Official LG "XXLH90" 240hz LED Owners Forum [NO PRICE TALK] - Page 158 - AVS Forum | Home Theater Discussions And Reviews
post #4711 of 4735 Old 01-12-2013, 04:32 PM
mk262's Avatar
I have a 42LH90 connected to a vizio sound bar using optical (which of course is the only audio out this tv has).
When I view content from my patriot box, connected via hdmi, I can watch all my videos fine, DTS, AC3 5.1, etc.
When I view content from OTA using my antenna, any station, the sound bar starts making a constant buzzing sound. Oddly, the tv speaker works fine. This set has no audio options of any kind once you disable the tv speaker and none of those options are technical. It's balance, bass/treble, etc.
I tried searching this thread but couldn't find anyone with a similar issue. Up until now I've had cable, connected to the tv via hdmi. Now that I'm on broadcast this is my first experience.
I called LG and, after a few rounds, they said they need a day or two to hear back from a higher level team before they can help. Has anyone had a similar problem? I would appreciate any input.
mk262 is offline
post #4712 of 4735 Old 02-02-2013, 03:54 PM
p5browne's Avatar
Quoted: 3133 Post(s)
Liked: 2447
Adding the iScan Duo to both my wife's 42LH90, and my daughter's 55LH90 in order to be able to AutoCal the calibrations of these 2 sets. Cuts down on the various Input Issues, plus will speed up the calibrations. Has been recommended that with AutoCal, use Expert 1 instead of THX. For those who'd like to go higher than the iScan Duo check out www.curtpalme.com re some great specials on the Lumagen units with a Darbee thrown in!
PLUS, let's not forget our Sponsors:
http://shop.avscience.com/Lumagen-Radiance-Mini-3D-Darbee-Darblet-Bundle_p_538.html
UN65HU9000 with SEK-3500U in UJS9000 Mod Mode. SDR Input at 1080P 60HZ 444. 4K separate HDMI input - Mine
UN75JU7100 / UN55HU7250 with SEK-3500U in UJS9000 Mod Mode / UN32EH5300 (On floor and up for sale) / 2 X LG 55LHXs / New addition UN40J5200AF - Wife's
PN64F8500 still up for sale
p5browne is online now
post #4713 of 4735 Old 02-24-2013, 09:00 PM
p5browne's Avatar
Liked: 2447
Still work in progress: as Calman gets better, so does the 55LHX and 42LH90. After much experimenting we're now doing the following.
#1. It appears that calibrating the actual 55LHX and 42LH90, seems to stress the TVs. On my 55LHX, have now off loaded the calibration onto a Lumagen Radiance XE-3D that I picked up on a Black Friday special pricing. (Even better deal now currently re: open box special at www.curtpalme.com with Darbee thrown in - 3 left). My wife's 55LHX and 42LH90 calibration are now off loaded onto an iScan Duos. The Theatre Room LG 55LV9500 is also off loaded onto an iScan Duo.
#2. Calibration is done on Expert 1. The Backlight, Contrast, Brightness, Sharpness and Tint values are placed in all the other Modes. (Backlight, Contrast, Brightness calibrated inside Calman. Colour tweaked inside Calman) All the other Modes have Colour set to Zero. All Modes have any 10 Point IRE's, 2 Point, and CMS values set to Zeroes. All Modes have Gamma set to Low on the 55LHX, Medium on the 42LH90 and White Balance to Warm.
On the 42LH90 and 55LV9500, all HDMI Inputs are zeroed, excepting the Input I'm working on. (Input 2.)
#3. Service Menu White Balances for Cool, Medium and Warm, RGB Gains and Cuts, calibrated for Warm setting values.
#4. The Expert 1 2 Point values are calibrated from within Calman during calibration, and the Expert 1 2/10 Point selection, is left on 2 Point.
#5. Once everything is setup, calibration is done with a Spectracal C6, profiled from a i1Pro, using the current Calman 5.1 version, and AutoCal is used for the 11 Point, and 125 Point 3D LUT. On the iScan Duos, AutoCal for 11 Point and CMS.
Since moving to this form and structure, have had far less problems with the LGs - leaving the stress to the XE and Duos. PQ now looks like watching out your front window to the world, after cleaning the window, and adding a Darbee (on my set only) to enhance the experience!
One thing I've noticed since doing this, when I do a complete reset to all zeroes, the PQ is now looking pretty good. The calibration just makes it look that much better!
post #4714 of 4735 Old 02-27-2013, 11:18 PM
caseflys's Avatar
good info,about to move 52a750 into room to compare side by side...yes it can be turned on/off auto dimm ,thank you 6.gif
caseflys is offline
post #4715 of 4735 Old 05-18-2013, 07:26 AM
p5browne's Avatar
Liked: 2447
Wife got fed up with the Duo's HDMI hand shaking problems, Will now have to do a full re-calibration. Will post values once finished.
6 Hours Later!
May 19,2013
Wife's 47LH90 Calibrations using Calman 5, C6 on TriPod, profiled off NonEn i1Pro
Now using iScan Duo for Patterns instead of the Spectracals DPG1000 Pattern Generator
As per request:
Gamma Medium, White Balance Warm Luminance 156
Service Menu White Balance: Cool/Medium/Warm All calibrated to Warm settings.
A much more fine tuned Brightness and Contrast were done through Calman 5
RG: 192/192/192
GG: 170/171/170
BG: 69/68/67
RC: 66/65/66
GC: 65/64/65
BC: 67/66/67
BL: 45
CT: 78
BR: 49
HS: 54
VS: 58
CL: 49
Tnt: 0
2 Point Calibration:
Red Contrast (100 IRE): 4
Green Contrast (100 IRE): 0
Blue Contrast (100 IRE): 18
Red Brightness (30 IRE): 11
Green Brightness (30 IRE): 0
Blue Brightness (30 IRE): 22
CMS:
RC: 8
RT: -9
Gc: 11
GT: -29
Bc: 2
Bt: 22
YC: -9
YT: -1
CC: 0
CT: -2
MC: 2
MT: -1
10 Point Calibration:
100: -5/-8/11
90 : -1/-5/13
80 : -1/-8/10
70 : -1/-7/14
60 : -2/-5/10
50 : 0/-4/13
40 : 1/-4/11
30 : 3/-2/9
20 : 5/2/10
10 : 7/5/6
Notes: Values will be changing due to 2 different Calibration changes
#1 - Now calibrating only with the i1Pro NonEnhanced for CMS, and Spectrcal 6 Profiled from the i1Pro for Greyscale
#2 - Negating Values in the Computer settings on each HDMI Input /Modes and setting the Backlight, Contrast, Brightness and Sharpness to the same as the Video settings. All Colour settings set to Zero on the Computer Settings. Found that the Computer settings were affecting the Video settings.
post #4716 of 4735 Old 11-27-2013, 03:44 AM
Bond 007's Avatar
Quoted: 2655 Post(s)
Liked: 2108
Bump
Licence to Kill
Bond 007 is online now
post #4717 of 4735 Old 02-22-2014, 07:44 PM
gdg
gdg's Avatar
I just bought one of the last Panasonic TCP50ST60 plasma's available in Canada so I was planning on selling my LG 42LH90. Is there a used market for the LG and can anyone suggest the best place to advertise it?
gdg is offline
post #4718 of 4735 Old 02-22-2014, 07:48 PM
Latinoheat's Avatar
Quoted: 1157 Post(s)
Liked: 958
Craigslist.
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, HTPC, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC,Klipsch Reference R-62II,Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is offline
post #4719 of 4735 Old 02-22-2014, 07:56 PM
Bond 007's Avatar
Liked: 2108
Let us know if you sell it. I have a 47LH90 thats like new. Been in storage for 3 years and I cant hardly give it away.
Licence to Kill
post #4720 of 4735 Old 06-05-2014, 10:14 PM
p5browne's Avatar
Liked: 2447
New calibration technique re: Calibrating the Service Menu White Balance Gains to give the Normal 2 and 10 Point 100% on Spec. at default values. Improved PQ, and the best I've ever seen on this set. AutoCal on the iScan Duo using Calman 5.3.5 RC2 Build #1570. (New RC3 just became available tonight.)
post #4721 of 4735 Old 06-06-2014, 02:33 AM
Bond 007's Avatar
Liked: 2108
I have no idea what this means. Are you saying you just recalibrated yours with a new machine?
Licence to Kill
post #4722 of 4735 Old 06-06-2014, 08:25 AM
p5browne's Avatar
Liked: 2447
For the last 4 years, after consulting with another member on the Forum, we have basically been trying to come up with the Best calibration possible on first a 42 and 55LH90, then 55LHX. And, that it would last.
We started from sets set at default, calibrated the Brightness and Contrast (which is usually in the 85 and 45 settings area.) Then went into the Service Menu and calibrated the Cool/Medium/Warm White Balances to LG's book spec values. This made it a lot easier to now do the 10 Point in the Normal Mode. But we found the sets somewhat unstable. That's when the other Member mentioned, since we don't use Medium and Cool anyways, why not calibrate all 3 to the Warm Spec. This helped greatly in stabilizing the sets. Until a short time ago, this is what we've done.
But, then along came some Samsung sets: Service Menu White Balance is all in Cool Specs. Realized this after calibrating to Warm spec and bricked the set. Warranty repair done, back up and running. So, leave those White Balances alone! Wife wants to replace a great looking Samsung 32" with the same, except Smart. (Unfortunately not a good PQ as the bumped set.) Only 2 Point available on the 32s. Then it hit me, leave Normal Menu on default Menus, and manipulate the SM WBs to give my Normal 2 Point Menu, on default, the proper Specs. Worked great! Applied same method to the older 32". Work great as well here.
Lets try this on my LG 42LH90, both LG 55LHXs, and on a LG 55LV9500 that I was in the process of selling. Beautiful! Best I've ever seen these sets! Also have now applied to my basement Samsung PN64F8500 - same thing, best results so far.
The only issue we ran into on the older LH90 and LHXs was, the SM WB Offsets, DON'T affect the 30% in either the 2 or 10 Point. So just calibrated the SM WB Offsets to Warm spec to be on the safe side.
From here, Calman was used to finish the calibrations by AutoCalling either iScan Duos, or Radiance Lumagens.
Re the New Smart TV - after 50 hours, set just clicked in, and now has a great PQ as well.
post #4723 of 4735 Old 06-06-2014, 08:33 AM
Bond 007's Avatar
Liked: 2108
I have a 47LH90. Would it be necessary for me to enter the Service Menu for your settings to be helpful to me?
Licence to Kill
post #4724 of 4735 Old 06-06-2014, 08:53 AM
p5browne's Avatar
Liked: 2447
Every set is different. I can give you my settings for B&C, and SM WB but they may not apply to your set.
I showed the 42LH90, that I'd calibrated the old way, a few months back, to my brother-in-law when he was deciding which set he wanted to buy off me.
As a test, showed him the calibrated set I'd done at Night, in the Dark, in the Dark room. Looks great! Turned the lights on, then showed how the room affected the PQ. He couldn't believe the difference! This was done as a warning: yes I'd include a calibration in his purchase price, but, be prepared to see either a positive or negative change when he got it home. He went with the LG 55LV9500 - which, once paid for, him and the girl friend split, and she had to pay him off for his share!
The Service Menu is the key, but you do need calibrating equipment in order to pull this technique off.
As to another tidbit: LG SM WBs are all WAY OFF! Warm which is suppose to be 6500K, is usually 9500K. Medium is up around 11000K, and Cool, up around 13500K . Another reason for calibrating the Service Menu White Balances! When doing Normal 2/10 Point and CMS calibrations, you're having to try and offset the SM WBs being overly exaggerated !
post #4725 of 4735 Old 06-06-2014, 09:15 AM
Bond 007's Avatar
Liked: 2108
Thanks for the info.
I understand every set is different and it depends on the enviro. Just thought I might try yours and see if its better. I can always switch back to what Im using now which looks pretty good. But I dont want to mess with the Service menu. Thanks anyway.
Licence to Kill
post #4726 of 4735 Old 06-07-2014, 06:53 PM
p5browne's Avatar
Liked: 2447
Unfortunately, if you don't get the exaggerated LG Service Menu White Balances under control, then the system is always in a destabilized mode.
Note: White Screen effect, changes between Gamma being on Low, Medium and High, with High having the least White Back ground. Re-calibrated the set with Gamma set to High since I detest White Back grounds! Also deciding between Dynamic being on Low or Off - does give a sharper PQ when on Low.
Will have to do a Black Check this week - it appears some of these adjustments don't directly affect Blacks, but indirectly.
Greyscale and Colours get elevated, but get the exact same reading for Black, the elevated levels make the Blacks appear better.
Recalibrated tonight using 75% Stimulus and 75% Saturation - Turned Dynamic Off and Gamma back to Medium. Much better results. Contrast now at 80, and Brightness stayed at 44.
post #4727 of 4735 Old 08-11-2014, 01:01 PM
r.j.muller's Avatar
I understand I am violating the "NO PRICE" title of this forum, but I have truly spent hours searching to figure out a sales price for my 4 year old 55LH90 with no luck at all. Paid $1,800 new, current model 55" LG LED Smart TV's are about $700. If you can please forgive my scandalous behavior, I would really appreciate the help.
Robert
r.j.muller is offline
post #4728 of 4735 Old 08-11-2014, 01:13 PM
Bond 007's Avatar
Liked: 2108
Robert
I couldnt sell my 47LH90 for $600 3 years ago. $2100 MSRP and its still in mint condition. No one appreciates that its a full array LED tv. Decided to keep it rather than practically give it away.
post #4729 of 4735 Old 08-31-2014, 07:05 PM
p5browne's Avatar
Liked: 2447
I was lucky a few years ago. $1500 to a Female Dentist Client, and $500 for a second to my daughter. (55"ers)
Have been wanting to recalibrate both due to the new Calman 5.3.6b software. Greatly improved the PQ on both my Samsung PN64F8500 and LG 55LHX. Will know more when I redo my wife's bedroom 42LH90 in the next short while.
Re-calibrated using the new Calman Beta 5.4 Build #1632 . Have also taken to bumping the 100% Blue up a couple of clicks to give head room when AutCaling with the iScan Duo. Also adjusted for an Output of 45fL. Much better PQ. Brightness and Contrast, no change.
Just removed the Sony BDP-S770 off the wife's 42LH90 and installed the new Samsung BD-H6500 - WHAT A DIFFERENCE!
The 42LH90 looks Fantastico!
Being replaced with the Samsung UN55HU7250. (Wife wanted bigger and curved.)
post #4730 of 4735 Old 03-29-2015, 02:08 PM
Cravit8's Avatar
Quoted: 1152 Post(s)
Liked: 610
I just bought a 47" set from my neighbor, guess I have some skim reading to do. Any tips or alerts I should know?
Cravit8 is offline
post #4731 of 4735 Old 03-29-2015, 09:25 PM
Bond 007's Avatar
Liked: 2108
There are some good calibration settings for it here at AVS somewhere. I still have my 47 and haven't had any problems. Still gets a great picture.
post #4732 of 4735 Old 03-30-2015, 09:18 AM
Cravit8's Avatar
Liked: 610
Good to know. Hopefully I can actually find them.
I just wanted to make sure there weren't any settings adjustments that cause a bricking of the unit.
PSN: Cravit8
XBL: oOo_Crav_oOo
Cravit8 is offline
post #4733 of 4735 Old 03-30-2015, 09:48 AM
Bond 007's Avatar
Liked: 2108
None that I am aware of.
post #4734 of 4735 Old 08-27-2015, 02:11 PM
d2thez's Avatar
Ive had this TV for a while and my firmware (FW) read out as 3.18.0. Are there any newer versions? I ask because I was having a heckuva lot of lipsync issues over HDMI with my PS4.
d2thez is offline
post #4735 of 4735 Old 08-27-2015, 03:03 PM
Bond 007's Avatar
Liked: 2108
Have you checked the LG website?
Reply LCD Flat Panel Displays
