IS XBR really better? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 11-29-2008, 12:38 AM - Thread Starter
jyeh74's Avatar
I'm comparing Sony's KDL-52S4100 with Sony's KDL-52XBR6. The difference is about $1000. For basic blu ray and video games and HD tv, is it really worth the extra $1000? What makes XBR that much better anyways? I compared the specs and there are things that the XBR has like "Advanced Contrast Enhancer (ACE)" and "Motion Flow 120Hz" that the other model does not have, but really, do you guys think it is worht the extra $1000?
jyeh74 is offline
post #2 of 11 Old 11-29-2008, 12:50 AM
_Noah_'s Avatar
Go to the SonyStyle site and do a side by side comparison of features.
Looks like the XBR offers better video processing, more inputs, and better internal speakers. Probably a few other things I've missed but I don't think the difference is worth an extra $1000
_Noah_ is offline
post #3 of 11 Old 11-29-2008, 12:58 AM - Thread Starter
jyeh74's Avatar
Yep, I did that. Just wanted to get everyone's opinions
jyeh74 is offline
post #4 of 11 Old 11-29-2008, 02:39 AM
HiFiFun's Avatar
It is for the stockholders!
HiFiFun is offline
post #5 of 11 Old 11-29-2008, 02:50 AM
wtfer's Avatar
Quoted: 147 Post(s)
Liked: 40
Well, aside from the speakers & extra features, the XBR6 will have a noticeable improvement in deeper darker black levels & overall better contrast as well as better motion handling.
If you can afford it, go for it.
wtfer is offline
post #6 of 11 Old 11-29-2008, 08:05 AM
DR. BILL's Avatar
You can split the difference and get the Z4100. That unit is as good as the XBR and $300 or so less.
DR. BILL is offline
post #7 of 11 Old 11-29-2008, 08:17 AM
GEOgamer's Avatar
XBR's have backlights, this is MAJOR diffference .
I'm thinking to buy a 46XBR6 but thinking wait until middle of December, will be cheaper.
Man Black Friday was a Dissaster for stores, they sold just 40% of stuff and don't know what to do beacuse people can't buy this kind of stuff if you aren't REALLY sure you don't lose your job in a couple months, and problem is bigger than TV, companies going out off business like a hell or firing 50-70% of workers.
I was thinking to buy from AMAZON but it charging Sales TAX for NYC and i'm in trouble,
do anyone knows good online retiler for XBR without S.Tax for NYC ?
GEOgamer is offline
post #8 of 11 Old 11-29-2008, 09:20 AM
TVbc's Avatar
??? ALL lcd's have backlights. that's what provides the light for the image you see. no backlight, no image.
most lcd's have CCFL cold cathode fluorescent lamps for the backlighting. some use LED's, the new sony xbr8, the new samsung 950 and the new sharp.
plus a couple of older versions from sony and samsung.
iirc afaik fwiw imo
TVbc is offline
post #9 of 11 Old 11-29-2008, 09:52 AM
GEOgamer's Avatar
Series
Size Range
Resolution Bravia Engine ACE True 24p DMex TV Guide IPG 3D Graphic Onscreen Controls 120 Hz 10-Bit
Deep Color x.v. Color DLNA
Backlight Dynamic Contrast Multi Device Control Component Inputs HDMI Inputs Speakers Standard Features
L 32",37"
720p
(1366x768)
8,000:1
1 2 2 x 10W 1 PC Input
178 degree viewing angle
VESA mounting compatible
8 ms panel response
ATSC/NTSC tuner with QAM
M (19-inch) 19"
720p
(1440x900)
9,000:1
1 1 2 x 5W
M 26",32",37"
720p
(1366x768) BE2 ACE
9,000:1 Bravia Theatre Sync 2 2 2 x 10W
N 26",32",37" 720p
(1366x768) BE2 ACE
9,000:1 Bravia Theatre Sync 2 2 6 (2x7W + 20W internal subwoofer + 2x7W external)
S 40",46"
1080p
(1920x1080)
ACE
25,000:1
2 3 2 x 10W
V 40",42",46",52"
1080p
(1920x1080) BE2 ACE
25,000:1 Bravia Sync 2 4 2 x 10W
W 40",46",52"
1080p
(1920x1080 BE2 ACE
30,000:1 Bravia Sync 2 4 2 x 10W
Z 40",46"
1080p
(1920x1080 BE2 ACE
XBR6
(37-inch
or smaller) 32",37"
1080p
(1920x1080) BE2 ACE
XBR6
(40-inch
or larger) 40",46",52"
1080p
(1920x1080 BE2 ACE WCG-CCFL 50,000:1 Bravia Sync 2 4 2 x 10W
XBR8 46",55"
1080p
(1920x1080 BE2
Pro ACE Pro TRILUMINOS RGB LED over 1,000,000:1 Bravia Sync 2 4 TBD
Check yourself and compare:
http://www.amazon.com/Sony-Bravia-KD...977503&sr=1-24
GEOgamer is offline
post #10 of 11 Old 11-29-2008, 12:10 PM
ls1z28's Avatar
Check PriceGrabber.com
ls1z28 is offline
post #11 of 11 Old 11-29-2008, 01:44 PM
DR. BILL's Avatar
I was looking at both of these and decided on the Mitsubishi LT 40128. Better PQ and with the $600 gas card tough to beat. You would have to buy before the end of November for the card.
DR. BILL is offline
Reply LCD Flat Panel Displays
