Westy LVM-37W1 Problem. Need suggestions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-03-2009, 12:38 PM - Thread Starter
BKM72's Avatar
The TV stopped turning on after only 4 years. Not under warranty anymore.
Researched and found the problem is usually the power supply ($178.00), or it could be the control board. I've also read where some have said its usually just 2 capacitors that go bad (about $1.50/ea.) Problem is, which 2?
I've got the back of the TV off and removed the protective cover to the PS. Only 4 screw and 4 plugs to swap it out....seriously easy.
I'm just worried about spending $180.00 and it doesn't fix it.
Anyone else had this issue? How did you fix it?
I hate to junk a $1200 TV after only 4 years, but dont want to blow my money on unnecessary parts either.
Any guidance?
BKM72 is offline
post #2 of 3 Old 09-03-2009, 01:59 PM - Thread Starter
BKM72's Avatar
Well, I called the guys at Discount-merchant.com, described the problem, and it sounds like it definitely the PS.
I just ordered one and will install it when it get here.
If it corrects the problem, I can do a DIY write up if anyone is interested.
I've seen where others have had the same problem, so maybe I can help other owners out.
Let me know.
BKM72 is offline
post #3 of 3 Old 08-25-2012, 06:34 PM
mntmst's Avatar
A note to help someone who still has one of these.
My old LVM-37w1 finally started to power off (no picture) after running for a while and then it just quit with nothing but the orange led one day. The problem with mine was on the power supply. A bad solder joint in the switching power driver section of the board on a capacitor lead.
http://flic.kr/p/cYCEFy
http://flic.kr/p/cYCECN
If you have one sitting in a closet with this problem this might be a easy fix.
Combat Xerox Repairman
I make magic smoke.
Need this for HT
mntmst is offline
Reply LCD Flat Panel Displays
