True Or False: You can use 3 Yellow RCA video cables in place of the 3 component... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 11-28-2008, 03:59 PM - Thread Starter
nullqwerty's Avatar
Hey folks,
I have 3 extra yellow rca video cables laying around. Can I use them in place of the 3 Red/Green/Blue cables for a component hookup?
If so, do the three yellow rca cables have to match (company and brand) or will any 3 high quality video cables do?
nullqwerty is offline
post #2 of 12 Old 11-28-2008, 04:01 PM
Kal Rubinson's Avatar
Quoted: 672 Post(s)
Liked: 457
In theory, any competent 3 75ohm video cables will do.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #3 of 12 Old 11-28-2008, 04:02 PM
jalis's Avatar
RCA cable are RCA cable are RCA cables..... i think its funny how people will spend extra money on a subwoofer cable... its the same thing so yes you can use the composite cables for component cables.
jalis is offline
post #4 of 12 Old 11-28-2008, 04:11 PM
av.pallino's Avatar
Originally Posted by nullqwerty View Post
Hey folks,
Any 3 RCA cables will work.
av.pallino is offline
post #5 of 12 Old 11-28-2008, 04:23 PM
RevToTheRedline's Avatar
You can use 3 white ones or 3 red ones too or 3 purple ones.
RevToTheRedline is offline
post #6 of 12 Old 11-28-2008, 05:23 PM
John327's Avatar
RCA cables are made video, left and right.
The cable itself is a 2 wire positive and ground.
Component cables are: Green, Blue, Red or YPbPr which are made up of coaxial cable (RG59 or RG6).
Coaxial cable have far better bandwidth capabilities than 2 wire. That's why the industry uses those kinds of cables for component. No conspiracy!!!
You can get away with using RCA cables in place of component cables for a 480p signal, but your image quality would be degraded for 720/1080p.
In a bind I have used RCA cables in place of component.
A good quality RCA cables' Video connection(yellow) is made of RG59 at best, so that is a good connection for the Green of component, which caries the Luminance signal.
Cheap RCA cables have all 3 wire as 2 wire
But why settle for second best when you can just get affordable component cables? Monoprice etc...
If you're really on a budget and you got some time on your hands, go by 30 feet of RG6 cable at your surplus electronics store and some RCA connectors, Google "how to make your own component cables" and BAMMM cheap good quality compenent cables.!!!
John327 is offline
post #7 of 12 Old 11-28-2008, 08:35 PM
david(dallas)'s Avatar
Quoted: 135 Post(s)
Liked: 41
true
david(dallas) is offline
post #8 of 12 Old 11-28-2008, 08:38 PM
nm88's Avatar
No, they're not. But any video cable will work.
nm88 is offline
post #9 of 12 Old 11-28-2008, 09:05 PM
neo1022's Avatar
true. (but don't use the red or white audio cables.)
neo1022 is offline
post #10 of 12 Old 11-29-2008, 03:54 AM
Carled's Avatar
I use a spare component video cable as an audio interconnect in my setup and it does the job with aplomb. 75Ω coax is 75Ω coax.
Carled is offline
post #11 of 12 Old 11-29-2008, 08:18 AM
saturation's Avatar
RCA cables vary in quality, but as other said, its bandwidth was not designed to component video even if you get one made to spec.
I did a quick test with photos using RCA, component and HDMI video on just 480p material and the distortion is easily seen on A-B comparisons. You can find the photos on a post I made on AVS.
saturation is offline
post #12 of 12 Old 06-21-2014, 04:10 AM
Liked: 0
Exclamation No.
Based on most of the replies I did try it out. And in the end result broke it. After about 10 minutes of listening to music using the yellow rca cable for audio (subwoofer port) it broke, (making my subs to a loud POP noise that scared the living daylights out of me). Guess I will have to get myself some new cables...
Darkbullet009 is offline
Reply LCD Flat Panel Displays
