Samsung LCD TV LE-32A558 picture size problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-23-2008, 03:43 PM - Thread Starter
ddalcu's Avatar
Hello
I have the following problem: I set my picture size to 4:3 and the picture style to movie; after exactly 30 minutes every time the picture size comes back to 16:9 and the picture style to dynamic... What can be wrong? How can I avoid this?
ddalcu is offline
post #2 of 4 Old 11-24-2008, 07:40 AM
Allnatural's Avatar
Sounds like your tv is set to store demo mode. There may be a menu option to change that. If not, you'll have to do a factory reset (hold 'exit' on the remote for ten seconds).
Allnatural is offline
post #3 of 4 Old 11-24-2008, 08:14 AM - Thread Starter
ddalcu's Avatar
Thank you for your replay. I'll try what you've said and come back with an answer.
ddalcu is offline
post #4 of 4 Old 11-24-2008, 10:01 AM
mes444's Avatar
I wouldn't do a factory reset. But the Demo mode is on and that's what is causing the problem. There should be instructions for getting your tv out of demo mode by pushing a few buttons on the tv, in the owner's manual or online at www.Samsung.com and click on support at the top of the page.
Factory reset may do things to the tv you don't want reset, the demo mode is easy to turn off so keep it simple.
mes444 is offline
Reply LCD Flat Panel Displays
