Help Check my Cables/Connections for My New Setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-24-2008, 06:26 PM - Thread Starter
magogian's Avatar
Hello all,
Thanks to all of your help, I'm close to nailing down what components I'm going to buy this week.
Forgive my limited artistic skills, but I created a basic chart showing how I think the components should be connected. Please let me know if I am wrong/it will cause problems/or if there is a better way.
In particular, can I connect my PC's audio directly to the receiver, while the video goes directly to the TV? I don't want to get another graphics card just to get a straight HDMI connection from my PC to the TV. Instead, can I just connect the 3.5mm optical out from my PC to the receiver as shown?
Thanks so much!
[IMG][/IMG]
Click a few times on the image to enlarge.
magogian is offline
post #2 of 8 Old 11-25-2008, 05:58 PM - Thread Starter
magogian's Avatar
Bump for help please!
magogian is offline
post #3 of 8 Old 11-25-2008, 06:15 PM - Thread Starter
magogian's Avatar
oops, double post
magogian is offline
post #4 of 8 Old 11-25-2008, 07:26 PM
Leadsalad's Avatar
It's fine except that you could just run the HDMI from the computer through the receiver as well along with the audio.
Leadsalad is offline
post #5 of 8 Old 11-25-2008, 07:44 PM - Thread Starter
magogian's Avatar
I don't have HDMI on my computer, only DVI. Plus, the Okyno 606 manual says that it can't receive video from PCs.
magogian is offline
post #6 of 8 Old 11-25-2008, 08:09 PM - Thread Starter
magogian's Avatar
Another question, are there any cables that I'm missing?
magogian is offline
post #7 of 8 Old 11-25-2008, 08:18 PM
Leadsalad's Avatar
Well, you could try it regardless of what the manual says. You're running a DVI->HDMI converter cable, could just plug it in to see.
No, you're not missing any cables, the one good thing to come of HDMI is cabling simplicity.
post #8 of 8 Old 11-25-2008, 08:29 PM - Thread Starter
magogian's Avatar
Thanks for your help!
magogian is offline
Reply LCD Flat Panel Displays
