Official Panasonic TC-L32S1 Thread - Page 17 - AVS Forum
post #481 of 483 Old 12-23-2010, 02:24 PM
sjetski71's Avatar
Originally Posted by GammaBreaker View Post
Has anyone tested the Input Lag in Game Mode VS Standard/Cinema? My only irk with game mode is you really have to ramp up the Brightness and Backlight to get the black square test on Lagom to be passable, which brings the black level itself up considerably. Turning Game Mode off quickly makes them easily distinguishable. If the lag in Standard/Cinema isn't that bad (30ms or less is fine) I'd consider readjusting the set for it.
It has been determined that "game mode" on this TV is nothing but a color pre-set, none of them affect input-lag whatsoever.
In other words set it to the best color pre-set and enjoy, your input lag will not suffer one bit, as long as you disable the picture enhancement options of course...
GammaBreaker likes this.
sjetski71 is offline
post #482 of 483 Old 01-05-2011, 10:59 AM
KPOD's Avatar
Originally Posted by frito View Post
yep using an DVI to HDMI cable
my picture settings on my 37S1 are
cinema
backlight 60 (you can change this)
contrast 96
brightness 34
color 40
tint +4
sharpness 0
color temp warm
color mgmt off
x.v. color auto
AI picture off
video NR off
advanced menu
motion focus off (turn this on for cool old school CRT flicker effect lol)
black level light
HD size size 2 (this turns off overscan when its got 1920 x 1080 input resolution.
I'm using these settings for watching DVDs and blu-ray through my PC, however the screen appears to be too dark for my taste, colors are good though. Should I adjust the brightness, or backlight? I'm not quite sure what the difference is, and if anything else needs to be adjusted accordingly when adjusting those settings. Dark blue text is completely unreadable on dark backgrounds.
KPOD is offline
post #483 of 483 Old 01-23-2014, 07:58 AM
hort22's Avatar
bumping a real old thread here...can anyone recommend anything on the market today with great input lag like the S1...ive had the 32" for a few years and its been great...just looking for something a bit bigger now with the same response time.
hort22 is offline
Reply LCD Flat Panel Displays
User Tag List
