KDL-52xbr5 speaker settings revert back after changes saved - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-30-2008, 10:36 PM - Thread Starter
pseudotrash's Avatar
Hopefully someone can help.
The players:
TV- 52xbr5
Blu-ray- s350
Receiver- 4300es
Sat- Directv HR22 HD DVR
Remote- Harmony 1000
The scenario:
Sat & Blu-ray are connected to receiver via HDMI 1.3 cables.
Receiver out to TV via HDMI 1.3 cable.
The problem:
TV speaker setting is set to "Audio System"; Audio out set to "Fixed".
TV displays something like 'switching to external source' when powered up and working correctly.
When I turn everything off and then back on, most of the time (more than occassionally) the TV speaker setting will revert back to "TV Speakers" and the amp mutes itself. When this happens I always have to press the mute button on the remote to turn the muting off and go back into the TV settings to change back the aforementioned settings.
What gives? Let me know if you need more info.
Thanks in advance and Happy Holidays to all.
What gives?
pseudotrash is offline
post #2 of 4 Old 12-01-2008, 07:21 AM
schlick's Avatar
Are you using hdmi control? If so, disable it. Then disconnect all inputs to the tv, and attempt to replicate the problem. If it can be reproduced with no connections and hdmi control off, the tv needs service.
schlick is offline
post #3 of 4 Old 12-01-2008, 03:52 PM - Thread Starter
I am using hdmi control and will try your suggestion. Thanks for the help.
post #4 of 4 Old 12-01-2008, 07:31 PM
schlick's Avatar
You shouldn't have to troubleshoot the connections. I'm guessing the hdmi control is the culprit.
schlick is offline
Reply LCD Flat Panel Displays
