ILO TV help! I can't find any support. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-05-2009, 08:29 AM - Thread Starter
vettegofast's Avatar
Hello all,
I have an ILO 42" LCD HDTV 1080i from walmart. I am trying to receive the off air digital channels. However, i cannot receive them. I also have a DTV coax port on the back and I have tried it as well. The "dot" button on the remote does nothing. Can someone alse with an ILO give me a hand?
If not, does someone have the support information for ILO?
vettegofast is offline
post #2 of 4 Old 01-05-2009, 08:42 AM
nowretired's Avatar
Originally Posted by vettegofast View Post
Hello all,
You probably just need to do an automated scan of both digital cable and digital over the air (OTA). What kind of external antenna are you using? Does this TV have two coax rf inputs? Most don't. If it just has one coax input, you'll need an A/B switch to connect to an external antenna in addition to the digital coax.
nowretired is offline
post #3 of 4 Old 01-05-2009, 10:08 AM - Thread Starter
Thanks for replying.
I tried a scan with no luck. It has 2 RF inputs, one says "DTV". I am not sure if this is for cable TV or not, but i am not using it. I have my Satalite hooked on on the HDMI. I am using a regular antenna, no amplifier.
thanks again
post #4 of 4 Old 01-06-2009, 08:43 AM
nowretired's Avatar
thanks again
What are the 2 RF inputs labeled? DTV and what else? What input is your external antenna connected to? Have you tried scanning with the antenna hooked up to the DTV input? You also might want to look in your settings menu to see if it is set up as a Cable input, rather than "over the air". That would prevent you from finding the OTA channels.
Reply LCD Flat Panel Displays
