Need help making a desision on sub-$800 LCD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-07-2009, 12:25 PM - Thread Starter
BassKozz's Avatar
I went around to my local Wholesale stores (BJ's & Costco) as well as BestBuy (Rip-off, no good deals), I took down the model numbers of all the different TV's greater than 32inches but less than $800, I then compared the prices to Amazon.com, and this is what I came up with: http://spreadsheets.google.com/ccc?k...HUd1yrmqRwuZDQ
At first I was leaning towards the 37inch Vizio VW37LHDTV30A/40A from costco ($579.99), but then I thought for $100 more I could get the 42inch Panasonic THC42HD18 (also from costco)...
So many choices, I don't know what to do?
Any/All feedback is GREATLY appreciated.
-BassKozz
BassKozz is offline
post #2 of 5 Old 03-07-2009, 01:37 PM
BillP's Avatar
Quoted: 260 Post(s)
Liked: 201
I would personally stick with Panasonic, Samsung, or Sony.
BillP is offline
post #3 of 5 Old 03-07-2009, 02:32 PM
N1LSS's Avatar
gonna have to place my vote for a samsung, but in my opinion i would try and save a little more for a better modle. $800 doesn't offer a whole lot in the way of options [IMG]http://************************************/img/2464/i09b0128lrvx/smile.gif[/IMG]
N1LSS is offline
post #4 of 5 Old 03-07-2009, 03:52 PM - Thread Starter
BassKozz's Avatar
So would the 42inch Panasonic THC42HD18 for $679 (Costco) be my best bet?
I don't have a choice I have to stick with $800 as my budget unfortunately.
Which Samsung would you go for:
40inch / LN-T4069F / $749 (BestBuy)
32inch / LN32A330 / $440 (BJ's)
32inch / LN32A450 / $545 (Amazon)
32inch / LN32A540 / $599 (Costco)
Just curious why the affinity for Samsung's ?
BassKozz is offline
post #5 of 5 Old 03-07-2009, 11:22 PM
woodyjoe's Avatar
Check out the toshibas.
woodyjoe is offline
Reply LCD Flat Panel Displays
