Official Toshiba Regza 32CV510U/37CV510U Owner's Thread - AVS Forum | Home Theater Discussions And Reviews
post #1 of 26 Old 01-10-2009, 08:12 AM - Thread Starter
TygerClaw's Avatar
Friday morning I made the jump and ordered the Toshiba Regza 32CV510U as my very first HDTV, I thought I make this thread for those who may have own this series of HDTV.
Feel free to post what you think of this particular model of TVs as well as any calibration settings, I will be using this TV for Gaming, TV, and Blu-Ray.
Video
DynaLight™ Dynamic Back-Light Control
PixelPure® 4G 14-Bit Internal Digital Video Processing
60 Hz Video Scan Rate
Cinespeed™ LCD Panel
TheaterWide® Modes
ColorMaster™ Color Control
Color Temperature Control
Native Mode™
Built-In ATSC/NTSC/QAM Digital Tuning
Audio
SoundStrip® Speaker System
Convenience
Auto Aspect Control
Sleep Timer
REGZA-LINK® (HDMI™ CEC)**
Gaming Mode
Input Labeling
Picture Freeze
Mute
4-Item Universal Remote*
Jackpacks
HDMI™ Digital Inputs: 3 (1 Side)
15 Pin D-Sub PC Input
ColorStream® HD Component Video Inputs (2)
Analog Audio Out (Variable)
Dolby® Digital Optical Output
Front A/V / Rear A/V / Rear S-Video: 1/1/1
Weights and Dimensions
Dimensions: 31.0 x 20.7 x 3.4 (WxHxD)
Weight With Stand: 28.6 lbs.
Dimensions With Stand: 31.0 x 22.3 x 9.7 (WxHxD)
Weight With Packaging: 35.2 lbs.
Dimensions With Packaging: 34.5 x 24.9 x 9.9 (WxHxD)
TygerClaw is offline
post #2 of 26 Old 01-11-2009, 01:38 PM - Thread Starter
TygerClaw's Avatar
No love for these TVs?
My 32" will arrive sometime on Tuesday and I look forward to it, I'm just curious if others are still enjoying there TVs?
post #3 of 26 Old 01-18-2009, 01:14 AM
PraiseBear's Avatar
Ordered my 32CV510U Wednesday night, and it arrived at the door Friday afternoon. I also own a 26HL67. These Toshiba have amazing PQ. The new 32" does not disappoint.
PraiseBear is offline
post #4 of 26 Old 01-18-2009, 07:25 PM - Thread Starter
TygerClaw's Avatar
I been enjoying my 32CV510U so far, The picture quality is great, The Xbox 360 also looks great on it, My only issue so far is the QAM tuner is not picking some of the local HD channels through my cable provider which is Comcast.
The ATSC tuner has trouble picking up some of the OTA channels, But other then that, I'm loving this TV.
post #5 of 26 Old 01-18-2009, 09:51 PM
PraiseBear's Avatar
My experience here is quite the opposite. I think the new tuner in my 32" is clearly better than my older 26HL67. Don't get me wrong, the 26" tunes in every unscrambled channel that my cable company has to offer. But the new 32" picks even more channels, albeit all of the extra TV channels are duplicates of something else, and they don't offer higher res. In addition, the new 32" brings in FM radio stations as well!!! Analog channels are coming through fine, but I don't usually watch them. Once you've seen HD and digital broadcast, it's very hard to turn back. If you're not happy with the reception, talk to your cable company. I had to do that myself. When I first got the 26", the digital reception was awful. I called the cable company. They sent a tech and installed amps. Everything looked a whole lot better after that.
While I'm at this, let me also mention that I love this Toshiba design, which takes one cable input and tunes in everything. My JVC and my PC require 2 inputs, one for analog and one for digital. This means I have to split the signal externally. This Toshiba takes one input and does everything internally. Thank you.
post #6 of 26 Old 01-18-2009, 10:16 PM - Thread Starter
TygerClaw's Avatar
Well, I have an HDTV tuner card on my PC that finds all the unencrypted QAM channels, Its just that two of the local HD channels aren't picking up on my TV for some odd reason.
It finds all the standard definition versions of the local channels however, I just want all the local channels in HD and I'm missing only 2 that its supposed to detect.
post #7 of 26 Old 01-19-2009, 12:19 PM
PraiseBear's Avatar
I don't think I have the answers to solve your problem just yet. My local HD channels (CBS and ABC) sometimes give me troubles that other HD channels don't. I wonder what is the signal strength of these channels showing on your TV. If you manually enter those channels that your tuner is not picking up and check the signal meter. Does it say that the signal is too weak, or something else?
post #8 of 26 Old 01-19-2009, 03:29 PM - Thread Starter
TygerClaw's Avatar
When I go to the signal meter, You can select the physical channel number and it would give you the signal strength, I don't know what the physical channels for CBS and ABC are, I have tried going into the channel edit screen and looked at every single digital channel it detected, The majority of them are unchecked cause they are encrypted, And non of them is CBS or ABC in HD, The TV just doesn't find those two channels in HD, only in SD.
The only channels it finds in HD are Channel 2 PBS (WPBT-DT), Channel 6 NBC (WTVJ-DT), Channel 7 Fox (WSVN-DT), Channel 33 MNT (WBFS-DT) and Channel 39 CW (WFSL-DT).
post #9 of 26 Old 01-19-2009, 07:18 PM
PraiseBear's Avatar
Actually, when I read my own post, I realized that I was asking the wrong question. What I was really curious about were the 2 missing HD channels that you said your PC picked up, but your TV didn't. Do you know the channel numbers of those 2 missing HD channels? And what happen when you enter those numbers manually? on your TV? I imagine the TV will not show anything, but is it because of the weak signal, or because of something else?
post #10 of 26 Old 01-20-2009, 12:16 PM - Thread Starter
TygerClaw's Avatar
The channel numbers are completely different on the TV then on the PC, For example, WTVJ-DT on the PC using GB-PVR shows up as 118.176 and on the TV its 118-432.
When ever I attempt to enter a channel that it didn't find, It will revert to the closest channel channel thats unecrypted. For example, If I were to enter on the TV something like 118-433, It will just tune back to 118-209 because the TV doesn't detect that channel.
post #11 of 26 Old 01-21-2009, 01:25 PM
jdbskype's Avatar
I got my 32CV510u last week and have been enjoying it as well. This set seems to do best in darker rooms (though, don't they all). The off-angle viewing is not as great as others in its class but overall I'm quite happy - particularly since the set is less expensive than others in its class. I'm watching OTA HD broadcasts and waiting for a HDMI cable to try some upconverted DVDs.
JDB
jdbskype is offline
post #12 of 26 Old 01-21-2009, 07:31 PM
seank's Avatar
Does anyone know if the Toshiba 32CV510U supports 1:1 pixel mapping?
seank is offline
post #13 of 26 Old 01-21-2009, 10:48 PM
PraiseBear's Avatar
I'm not familiar with 1:1 pixel mapping myself. But I found this in the manual (p.39). I hope this is what you're looking for.
Dot by Dot
(for VGA, SVGA, XGA, and WXGA sources only)
Dot by Dot is a non-scaling display.
Depending on the input signal format, the picture is displayed
with sidebars and/or bars at the top and bottom. (Example:
VGA input source)
post #14 of 26 Old 01-26-2009, 07:00 PM
ace660's Avatar
How is this TV for gaming (PS3, Xbox 360)? Any input lag or ghosting?
ace660 is offline
post #15 of 26 Old 01-30-2009, 10:28 AM
ace660's Avatar
Bump...
ace660 is offline
post #16 of 26 Old 01-30-2009, 06:18 PM
PraiseBear's Avatar
Sorry, Pal, that you didn't get any responses. I wish I could help, but my TV is not hooked up to any game console. I could tell you this though: My other Toshiba is hooked up to a Wii, and I have not experienced any lag or ghosting. I didn't even turn on the Game Mode. The other Toshiba is an older REGZA. So, I expect this new one is even better. Good Luck.
post #17 of 26 Old 01-31-2009, 08:14 AM
ace660's Avatar
ok, thanks for the reply.
ace660 is offline
post #18 of 26 Old 02-02-2009, 06:15 PM
PraiseBear's Avatar
Owners, you might like to know that the 32" has just been picked by Consumer Reports as CR Best Buy for 32" 720p sets. I'm happy about that.
post #19 of 26 Old 02-03-2009, 11:10 PM - Thread Starter
TygerClaw's Avatar
My Xbox 360 is hooked up to it via Component cables, And so far I have not experience any input lag, All seems flawless.
Then again I turned the Game Mode on while using it.
post #20 of 26 Old 02-04-2009, 07:50 AM
ace660's Avatar
Thanks for the reply TygerClaw.
ace660 is offline
post #21 of 26 Old 02-16-2009, 04:48 PM
romanesq's Avatar
With some reviews and user comments, there doesn't seem to be any contrast numbers on this model at all.
What is the contrast?
It's all just a game. I just play to win.
romanesq is offline
post #22 of 26 Old 02-16-2009, 05:52 PM
PraiseBear's Avatar
It's a good question. Even as owner of the set, I couldn't find the number for contrast ratio in the manual. Toshiba doesn't seem to care about advertising it. Then again, I think you already know that whatever the manufacturer claims to be the contrast ratio isn't a real good measure of the actual performance of the set. The only thing I could say about the Toshiba's contrast is that it looks very good to this set of eyes. (Probably not the objective comments you were looking for.)
post #23 of 26 Old 05-21-2009, 06:03 PM
murfie4's Avatar
Here are my settings.
Contrast 100
Backlight 100
Dynalight on
Brightness 50
Color 85
Tint -6
Sharpness 69
Advanced Picture Settings
Dynamic Contrast High
Static Gamma -2
Color Temp Cool
Color Temperature
B Drive +4
G Drive +9
Color Master
Red Hue +10 Sat +11 Brightness +6
Green Hue +11 Sat +5 Brightness +7
Blue Hue+13 Sat+11 Brightness +6
Yellow Hue +6 Sat+ 6 Brightness +6
Magenta Hue+5 Sat+ 2 Brightness +1
Cyan Hue+9 Sat+ 5 Brightness -6
murfie4 is offline
post #24 of 26 Old 12-06-2009, 03:14 PM
Fabricator's Avatar
Quoted: 20 Post(s)
wow, no kidding, thats
hello guys. just found this thread. i have had mine since feb. it is just a basic tv viewing set. and i find the pq to be very good.
what i am looking for. is a way to find out how many hours are one it.
thanx
chasing rattles ......Pro8100 & Da-Lite HP 2.8 Cult member
Fabricator is offline
post #25 of 26 Old 12-11-2009, 07:21 AM
MarcSparks's Avatar
Any owners of the 37CV510U on here? Was wondering what the real measured width of this TV is. The specs on Newegg say it is 36.1" wide, but there's no way that's right. Has to be in the low 35" range. Based on the pic and the fact a 37" screen itself is only 32.25" wide.
Looking for the holy grail of 37" diagonal TVs that has a thin enough bezel to be less than 35" wide to fit in a legacy cabinet for my parents.
MarcSparks is offline
post #26 of 26 Old 12-11-2009, 09:56 AM
greg42's Avatar
Toshiba says 35.5 inches wide. Hm, not quite gonna make it sounds like.
http://www.tacp.toshiba.com/televisi...model=37cv510u
The bezel of that unit is pretty thin, but I'm thinking not quite as thin as the one on my 40XF550U, because the width of my 40" set is only 36.8 inches. It's a great unit but was not made in a 37".
I think the 37CV510U is probably the closest you're going to get. If you can just figure out a way to deal with that half an inch....
greg42 is offline
Reply LCD Flat Panel Displays
