $100 all by itself! Then maybe $40 for the stand; $25-30 for the power supply board; $60-70 for the video board, etc... I could end up getting some pretty good money out of it. What do you guys think?
ID:	622489   Click image for larger version
michaelwalsh is offline
post #3638 of 3640 Old 03-26-2015, 08:53 PM
jmystikcfl's Avatar
Does anyone know if there's a discrete IR command to toggle the speakers on/off? I know the functionality exists through the menus, but I'd like to program it as a button on my Harmony remote. If anyone has done it, could you please post up how you did? Or, if you know of another model that has the toggle command that works with the XBR6 and can post the model number I can always use my other Harmony to teach it to the living room remote. Thanks!
jmystikcfl is offline
post #3639 of 3640 Old 04-07-2015, 12:44 PM
Decided to part it out - panel was bad. Not upper tabs, which Sony had apparently tried to address by already having rubber bumpers attached to the metal frame from the factory, but one of the "floating" tabs at the side of the screen. Anyone need any parts before I throw them up on eBay?
post #3640 of 3640 Old 05-28-2015, 10:17 AM
Liked: 0
Screw for KDL-52XBR6 TV Stand
Thank you
Hi,
Can you please let me know what is the screw size or where you found it online? I am trying from two days but I cannot find it anywhere and it is not mentioned in the manual as well.
I would really appreciate your help.
Sweety
sweetythoda is offline
Reply LCD Flat Panel Displays
Sony Bravia 37 Inch Lcd Hdtv Kdl 37xbr6 , Sony Bravia Xbr Kdl 40xbr6 40 Inch 1080p 120hz Lcd Hdtv , Sony Bravia Xbr Kdl 46xbr6 46 Inch 1080p 120hz Lcd Hdtv , Sony Bravia Xbr Kdl 52xbr6 52 Inch 1080p 120 Hz Lcd Hdtv
