Sony Bravia KDL-46S4100 HDMI issues - AVS Forum | Home Theater Discussions And Reviews
post #1 of 40 Old 04-24-2009, 08:29 AM - Thread Starter
trulaker9's Avatar
So here is my problem, I recently purchased a Sony Bravia KDL-46S4100 and hooked it all up using HDMI cables. I had one HDMI cable going to the cable box and 1 HDMI cable going through my Sony Home Theater System and everything was working great. Yesterday I turn on my TV and I have no picture\\sound coming from any of my HDMI connections. The TV does not give me any codes such as "check signal" or "weak or no signal" All I get is a blank screen with HDMI1 or HDMI2 in the upper left hand corner. I hooked up my cable box via component cables and everything works fine, so I figure it isn't the TVs panel. That led me to believe it was the HDMI cables, so I took them over to my neighbors house to test them on his setup and the HDMI cables worked fine. I am at a loss as to what the problem could be, and was wondering if any of you had any ideas?
trulaker9 is offline
post #2 of 40 Old 04-24-2009, 09:06 AM
frito's Avatar
sounds like something related to HDMI on the TV's mainboard broke. try a hard reset just incase its just a software glitch, I cant find the procedure but I have posted it on here before if you do some searching
edit: I found it!
*Reset the TV: With the TV on, hold the UP arrow on the remote and press the power button on the TV (not the remote!). You will lose channel information, etc and have to re-run Auto tuning if you want that feature.
If you're a gamer or interested in using an LCD TV as a primary monitor take a look at my thread on Input Lag
frito is offline
post #3 of 40 Old 05-27-2009, 06:22 AM
konus's Avatar
Hi Trulaker,
have you solved your problem using the "hard reset"?
I'm experiencing the same issue: some days ago, I turned on my brand new 40W5500 and... HDMI don't work anymore... I've tried everything (I used to connect the PC to the TV to watch High Def movies): 3 different graphic adapters, 3 different HDMI cables, 2 different DVI-HDMI adapter and so on... nothing to do...
Frito, do you think the hard reset procedure you suggest could be ok for my TV too?
Thanks for the help!
konus is offline
post #4 of 40 Old 12-22-2009, 07:42 AM
clax66's Avatar
Hey guys, I know this is an older thread but I would realy liike to know if anyone has had any luck with resolving this issue. I have had my Bravia KDL46V5100 for about 10 days when all of my HDMI ports seemed to have stopped working. My component port works just fine....anyone
clax66 is offline
post #5 of 40 Old 02-20-2010, 05:35 AM
petez66's Avatar
I have a KDL-V5100 with exactly the same issue. I actually brought my tv back for an exchange once, and it happened again with the new one too. All HDMI's suddenly quit working, component ins work fine. I'm not sure but it seems to be related to setting HDMI control to on. This issue doesn't seem unique to any one series. I did a hard reset as mentioned above and now its all good again. Too bad |I didn't find this forum before I exchanged the other one....
Thanks frito!
petez66 is offline
post #6 of 40 Old 10-27-2010, 07:35 PM
Jdcan005's Avatar
I have the 46" Bravia, bought in January/10. Yesterday I lost the picture and sound. Tried a different cable and receiver with the same results. I tried the reset with the up arrow and the power button on the set but again with no success. I unplugged the tv for about 30 seconds and as soon as it was plugged in the picture and sound returned. So far so good. jd
Jdcan005 is offline
post #7 of 40 Old 11-04-2010, 07:20 PM
VVBK99's Avatar
I also had HDMI cable failure. I unplugged the TV for over 30 seconds and plugged back in. TV is reset and working as intended. Thanks to this string of problems and fixes
VVBK99 is offline
post #8 of 40 Old 11-22-2010, 07:21 PM
westcoast1965's Avatar
Dudes, I have the same problem described above.
My Sony Bravia KDL40S5100 was working perfectly... purchased in March of this year.
Now for now reason I have ZERO HDMI input available. You're all saying that physically unplugging the TV and resetting it will work?
I already took my Received in to be fixed and they proved it was working, got a new cable too.
I will try the fix.. anybody get a solid answer out of the dealer as to why this happens or if there's a fix for it?
westcoast1965 is offline
post #9 of 40 Old 11-22-2010, 08:05 PM
OK! It worked! If I have to unplug my TV once every 6 months I guess I can live with it - wondering if there's a patch. I'll go talk to the dealer and see what they say.
In the meantime, whomever figured this out - I owe you a beer. If you're ever up in Vancouver let me know!
post #10 of 40 Old 02-13-2011, 10:26 PM
shatheid's Avatar
I have the 46v5100 with the same issue.
The television detects a device is plugged in (hdmi lights up in the input) and devices can recognize it (plugged my laptop in to double check, and SONY TV 1920x1080 pops up on my laptop display options), but no signal is getting to the tv for some reason.
I've tried unplugging it, resetting it (up+power), and I believe my firmware is up-to-date.
Any idea what else it cold be? One day it was working, and the next its not.
shatheid is offline
post #11 of 40 Old 05-27-2011, 09:42 PM
lazysony's Avatar
shatheid,
how did you resolve the problem?
Same situation here, tried the up+Power, the unplug for 5 minute, the fw update, the call to tech to no avail. tech said call service technician. but my tv is 18 months old (out of warranty).
Please share your results.
lazysony is offline
post #12 of 40 Old 07-12-2011, 04:44 AM
ranmoo's Avatar
Thanks for all the info above, and I recognize this is an old thread.
I have a Bravia KDL-46Z4100 and have several of the issues listed above.
About a week ago, none of the FOUR HDMI inputs on my Sony Bravia will accept as an input or work. I have reset the TV, unplugged it for more than 30 seconds, and have updated hte firmware. Nothing seems to work.
As an aside, when you hit "input" on the remote conctrol and there are no cables input into any of the HDMI inputs, the "HDMI3" always shows on the screen as if someting is connected to it, though nothing is.
Any other suggestions (in addition to those above) would be appreciated.
THANK YOU!!
ranmoo is offline
post #13 of 40 Old 07-12-2011, 05:46 PM
74f100's Avatar
I have had a very high rate of TV's getting the HDMI processors blown this year.
If you lose all of them, that is usually the problem if you are using KNOWN good input devices and cables. Just because a cable box works on component doesn't mean it is out putting HDMI. Use a working HDMI DVD or blueray player.
74f100 is offline
post #14 of 40 Old 07-19-2011, 03:31 PM
floydjackson's Avatar
I just had the same problem with all HDMIs. I did the reset and unplug and it worked. I also have my computer hooked up to the VGA, and a couple days ago it started to only display in 4:3 (bars on sides) vs fit to the full 16:9. I tried every option on the computer (Windows 7) and nothing. It did not recognize my tv as the display, instead it said 'generic pnp device'. Now after the reset it says 'Sony TV'.
Definitely something malfunctioned inside.
Thanks for the help.
floydjackson is offline
post #15 of 40 Old 07-25-2011, 06:34 PM
Bishmic's Avatar
Thank you for suggesting the reset option by unplugging. We had picture but no sound (on a Monday night grrrr!!!) so my husband gave up but thanks to this thread, we learned the reset option. Thank you! We unplugged everything, by the way.
Bishmic is offline
post #16 of 40 Old 07-25-2011, 07:12 PM
74f100's Avatar
Also remember to check firmware, I don't remember which models off the top of my head, but a few Sony's had HDMI issues corrected by updating.
Jim
74f100 is offline
post #17 of 40 Old 08-20-2011, 02:44 PM
electrical guy's Avatar
Hello to all, I had the same problem with my 18 month old KDL series 46" Sony. The remedies mentioned on this forum are all really good ones. If, for some reason, these remedies don't work for you try this remedy. Turn off and unplug the power cord for ANY HDMI connected to your TV, including your TV. Wait a couple of minutes and then, one device at a time, depress and hold the power button on each device for about 30 seconds. This will allow the capacitors in each device to completely discharge. The capacitors hold a charge, after they are unplugged, which allows the "error" to stay in the device's memory, holding the power button allows the capacitors to discharge. Then the "handshake protocol" between HDMI input and your devices can be re-established. If the other very good information in this forum doesn't work then give this a try. KUDOS to all that post on here, its my first visit and its a nice site!
Good Luck to all!
electrical guy
electrical guy is offline
post #18 of 40 Old 08-30-2011, 10:10 PM
xbeatle's Avatar
Sorry if this is in wrong place but with all the noise on these pages I have no idea where to start a thread..absolutely no idea
Anyway, I'm having no luck doing the simplest thing. Connecting my Dell XPS 8300 computer with Windows 7 to my Sony.
I'm going VGA - VGA and it says something like bad input, select another input.
Well, I've naturally chosen the PC input..I assume this is correct..but it's not working.
Any input would be greatly appreciated.
J.
xbeatle is offline
post #19 of 40 Old 11-09-2011, 11:01 AM
chrisn06's Avatar
I am aware that is is an old thread but wanted to note that I am having the same issue with my SONY KDL-52V5100 TV. I receive a "no signal" error periodically when using any of the hdmi ports and this has been going on since a month into ownership. I have reset the factory settings multiple times and have uploaded the firmware that SONY sent to me on a USB thumb drive. Over the course of two years I have attributed this problem to everything but the television. I have replaced the hdmi cables, 2 cable hd boxes, my Samsung home theater to a SONY home theater and most recently changed my cable boxes to brand new Direct TV hd boxes....and guess what...still having the same "no signal" problem. Sony has finally agreed to send someone out to evaluate the television but has not made any guarantees about fixing it yet at this point. It sounds to me these televisions have faulty hdmi ports and should be recalled. I guess if it was a fire hazard, SONY would replace it. I wish the problem would not have been intermittent from the beginning and it would have just always said no signal. Then I would have just taken the television back right from the get go. Good luck other SONY owners. SONY products are not what they used to be.
chrisn06 is offline
post #20 of 40 Old 12-08-2011, 08:47 PM
TOM MAR's Avatar
Good Luck to all!
electrical guy
Tried this & Success, Saved me buying stuff I didn't need.
Thanks For Your Help
Tom
TOM MAR is offline
post #21 of 40 Old 12-13-2011, 04:38 AM
larikn's Avatar
I have a 40" HD 3D bravia but cannot get the TIVO to connect to the TV using HDMI. Other devices seem to work. Has any one experienced this problem?
larikn is offline
post #22 of 40 Old 03-10-2012, 08:02 PM
SonyInVancouver's Avatar
I also ran into this issue after updating my firmware. BD player had no sound. Unplugged everything - ALL HDMI devices and did the power button press and then reconnected. All now works great!
The reason for updating the firmware is that the TV would sometiems have no sound or badly tweaked color on the DirecTV receiver. Turning the DirecTV receiver off and back on fixed it.
Now with the new firmware that issue is gone.
SonyInVancouver is offline
post #23 of 40 Old 05-11-2012, 07:51 PM
Johnlangan's Avatar
I was really feeling quite lost and confused till I came across this forum.
I have been searching sites for days trying to find a solution to why I had problems with HDMI and my Sony 46 HDTV. Well I tried the hard reset and all is well in my world now!! One would think perhaps when the Direct TV guys were here replacing what they thought was a defected set top box, that they would have known to try the Sony hard reset. Even when I tried talking to service management they had no clue. All they could suggest was that I would now have to use component cable for sound instead of HDMI. Really disappointed with their level of knowledge.
But a big thanks to all of you that have posted in this thread.
Johnlangan is offline
post #24 of 40 Old 06-07-2012, 09:49 AM
Martin Tichy's Avatar
Huge help. I was getting a little stressed out and after i unplugged it ALL and waited some 5 minutes, it all came back alive. thanks for posting!!!
Martin Tichy is offline
post #25 of 40 Old 06-30-2012, 10:20 AM
Blitzer1215's Avatar
Many thanks to Electrical Guy for the great idea and detailed procedure. In the past the other reset procedures had worked but failed me during this picture outage. I am pretty sure that it was the Samsung AV system power reset that solved this occurrence with the Sony HDMI connectors.. Thanks again to all.
Blitzer1215 is offline
post #26 of 40 Old 07-17-2012, 06:55 PM
TSH2010's Avatar
Similar issue here!!!
Everything was working fine and then saturday we get a black screen HDMI1 and No signal on the screen. Have tried hard resets to everything. Still no help. Tech support from Direct tv & SONY couldn't help either. I have a SONY Bravia KDL-46S4100 TV hooked up to a Direct tv HD receiver H24. I've swapped my HDMI cable to each port on the back of my tv & changed to input on my tv to correspond and that didn't work. The only way it is currently working is through the component cable (red,yellow,white) with horrible resolution. Please help.
TSH2010 is offline
post #27 of 40 Old 07-20-2012, 05:39 AM
Honzascud's Avatar
Hey! I have the same problem and none of the solutions here helped. I have researched this problem online and it really seems like faulty design. There is SO MANY people having trouble with Bravia HDMI ports. I talked to SONY customer support and they told me my problem is ''unique''.. I sent them bunch of links to forums like this - they couldn't do anything.. I'm about to throw that TV out of the window.. cool.gif
Honzascud is offline
post #28 of 40 Old 07-28-2012, 12:12 PM
Guy Gunderson's Avatar
Your instructions did the trick! You fixed my HDMI input problem. Never would have thought of that.
Thanks Electrical guy!!
Guy Gunderson is offline
post #29 of 40 Old 08-05-2012, 04:43 PM
LjRebar's Avatar
Folks,
I fixed my TV by going to the Sony eSupport website, downloaded the latest firmware for my model KDL-46V5100
http://esupport.sony.com/US/perl/swu-spec-eula.pl?mdl=KDL46V5100&upd_id=6532&os_group_id=18&ULA=YES TV and all is OK now.
http://esupport.sony.com/US/p/select-system.pl?model_type_group_id=12
As a matter of fact, things are better, the audio over the HDMI from the cable box was attenuated and now it is a lot better.
Follow the instructions on the website to download and extract the firmware .zip file to a FAT32 formatted flash drive, plug it into the USB port on the back of the TV and wait for the update to show it has completed. Make sure you get the correct firmware for your model TV !!
The firmware my TV was running was ER3something, so it was definitely down rev a bit. The TV setup, last option, all the way at the bottom of the screen shows you what firmware your device is running.
I hope this helps !!
73
LjRebar is offline
post #30 of 40 Old 09-07-2012, 07:22 PM
hdmicry's Avatar
I know this is an old thread, but I experienced the same trouble... I was hearing the audio but couldn't see the video coming out of my COX Cable device.
I was about to buy a new TV set BRAVIA (actually was about to switch brands because of that...), when all it took was to switch off/on the BRAVIA TV set. Who would have thought ??
Thank you very much for posting this fix.....
hdmicry is offline
Reply LCD Flat Panel Displays
Sony Bravia S Series Kdl 46s4100 46 Inch 1080p Lcd Hdtv
