How to remove dancing mute icon from Samsung LCD TV? - AVS | Home Theater Discussions And Reviews
post #1 of 11 Old 07-19-2009, 11:06 AM - Thread Starter
soupcxan's Avatar
I just bought a Samsung LN52B630 and it's great, except when you mute it a large mute icon shows up on the screen. I don't mind the icon, but it moves around every few seconds and the movement is what I find distracting. Is there any way to disable the movement or the icon altogether? Maybe in a service menu somewhere?
I searched the forum and found similar complaints about this icon but not the instructions on how to remove it. Obviously you can avoid this problem by turning the volume down to zero but that's a hassle, I would rather be able to use the mute button.
soupcxan is online now
post #2 of 11 Old 08-15-2009, 10:34 AM
aeroguy's Avatar
Quoted: 12 Post(s)
I've been searching for this too but haven't found anything. I would like to remove it so I can use a logitech harmony activity based remote to mute the TV volume when watching a movie instead of having to turn it down.
aeroguy is offline
post #3 of 11 Old 08-15-2009, 12:01 PM
thecrazykevy's Avatar
It doesn't say anything about it in the instruction manual so I don't think you can. Not without going into the service menu anyway.
thecrazykevy is offline
post #4 of 11 Old 08-15-2009, 12:41 PM
felonyr301's Avatar
Nope you can't either turn off the speakers in the sound menu of the TV or put the volume down to 0. It's just faster to turn off the speaker from the sound menu then to put the volume down to 0 since I be having it at like 40 lol.
Xbox Live Gamertag: FELONY 301
PSN ID: FELONY--301
No problem adding people...
felonyr301 is offline
post #5 of 11 Old 08-15-2009, 04:38 PM
blackssr's Avatar
Quoted: 299 Post(s)
Liked: 93
Why would you stare at the TV with no sound anyway?
I've paid for my sins. We're even!
blackssr is offline
post #6 of 11 Old 08-16-2009, 09:04 AM
aeroguy's Avatar
Quoted: 12 Post(s)
Because you have your TV connected to a receiver and you want to watch a movie in surround sound.
aeroguy is offline
post #7 of 11 Old 08-16-2009, 09:17 AM
mes444's Avatar
If you want to watch a movie and disable the sound, go to the tv's main menu, audio, and turn the sound off. No dancing mute.
mes444 is offline
post #8 of 11 Old 08-16-2009, 12:11 PM
You should really just disable the tv speakers from the menu if you aren't going to use them.
post #9 of 11 Old 08-16-2009, 07:15 PM
aeroguy's Avatar
Quoted: 12 Post(s)
Good suggestion. That might be easy enough to plug into a logitech harmony remote.
aeroguy is offline
post #10 of 11 Old 11-25-2013, 04:43 PM
avspeace's Avatar
I just got the same TV today and have the same issue. I would really like help in the area if anyone knows.
For me, sometimes because of my health condition I need to mute the TV and rely on close captioning. Or sometimes I use the TV for light. As well if I do not fast forward commercials then I mute them. You also do not have to stare at it to see it.
avspeace is offline
post #11 of 11 Old 12-13-2013, 02:59 PM
SuePebbles's Avatar
[. We just turned the tv sound to 0. Took us about 1 hour to come up with this
Hope it helps. Why the wanted to put a danceing icon on the screen I'd beyond me
SuePebbles is offline
Reply LCD Flat Panel Displays
