Cinemotion - Auto1 vs Auto2 vs Off - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-23-2008, 09:08 PM - Thread Starter
JakiChan's Avatar
Quoted: 17 Post(s)
I *know* that I want "Motion Enhancer" off, because I hate that 3D look. But "Cinemotion" is confusing me. I know what it does (reverse 3:2) but I'm trying to determine the difference between "Auto 1" and "Auto 2". I just spent like half an our Googling and I've been unable to get an answer.
It appears that Auto 1 *may* do some frame interpolation, even if Motion Enhancer is off. It does make things look odd (to me).
Auto 2 does a better job, to my eye. Some have said that Auto 2 disables Motion Enhancer, but if I turn it to High I can still see some effect, but no where near as pronounced as with Auto 1. Then again, maybe I'm just imagining it.
Does anyone have a definitive source for the different settings for Cinemotion , if Cinemotion adds interpolation, and how the settings may interact with Motion Enhancer?
JakiChan is offline
post #2 of 7 Old 11-23-2008, 10:26 PM
rault's Avatar
I'd like to know also.
Subscribing.
PSN-RacerRex
CT-100 settings courtesy of Da1writer
http://www.avsforum.com/avs-vb/showp...&postcount=745
rault is offline
post #3 of 7 Old 11-24-2008, 05:45 AM
GebLX's Avatar
If your feeding your TV a 1080/24p signal, then Cinemotion IMO should be turned off. I've tried both the Auto 1 and Auto 2, and while Auto 1 is cool if you like to get some of the affects of Motion Enhancer, it causes too much stutter to me. Auto 2 just does the 3:2 pulldown affect, but causes stutter too on my TV( V4100 ). I leave it off after doing a few tests.
GebLX is offline
post #4 of 7 Old 07-15-2010, 05:09 PM
G.B.'s Avatar
I wish Sony would give better examples of this Auto 1 & Auto 2. Other parts of the Menu as well. They give You no clue other than presets... Scene Select You can go to menu & see what Sports does , Cinama... General is most used on reviews. Auto I see nothing change ???
G.B. is offline
post #5 of 7 Old 07-15-2010, 07:05 PM
Toski's Avatar
When I had my Sony EX500, I noticed that with Motionflow set to High and Cinemotion set to Auto 1, it would produce the SOE. If you leave Motionflow on High but set Cinemotion to Auto 2, the movie still looked like a movie but without judder. I preffered the Motionflow on High and Cinemotion on Auto 2.
Toski is offline
post #6 of 7 Old 07-16-2010, 07:49 AM
8mile13's Avatar
Quoted: 1479 Post(s)
Liked: 825
1080P24/motionflow should be off or you will get 1080P.
Here is a Motionflow and Cinemotion explained post and thread.
8mile13 is offline
post #7 of 7 Old 07-16-2010, 08:18 AM
G.B.'s Avatar
Thanks..
G.B. is offline
Reply LCD Flat Panel Displays
