Official Sony XBR8 Series Owner's Thread - Page 186 - AVS Forum | Home Theater Discussions And Reviews
post #5551 of 5580 Old 11-01-2014, 10:41 AM
jehill's Avatar
Quoted: 45 Post(s)
Liked: 6
Originally Posted by J_Palmer_Cass View Post
How do you like your new TV?
My KDL-55NX720 has started to act up again. Picture starts out good, then slowly degrades with skipped frames. After a while, it goes down to about 1 frame every two seconds, and then locks up on one frame or maybe black.
I ordered the main board BATL that has the X-reality engine on it. The service manual suggests that may be the problem board. No LED trouble codes.
The picture is gorgeous on the new set. However, I do see slight vertical banding on a white screen. It's brought to your attention when the camera pans a white object. See my posts starting on Official Sony KDL-XXW850B thread for more details.
I am keeping my fingers crossed for you that the new BATL board solves your problem.
jehill is offline
post #5552 of 5580 Old 11-02-2014, 09:46 AM
J_Palmer_Cass's Avatar
Quoted: 393 Post(s)
Liked: 118
The BATL board that I purchased was the only one that I could find. It was the last new unit available at Tristate, and everyone else listed the BATL board as out of stock. I panicked and bought the board while I could still get one.
I also have to order a TCON board while they are still available. There are two versions for my TV, so I have to wait until I take the TV apart to find out the exact number (suffix F or H).
There is a third board called the LED driver board. That board also has a few numbers and is hard to find.
If I get the TV working I may just collect the three boards and keep them as spares. The cost for all three boards will be under $200.
I suspect that the TCOM board may be bad. The LED brightness is flashing and is too bright. Sort of a white haze over everything. Kind of hard to tell what board is bad when everything is interconnected to the extent that they are these days. Connections go from BATL to TCON to LD board to LCD Panel.
These TV sets are kind of hard to take apart. You have to place them face down on a table because the stand is attached to the rear cover. The Opticontrast LCD panel has a surface coating on Gorilla glass, so I have to use extreme care in handling this TV.
J_Palmer_Cass is offline
post #5553 of 5580 Old 11-02-2014, 01:59 PM
jehill's Avatar
Quoted: 45 Post(s)
Liked: 6
It's unfortunate that you have lay the set down. It was easy to work on my XBR8. BTW, you can return uneeded boards to Tristate for a 20% restocking fee. I am still waiting for my 80% refund for three boards that I didn't need!
jehill is offline
post #5554 of 5580 Old 11-05-2014, 06:43 AM
dannyss's Avatar
Well I finally got an offer for the XBR8 replacement from Sony Canada.
They are offering a $1225 credit towards the purchase of a new set.
I'm leaning towards the 70" X850B.
I figure now's the time to move up to bigger and 4K.
Anybody have any opinion?
Danny
dannyss is offline
post #5555 of 5580 Old 11-06-2014, 12:53 PM
jehill's Avatar
Quoted: 45 Post(s)
Liked: 6
Danny
That's a pretty high credit. I only got a credit of $75. I appears that I got ripped off. The XBR-70X850B looks pretty good to me.
jehill is offline
post #5556 of 5580 Old 11-07-2014, 11:23 AM
dannyss's Avatar
Update,
I went to see the X850 70" and the x900 55" (no 65" in store) at the local Sony Store.
We did look at a 65" and the size difference with a 70" is noticeable.
Can't beat the size of a 70". So we're going with the 70X850B.
The store is giving me a $200 credit on a PS4!
And after calling Sony Support, the upped their offer from $1225 to $1450.
So as of now, I get a $1225 credit and a free PS4!
I still have to get something more out of the store. The store manager and the saleman used to work with the salesman I always used to deal with all these years at the old Sony Store.
So the choice is made but the deal is not done yet.
Danny
dannyss is offline
post #5557 of 5580 Old 11-07-2014, 01:30 PM
bytown rick's Avatar
Update,
Danny
Danny,
Was yours on extended warranty? Or is this a good-will credit?
Rick
bytown rick is offline
post #5558 of 5580 Old 11-08-2014, 05:48 AM
dannyss's Avatar
Originally Posted by bytown rick View Post
Danny,
Rick
It was under a loyalty program. I never take extended warranties.
Danny
dannyss is offline
post #5559 of 5580 Old 12-17-2014, 05:15 PM
PaulG333's Avatar
So it looks like my kdl-55xbr8 has bit the dust. The standby light blinks 13 times, and I got it looked at and they said the service menu is showing errors for the panel. They reset the error codes and it works right now, but they said it can happen again at any time. They said they will show me how to clear the codes when it happens again, but I don't really want a problematic TV for my main viewing TV, so I'm pretty sure it's headed for the dump. I plan to scavenge the boards out of it first though.
I had the extended warranty on the set, and it failed 3 weeks out of warranty, and Sony offered me a store credit of $750 which was nice of them even though the warranty had ended, but I'm not sure I want to drop another $4,000 on a Sony product.
Does anyone have an xbr8 with a good panel that they want to sell? lol
PaulG333 is offline
post #5560 of 5580 Old 01-05-2015, 01:35 PM
greenpjs's Avatar
Originally Posted by Rustito View Post
OK - When I turn the TV on after being off all night I hear no relay click and no click shortly after turning TV off. I have been reading that this means it is not going into the proper stand-by or off mode and using additional power. Can someone please tell me how to fix this? I am using FIOS box and HDMI from box to TV. Not using TV guide set-up.
Thanks for any help,
Rustito
That post is almost five years old, but the same thing just happened to my 46" xbr8. I finally had to do a "factory reset" just as Rustito did to fix his five years ago. Everything is now back to normal. I am posting this just in case it helps someone else.
greenpjs is offline
post #5561 of 5580 Old 01-11-2015, 11:31 PM
TheBucketOfTruth's Avatar
Originally Posted by JRThiele View Post
Just making a few posts to get my count up so I can answer a PM. Thanks for the understanding.
There is a test forum where you can post junk.
http://www.avsforum.com/forum/46-post-testing-area/
TheBucketOfTruth is online now
post #5562 of 5580 Old 01-12-2015, 12:48 AM
smikec's Avatar
If you scavenge the boards, I would be interested in the FBU board.
S
smikec is offline
post #5563 of 5580 Old 01-19-2015, 08:35 AM
PaulG333's Avatar
S
I can't send you a pm because of my post count, but if you post up your email address, I'll send you an email.
Paul
PaulG333 is offline
post #5564 of 5580 Old 01-21-2015, 01:00 AM
smikec's Avatar
Paul
Thanks Paul,
pale pony at shaw dot ca (no spaces)
S
smikec is offline
post #5565 of 5580 Old 01-28-2015, 09:51 AM
Parrish's Avatar
Quoted: 23 Post(s)
I have one that is like new- low hours stored in closet for a rainy day that I would let go for $2,750.00
Coton de Tulear-IndyFab-Kuro-XBR8-Sharp Elite-LG OLED - Current Loves of my life.
Parrish is offline
post #5566 of 5580 Old 01-28-2015, 10:09 AM
PaulG333's Avatar
Thanks, but I bought a crappy Sony to tide me over now until I can afford a nice set again. I bought a demo unit from a Sony store that was closing, a KDL60W630B for $900. With the Sony credit for $750 and with warranty and taxes, it cost me about $530. Not bad for a 60".
PaulG333 is offline
post #5567 of 5580 Old 05-22-2015, 06:07 AM
Ryko1000's Avatar
A little bump as i need to decide quickly
I have a chance to get 46" XBR8 VERY cheaply and I have to decide today, so I don't have time to read the whole thread (will do that later).
I need a quick recap of pros and cons of this nice tv if some of you guys have time.
I see that there was still a problem with uniformity at that time, was it only slight or really bad and deal breaker level? I won't be able to choose from a few, there's only one. I hope it's good...
I'll use it mostly for PS4 and HD movies.
I heared the input lag is ok...any opinions on that? That's very important to me, but I'm fine with up to ~30ms.
And overall, how does it compare with todays tvs?
Thanx a lot
Ryko1000 is offline
post #5568 of 5580 Old 05-22-2015, 09:04 AM
jehill's Avatar
Quoted: 45 Post(s)
Liked: 6
I had a KDL-55XBR8 for six years until the panel failed. No uniformity issues with this set. Performance was flawless until the end of six years when suddenly every 6th line was missing. A couple of weeks later every 3rd line was missing. This was unacceptable, since the vertical resolution was reduced from 1080 to 720 lines. It looked like SD.
I never heard of vertical or radial banding until after I purchased a KDL-60W850B replacement for $1300.
If the display is good on the KDL-46XBR8 that you are considering, I wouldn't hesitate purchasing it.
jehill is offline
post #5569 of 5580 Old 05-22-2015, 10:11 AM
rgb32's Avatar
Quoted: 39 Post(s)
Liked: 31
Input lag on the 55" XBR8 in game mode using a Leo Bodnar tester is 36.7ms for the middle bar, -/+ 3.5 ms for the top and bottom readings. The 46" model should be similar.
rgb32 is offline
post #5570 of 5580 Old 05-22-2015, 10:57 AM
Ryko1000's Avatar
Thanx a lot
Ryko1000 is offline
post #5571 of 5580 Old 05-31-2015, 08:24 AM
Liked: 0
Hi Everyone. I am a longtime audiophile and Sony fanatic.
In full candor, I am re-posting this message from the general forum to better my information gathering.
I don't buy the argument that you have always spend for new in box televisions especially when old technology from SONY still destroys, in my subjective picture balance opinion, things costing many times as much today. I am not referring to the 4K sets. I am referring to 1080P with HDMI. I loved the XBR 9 but had heard about the "legendary" KDL-55XBR8. Any help from engineers or owners with my questions greatly appreciated:
Does the TV have major failure problems on average after a set period or does it depend on use hours?
If there is a failure such as the video processor circuit board are they tough to install and overly expensive even on ebay?
I was told that their Tri-Luminos technology was ahead of it's time in 2008 that Sony had to drop it for the XPR 9 due to cost and then re-release that technology are with the new 4K sets, true?
Is it still HDMI state of the art for DVD and 1080P Blu-Ray outside of the mega projectors or in the sub $1000 range today?
Can it really do 1080P for Blu-Ray quality in the sense of what you find on the shelf from Bravia as of this date? Quality?
The very first Sony Plasma's (the $5 and $10K models) are the blacks still better or the picture overall better and which model is a fair comparison?
How would you say the picture quality is comparing the last CRT's made? (KD-34XBR960 or KD-34XBR970)
Thank you!
Ian M. Gordon
CT Audio Society
Ian M. Gordon is offline
post #5572 of 5580 Old 06-10-2015, 07:33 PM
Liked: 0
My XBR8 is still going strong, but I've been considering moving it to another room and replacing with a XBR-X850C. Wondering if anyone here has an opinion about the PQ of the X850C compared to the XBR8?
naTERcON is offline
post #5573 of 5580 Old 06-11-2015, 06:12 AM
8mile13's Avatar
Quoted: 1182 Post(s)
Liked: 601
It probably will be an improvement in pq eventhough the X850C is a Edge Lit. Eventhough the XBR8 is a FALD it has more blooming and off axis problems than later generation FALDs, these problems will be more noticable in a darkroom. When you do a lot darkroom viewing the X940C, which is a FALD just like the XBR8, might be a better option.
8mile13 is offline
post #5574 of 5580 Old 06-11-2015, 09:01 AM
jehill's Avatar
Quoted: 45 Post(s)
Liked: 6
Overall, I love my KDL-60W850B. However, it has one problem that really annoys me when I see it, vertical banding. It's illustrated in the photo below taken while viewing a white (no color) jpeg. Notice the two columns either side of the center of the screen that are darker than the rest of the screen. Also notice the two whiter columns closer to the center. This is vertical banding. Beyond vertical banding, the entire screen should be uniformly white. However, you can see that the screen is darker and has a slight redish tint toward the edges. The two vertical darker bands are what really bother me. They appear when the camera is panning a white or light colored background. I submitted this issue to Sony and they claim that my set is "within specifications". For this reason, I will never buy an edge lit LCD TV again.
jehill is offline
post #5575 of 5580 Old 07-10-2015, 12:03 PM
Liked: 0
Question Heat Sinks Removal
I followed jehill's effort to save his XBR8 and I am on the same track. He stated he had to drill some screws out to get the correct model number for a TCON replacement. I am trying to do the same but have not been able to figure out how to remove the shields over the boards. Only screws left are on the heat sink and they will not budge, my question is do they have to be removed to remove the shield? I guess the shield folds down But I haven't been able to get it to move. Any help here? I have attached a photo off the area on the back of the tv showing the boards. Any help would be appreciated.
lynnsharpe is offline
post #5576 of 5580 Old 07-13-2015, 10:36 AM
jehill's Avatar
Quoted: 45 Post(s)
Liked: 6
I am not positive that you have to remove the heat-sink attached to the TCON board cover to remove the cover; however, you definitely have to remove the heat-sink attached to the CB1 board cover to remove it's cover.
In looking at the photos of the TCON board, I don't see holes that the heat-sink screws would screw into. So, it would appear that you do not have to remove the heat-sink. Remember, you also have to remove the four ribbon cables at the top and the two connectors at the bottom.
jehill is offline
post #5577 of 5580 Old 11-03-2015, 07:06 PM
gLaDiAtOr73's Avatar
kdl55xbr8
lost my screws to the stand,anyone know what size? ill keep looking through the thread in the meantime
thanks in advance
gLaDiAtOr73 is offline
post #5578 of 5580 Old 11-05-2015, 07:06 PM
Originally Posted by gLaDiAtOr73 View Post
kdl55xbr8
thanks in advance
found my own answer.
M5X16 in case anyone has the same problem. 46 cents for a 2 pack at home depot
post #5579 of 5580 Old 01-06-2016, 11:52 AM
shervinf's Avatar
Fbu a1557719b
Does anyone know where to get this board? I've been looking for it, and everyone says they are out of stock, and they don't know when they will get it.
I've replaced this board once, and I still have the old board, does anyone know somone that can fix the board? That's also an option.
shervinf is offline
post #5580 of 5580 Old 06-17-2016, 08:58 AM
leefarber's Avatar
My Vertical Lines Problem
I have a Sony KDL 46XBR8. The picture is great after 7-8 years, however there is a very strange phenomenon:
The TV is connected to my Marantz Pre/Pro and all sources go through the Marantz. When a source is off, the Marantz logo is displayed, as normal. However I get dozens of vertical lines across the screen. They go away when the source is turned back on, but I can't help but be worried by this. I have tested every HDMI cable, so that is not the problem. And I have connected a different TV to the Marantz Pre/Pro and the problem goes away, so it is definitely an issue with the TV.
Any idea what it could be? Again, it's not the end of the world. since luckily it goes away when there is an actual picture on the screen, but it's still troubling.
Thanks in advance!
leefarber is offline
Reply LCD Flat Panel Displays
Plasma Hdtv , Sony , Sony Bravia Xbr Kdl 46xbr8 46 Inch Triluminos Led Lcd Hdtv
