Vizio GV42L Will Not Power On - Amber Light Only - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-27-2009, 11:18 AM - Thread Starter
adp1207's Avatar
Just over 2 years ago, I purchased a Vizio GV42L HDTV from Costco. Last night (2 weeks after the costco warranty ran out), the unit would not power on and the logo was stuck on an amber light. Totally random, just came home and it wouldn't turn on. The remote will not turn it on either.
I tried to unplug it, bypass my surge protector, and called the useless Costco customer support number to no avail.
I'm thinking it's either the mainboard (~$120 part) or the power board (~$70). Has anyone else had this problem? Or, can i provide any other information to narrow this down?
adp1207 is offline
post #2 of 5 Old 05-27-2009, 01:50 PM
mjones73's Avatar
Try posting this under Display Devices in the sub section for your display type, you'll have better luck there.
Matt
Please don't PM me with technical questions that should be posted in the forum.
mjones73 is offline
post #3 of 5 Old 05-28-2009, 02:18 PM
rjgogo's Avatar
If you bought it with your American Express card you still have another year of warranty.
rjgogo is offline
post #4 of 5 Old 05-29-2009, 09:38 AM - Thread Starter
adp1207's Avatar
Even if I have a 1 year costco warranty? I think AMEX will only cover 1 year after the MANUFACTURER'S warranty, not any additional extended warranty...
adp1207 is offline
post #5 of 5 Old 06-15-2009, 01:43 PM
mrailey's Avatar
I have had the exact same thing happen to my GV42L LCD. I purchased mine from Costco 2 years and two weeks ago from them and the screen turned off while watching a movie while the vizio logo remained on. Neither Costco or Vizio will help because the warranty is over by two weeks.
I took mine to a repair shop where they said the mainboard was bad and would cost $414 to replace the board plus labor. If you have found somewhere to buy a mainboard for $120 I would like to know.
Thanks for any help
mrailey is offline
Reply LCD Flat Panel Displays
