Official Panasonic TC-L37S1 Owner's Thread - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 141 Old 02-01-2010, 08:26 AM
Odysseus18's Avatar
Originally Posted by LeRoyK View Post
I wrote those down on the first page of this thread.
http://www.avsforum.com/avs-vb/showt...5#post16731245
eek For some reason I was thinking they were your modified settings. Thanks!
Odysseus18 is offline
post #122 of 141 Old 02-12-2010, 12:02 AM
frito's Avatar
LeRoyK thanks for posting your calibration settings, i use my 37 S1 as a PC monitor and you settings look great to my eyes with the exception of the b-gain i had to leave that as it was close default in cinema but the r-gain was dead on right for my set at least and it looks excellent to me
for anyone else out there using this set as a monitor to clear up the text issue there are 2 tricks to use. #1 try setting you refresh to 59hz, for some reason it just looks better that way to me and others. #2 make sure sharpness is at 0-10 at most but 0 should be perfect really. #3 this is the big one, the panel these TV's use have a subpixel layout of Blue-Green-Red rather than the more common Red-Green-Blue on most LCD's and you must enable and adjust cleartype in windows so the text is rendered correctly, once done 95% of text you see is no longer blurry and looks great as it should, the remaining 5% of text is due to it being out of windows control of correcting for the subpixel change in the display as in games (hard to notice honestly in games) flash based applications etc.
I've used many LCD TV's as monitors in the past few years and this is by far the best for PC gamers, once adjusted correctly it looks great in windows and it has as close to no lag as possible and no significant pixel blurring while doing so.
to list models i've used with a PC for comparison and their downfalls in doing so
Sony 32XBR6 -
good overall picture, great contrast and black levels text was good on it
bad pixel blurring issue with black to white transitions that left 1/2 second ghost images on screen easily visible on web pages as well as some games, average to bad input lag ranging in the 30-60 ms range at 1080p on hdmi from my tests
Samsung 46B630 AUO panel - not my TV but a good friends TV so i helped him set it up for PC use etc.
Good colors, ok text, good TV to use with a HTPC for viewing video/movies but poor for serious gaming and PC use due to input lag much like the sony in this regard
Toshiba 40xv645u
Great black levels when at centered viewing angle but blacks turned purple really quick at off angles when your too close to the TV. Input lag was good for a VA based 120hz Panel 20-30ms when in game modes but this came at a cost of having poor pixel response time with slight changes in brightness of a picture most notably with dark images over an even darker background like dark grey over black for example would result in easily visible smearing. Text reproduction in windows was excellent, better than even the 37S1 with tweaks. another cost of game mode on this set was poor color range. color gradient scale tests showed tons of banding, much more than a TN monitor, out of game modes this almost went away and with slight tweaking of the color controls via colormaster in the menu's i was able to remove the remaining banding on this TV so its fine out of game mode once tweaked but colors in game mode are definitely compromised making it a poor choice for dedicated PC monitor use. that being said i still kept this TV to use in our living room as a TV because it is a perfect set for those looking for a TV that does TV and blu ray very well with a good 120hz that works well without too much SOE and has the bonus of being a good gaming TV when you need it to be even though you are sacrificing picture quality setting into that mode its always nice to at least have the option
If you're a gamer or interested in using an LCD TV as a primary monitor take a look at my thread on Input Lag
frito is offline
post #123 of 141 Old 02-12-2010, 12:39 AM
frito's Avatar
Ohh yeah i almost forgot to mention for those that are curious
1080p/24 appears to set a special mode on the 37S1 that works better than my 60hz 32XBR6 for displaying movies at their true judder free frame rate and in doing so also disables motion focus because its scan speed is made for 60hz not 48hz or 72hz, i'm not sure what update rate the TV switches to when given this signal but judging by my sony 32xbr6's obvious frame flicker inducing 48hz mode i would have to guess that the S1's are switching to 72hz because the edge flicker is much less apparent on this TV
frito is offline
post #124 of 141 Old 02-17-2010, 02:28 PM
Will Binegar's Avatar
Quoted: 12 Post(s)
Liked: 25
Thanks for sharing the info!
Will Binegar is offline
post #125 of 141 Old 02-17-2010, 03:02 PM
hidefLoans's Avatar
Frito, can you take a quick macro shot of your pixels with some thin black text on it to confirm the pixels are BGR and not RGB. (My camera sucks)
I don't notice any sharper text on my 32s1 by switching to cleartype BGR instead of RGB. It actually seems a little more artifcaty. My sharpness is set to 7, so thats not adding artifacts.
hidefLoans is offline
post #126 of 141 Old 02-18-2010, 01:02 AM
frito's Avatar
I would if i had a camera with a lens good enough to do it, i came across it somewhere saying it was BGR but i'm not sure now because someone else posted a macro shot of their IPS-Alpha panasonic and unless they changed something with these panels or his photo is not what he says it is it showed RGB pixels
either way running the clear type tuner appeared to fix the majority of my text sharpness issues
his post is here
http://www.avsforum.com/avs-vb/showt...3#post18147023
here's the photo
definitely looks like an IPS-Pro panel too so i guess i had the wrong idea for some reason
and yeah its RGB for sure
http://www.lagom.nl/lcd-test/subpixel.php
that test shows more or less that my 37S1 is RGB, what it appears to be to me is the colored text issue and somewhat blurry normal text is a direct result of these displays video filtering circuit. it appears that red and blue get blurred often into adjacent pixels while green for whatever reason does not, oh well no TV makes a perfect monitor but mine still looks good enough to me 95% of the time so i can live with it
frito is offline
post #127 of 141 Old 02-18-2010, 01:04 AM
frito's Avatar
Originally Posted by Smoof15 View Post
Second pass at my TC-L37S1 using an i1 Display LT with ColorHCFR.
SM Offsets - Warm
(Before) After
RG (FF) F5 ... -10
GG (E4) E4
BG (BB) C1 ... +08
RC (84) 84
GC (80) 80
BC (7E) 69 ... -21
Cinema Mode
Backlight 35
Contrast 85
Brightness 65
Color 50
Tint +4
Sharpness 30
Color temp. Warm
Color mgmt. Off
x.v.Color Auto
A.I. picture Off
Video NR Off
MPEG NR Off
Motion Focus On
Black level Light
HD Size 2
ColorHCFR Graphs
Thanks love your settings, i had my colors jacked up from trying someone else's setting and then playing around with the white balance in my sm too much but yours has got mine back to looking great overall
only differience is i raised the BL up to 45 and sharpness is at 0
this is for PC monitor use though and sharpness 0 is optimal in that use because anything more adds edge enhancement
frito is offline
post #128 of 141 Old 02-18-2010, 10:20 AM
Quoted: 12 Post(s)
Liked: 25
Would these settings be a good place to start with the G1?
post #129 of 141 Old 02-20-2010, 12:57 AM
frito's Avatar
sure give it a try but it may not look quite right, use your eyes and some test patterns for best results because it may vary but the panel used in the 37G1 is the same as the 37S1
I would not use those settings on anything other than an panasonic lcd s1.
the 37G1 is nearly identical to the 37S1 all it adds is 120hz + motion picture plus 3, the panel used is the same so picture settings for both are likely to be similar but you never know unless you try
frito is offline
post #130 of 141 Old 03-09-2010, 01:56 PM
kocoman's Avatar
Mines was a demo unit and it had a white scratch on the lcd horizontally, is there any way to fix it? I tried vaseline and eraser but it does not magically get rid of it... it does make it appear less when you see it on the sides, but when facing straight you can still see it from 12 inch..
kocoman is offline
post #131 of 141 Old 03-09-2010, 03:35 PM
frito's Avatar
pretty unlikely you will fix a scratch on the screen, be careful what you try to use you can easily damage it more than it already is
If you cannot see it real well at normal viewing distance i would try to forget about it
frito is offline
post #132 of 141 Old 03-16-2010, 09:08 PM
bshor's Avatar
Has anybody tried programming their Harmony remote for this TV? It's in the database, which is good, but the inputs are all screwed up. There's only 3 inputs, when there should be 7 or so. Don't understand how to fix it.
bshor is offline
post #133 of 141 Old 03-17-2010, 05:26 PM
IanD's Avatar
Quoted: 82 Post(s)
Liked: 50
I recently purchased the LA37S10A (Australian version of the 37S1), after reading the relatively glowing reports of this thread, but have discovered it is different.
1. Blacks go blue/purple and pastel with only small off-axis shifts.
2. Vertical streaks, mostly apparent with off-axis viewing.
3. There is no Backlight control, only Brightness and Contrast.
4. Seems to be no A.I. control, only Colour Management On/Off.
5. No HD 1/2 aspect ratio control, only Overscan On/Off.
6. Some settings go -xx to +xx, not 0 to 100.
7. 24p input is juddery with some vertical flicker.
8. No Motion Focus control.
I can dial in a fairly accurate picture with the standard user controls (apart from the black level) but overall results are unsatisfactory and I will be returning this TV.
Just goes to show you can't trust reviews from a different region to match your own experience, even when the models should be similar.
IanD is offline
post #134 of 141 Old 03-17-2010, 05:37 PM
Mark_Likes_Games's Avatar
Quoted: 31 Post(s)
Bummer - sounds like it's a different set really... You couldn't tell from the specs?
How DARE you question my ignorance!?!
Mark_Likes_Games is offline
post #135 of 141 Old 03-17-2010, 05:48 PM
Gary J's Avatar
Quoted: 405 Post(s)
Liked: 213
So you are talking about a PAL version rather than NTSC correct?
Gary J is offline
post #136 of 141 Old 03-17-2010, 11:08 PM
IanD's Avatar
Quoted: 82 Post(s)
Liked: 50
The LA37S10A handles PAL, NTSC and HD 24p.
There is very little difference in the specifications between the S10A, G10A and V10A models apart from 100Hz and 24p Motion Flow on the G and V: the S10A is still supposed to do 24p at 96Hz.
Unfortunately the specifications don't go to the level of mentioning whether there is backlight control, Motion Focus, etc.
I feel short-changed as I was expecting similar features to the S1 model, but I guess they gave us PAL capability instead and dropped a few other advanced features.
I'm debating whether to see if I can adjust backlight in the service menu, but reluctant if I intend to return the TV for a refund.
IanD is offline
post #137 of 141 Old 03-17-2010, 11:42 PM
frito's Avatar
well of all your complaints on your Austrailan version of the 37S1 the only one i will admit to being true is
blacks are well known to be not great on these TV's and its due to the IPS panel used in them, they do turn a slight blue color with off axis viewing angles on my 37S1, something that will happen with any LCD from my experience though so if your wanting this to not happen the only option is a Plasma or CRT display
otherwise yeah you guys got short changed by Panasonic for sure on the rest
frito is offline
post #138 of 141 Old 03-18-2010, 05:42 AM
Gary J's Avatar
Quoted: 405 Post(s)
Liked: 213
Perhaps you could have expected differences since this thread says specifically Official Panasonic TC-L37S1 Owner's Thread.
Gary J is offline
post #139 of 141 Old 06-23-2010, 03:16 AM
kocoman's Avatar
Is it possible to convert this into a AVCHD unit? also is it possible for it to accept a PAL video signal?
kocoman is offline
post #140 of 141 Old 07-24-2010, 05:50 PM
StickFigs's Avatar
Is it possible to reduce the overscan with a 720p signal through component or HDMI using the service menu?
StickFigs is offline
post #141 of 141 Old 01-24-2011, 03:17 AM
jice's Avatar
Anyone have experience with the Viera Link function?
For one year, I had only a Panasonic BD-60 player connected via HDMI. The Viera Link function worked as expected.
Now, I have a second device (a non-Panasonic DVD player) connected via HDMI as well. When this device is connected, Viera Link no longer functions.
Expected?
I currently have the non-Panasonic player in HDMI 1 and the BD60 in HDMI 2.
jice is offline
Reply LCD Flat Panel Displays
