LN40A550 & Dynamic Contrast (Low) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-03-2009, 06:45 AM - Thread Starter
Ace H's Avatar
With the Samsung LN40A550's Dynamic Contrast set to LOW and Backlight set to 5, Contrast 85, Brightness 45 my picture (in my opinion) is VERY GOOD.
QUESTION: Does using Dynamic Contrast alter the Backlight , Contrast and Brightness settings (mentioned above) in any way since the picture quality becomes noticeably better when Dynamic Contrast is turned on even to the LOW setting?
Ace H is offline
post #2 of 4 Old 04-03-2009, 01:32 PM
xraffle's Avatar
I agree. Does anyone have an answer to the question?
xraffle is offline
post #3 of 4 Old 04-03-2009, 03:50 PM
clicq's Avatar
From playing with my own set, it appears that dynamic contrast changes the brightness and contrast levels, but not the backlight (you can put the energy saving setting to auto for that).
I actually find that I have to lower contrast (to prevent bright scenes from getting too bright) and increase brightness (to ensure all the shadow detail is still visible) if I have dynamic contrast enabled.
clicq is offline
post #4 of 4 Old 04-03-2009, 04:04 PM - Thread Starter
Ace H's Avatar
My Energy Saving is set to Auto (the default setting). Perhaps the Auto setting compensates for adjusting the overall picture. As a matter of fact all other settings other than those mentioned were left to their default settings. Picture Mode is on the default setting of Standard.
Ace H is offline
Reply LCD Flat Panel Displays
