LNT4069F takes 30min to startup HELP! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 09-19-2009, 04:44 PM - Thread Starter
mlong68's Avatar
Hi All,
Just received a call from my parents indicating that their Samsung LN-T4069F takes about 30 minutes before it will startup and play. During this 30min outage they hear a clicking sound, and noticed the blue light comes on and off, but the color isn't as strong or bright as normal.
They also noticed that it will take longer for the TV to startup, if they leave it off over night. During the day, after the TV has warmed up, they can cut it off, and back on with out an issue.
Any ideas what maybe causing this problem? They had this TV for about 2years now without any issues.
mlong68 is offline
post #2 of 12 Old 09-19-2009, 05:13 PM
cnjax's Avatar
Quoted: 21 Post(s)
Originally Posted by mlong68 View Post
Hi All,
The power supply module in the TV is going bad, pretty soon the tv will no longer power up, happened to me on my 4671. Apparently a service tech posted an article stating this is a wide spread problem because Samsung is using crappy components.
LG 55EF9500
Samsung LN46B750
Oppo UDP 203
Oppo BD103
Denon AVR-x3200w
cnjax is offline
post #3 of 12 Old 09-19-2009, 05:23 PM - Thread Starter
mlong68's Avatar
Is this covered by warranty, or is it possible if I can order the part, and do the repair myself?
mlong68 is offline
post #4 of 12 Old 09-20-2009, 08:09 AM
hammerdwn's Avatar
Quoted: 173 Post(s)
Liked: 57
It is under warranty if the Tv was purchased within one year, and if you register online you can get another three months. If not you can certainly diy. You can either solder a few new capacitors onto the board for less than $10, or you just replace the whole board for $75.
XBR-65Z9D | AVR-X2200W | UBD-K8500 | JRMC HTPC w/9 cable tuners | Fluance SV 7.1 + eD A3-300
hammerdwn is offline
post #5 of 12 Old 09-20-2009, 08:45 AM - Thread Starter
mlong68's Avatar
Where can I get the part, and instruction on how to install?
mlong68 is offline
post #6 of 12 Old 09-20-2009, 12:58 PM
hammerdwn's Avatar
Quoted: 173 Post(s)
Liked: 57
$75
If you can put a video card into a PC, you can change the power supply board. Just handle the board by the edges so you don't get electric shocked from stored voltages (especially transformers and large capacitors).
post #7 of 12 Old 09-20-2009, 08:31 PM - Thread Starter
mlong68's Avatar
$75
Again, where can I purchase the board? The cheapest I find is for $179.00
mlong68 is offline
post #8 of 12 Old 09-20-2009, 09:05 PM
Benny42's Avatar
Dude, you have to click the price $75 !
bye
Benny
bye
Benny
Benny42 is offline
post #9 of 12 Old 09-21-2009, 12:05 AM
MrEastSide's Avatar
Quoted: 25 Post(s)
Liked: 55
Definitely power supply. Should be pretty easy fix.
Of course, I got it modified with the TK-427, which cheeks it up another, maybe, 3 or 4 quads per channel.
MrEastSide is offline
post #10 of 12 Old 09-22-2009, 06:36 AM - Thread Starter
mlong68's Avatar
Thanks all,
I was able to repair the 4 capacitors in about 5min. We are back up and running now.
mlong68 is offline
post #11 of 12 Old 07-22-2012, 01:02 PM - Thread Starter
mlong68's Avatar
Having double images with this set now. Can anyone confirm if this is a blown capacitor?
http://www.lwintegrationtest.com/tmp/blown_capacitor.jpg
mlong68 is offline
post #12 of 12 Old 07-22-2012, 04:50 PM
dfp
dfp's Avatar
Call Samsung. Here is a link to their program to fix long startup times and related problems:
http://www.samsung.com/us/capacitorsettlement/
edit: Oops, didn't see the original date. Well, maybe others seeing this thread can benefit from the Settlement notice.
dfp is offline
Reply LCD Flat Panel Displays
