Samsung LN52A550 or Toshiba 52RV535U ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 03-01-2009, 07:57 AM - Thread Starter
mullet34's Avatar
The Sammy is $100 more and has terrible speakers. Is there any reason to go with the Sammy?
mullet34 is offline
post #2 of 11 Old 03-01-2009, 08:49 AM
ramazur's Avatar
This accusation is false in my opinion. I had this set since September plus an AV reveiver with decent speakers available to me at any time. I find the set's speakers very acceptable. To get the best out of them I selected MUSIC for the audio setting.
ramazur is offline
post #3 of 11 Old 03-01-2009, 11:59 PM
maxdog03's Avatar
None of the sets from the factory have what I would consider very good sound. I don't understsand how people can have a big screen set up with the stock speakers, as the sound is at least 40% if not more of the experience.
maxdog03 is offline
post #4 of 11 Old 03-02-2009, 02:28 AM - Thread Starter
mullet34's Avatar
As to the Sammy speakers, hundreds of reviewers made them their #1 con about the unit. Does anyone have an opinion about the 2 TV's?
mullet34 is offline
post #5 of 11 Old 03-02-2009, 08:26 AM
BillP's Avatar
Quoted: 260 Post(s)
Liked: 201
Based on reviews, the Sammy is the better display. IMO, you should be using external speakers anyway.
BillP is offline
post #6 of 11 Old 03-03-2009, 12:49 PM
woodyjoe's Avatar
One thing the 535u has that the 550 doesnt is srt. It will improve your picture when viewing 480/720 and dvd sources.
http://www.avsforum.com/avs-vb/showthread.php?t=1113668
If possible find a place you can compare with similiar picture settings.
woodyjoe is offline
post #7 of 11 Old 03-03-2009, 01:14 PM
ludawg23's Avatar
uhhh the set speakers are AWFUL. One of the worst for sure...
Anyone with a good sized LCD should opt for an avr receiver and some decent speakers.
ludawg23 is offline
post #8 of 11 Old 03-03-2009, 01:16 PM
woodyjoe's Avatar
A soundbar can also be a good option.
woodyjoe is offline
post #9 of 11 Old 03-03-2009, 02:33 PM
Tree Dude's Avatar
I have the 535U and the speakers are ok. They are no better/worse than any other TV speakers I have used. IMO SRT is crap, it really is just edge enhancment. However SD on mine looks great with it off. I have just basic cable and I was very suprised at how good the picture was.
XBL and Steam: Atomic TreeDude
Tree Dude is offline
post #10 of 11 Old 03-03-2009, 02:41 PM
woodyjoe's Avatar
How are your srt modes and levels set?
woodyjoe is offline
post #11 of 11 Old 03-04-2009, 06:19 AM
Tree Dude's Avatar
I have played with them all. To me it really just looks like someone cranked the sharpness. But like I said SD looks great so I really don't have an issue with it.
Reply LCD Flat Panel Displays
