HELP! Just noticed this pixel issue. What do I Do? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-07-2009, 06:40 PM - Thread Starter
JP1080INC's Avatar
I have a 52 inch sony bravi lcd. KDL-52V4100. I have had it for about 6 months and only use it about 10 hours a week.
I just noticed this weird pixel issue that is showing up on the left side of the screen. It doesnt show when the screen is black but anything other than black it will show. They kind of flicker a little very lightly.
Can anyone please help me and provide advice. I want this fixed.
JP1080INC is offline
post #2 of 9 Old 04-07-2009, 06:48 PM
vultureyo's Avatar
only thing you can do is contact sony..... is under your 1 year. I assume you didn't get a store protection plan?
http://eservice.sony.com/webrma/web/index.do
vultureyo is offline
post #3 of 9 Old 04-07-2009, 06:57 PM - Thread Starter
JP1080INC's Avatar
[quote=vultureyo;16219773]only thing you can do is contact sony..... is under your 1 year. I assume you didn't get a store protection plan?
i got a 3 year but it was through the crap hole circuit city!
all i have heard is horror stories of people trying to get there stuff fixed or replaced after they went under.
post #4 of 9 Old 04-07-2009, 07:03 PM
frito's Avatar
[quote=JP1080INC;16219834]
your within sony's warranty call them if it does this all the time and on different source devices then its definitely the TV
If you're a gamer or interested in using an LCD TV as a primary monitor take a look at my thread on Input Lag
frito is offline
post #5 of 9 Old 04-07-2009, 07:05 PM - Thread Starter
JP1080INC's Avatar
[quote=frito;16219877]
yep, on the 360 & the PS3!
im going to try and go through sony.
im just scared, i baby this tv and i dont know if i want a service company ripping it apart. what if they cant fix it?
post #6 of 9 Old 04-07-2009, 07:21 PM
frito's Avatar
[quote=JP1080INC;16219894]
Sony will get it fixed, I think from what i have read from other users that have gone though sony for warranty repairs sony just sends a tech out to check out the problem, once its confirmed they send you a replacement or if none is available anymore give you options for what you want them to give you in return that is of the same value I Dont think they will try to fix the TV itself that problem looks to be part of the LCD control board that is connected to the LCD display itself and would need a screen replacement to fix IMO
frito is offline
post #7 of 9 Old 04-07-2009, 07:28 PM - Thread Starter
JP1080INC's Avatar
[quote=frito;16220016]
yep, just got off the phone with sony e support and they gave me the local tech (Consumer Electronics) and i just need to schedule them to come out to my home and look at it. I asked if they cant fix it or break it does sony replace it with a new tv or a REFURBISHED? she did not have a answer. She said that will be discussed between the Tech and the Sony rep that is on my case. BETTER NOT BE REFURBISHED!!!!! ARRRRRR
post #8 of 9 Old 04-07-2009, 09:01 PM - Thread Starter
JP1080INC's Avatar
has anyone had a large lcd replaced by sony with a new one or newer model?
post #9 of 9 Old 04-08-2009, 09:13 PM - Thread Starter
JP1080INC's Avatar
tech will be here next week from consumer reports.
ahhhh hope for the best!
Reply LCD Flat Panel Displays
