HELP!!! Need a Sony KDL-52W4100 T-con board - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-11-2009, 08:38 PM - Thread Starter
Ranger 518's Avatar
My Sony KDL-52W4100 has toasted a T-con board just a few months out of warranty. I can live being stuck with the bill but Sony has been backordered on these things for almost a month now. Anyone got a lead on one? I have no idea what will cross fit in Sony's line. Getting tired of watching a 32 inch Vizio.
Ranger 518 is offline
post #2 of 5 Old 10-11-2009, 11:31 PM
Extreme_Boky's Avatar
I assume you want to replace the board yourself...???
If YES, remove the back plastic cover and find the pixel driver board (T-con) MODEL number (which may be followed with hardware / software revision numbers as well...)
Use them to search the web.... you'll find something....
Boky
Extreme_Boky is offline
post #3 of 5 Old 10-12-2009, 04:02 PM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
Control MT board depends on serial number (US Models only):
8,000,001 - 8,100,000 pn#1-857-132-11 $630
9,000,001 - 9,100,000 pn#1-857-132-11
8,100,001 - 8,300,000 pn#1-857-240-11 $490
9,100,001 - 9,500,000 pn#1-857-240-11
XBR-65Z9D | AVR-X2200W | UBD-K8500 | JRMC HTPC w/9 cable tuners | Fluance SV 7.1 + eD A3-300
hammerdwn is offline
post #4 of 5 Old 10-24-2009, 03:39 PM
icethepenguin's Avatar
Try shopjimmy.com I got my replacement power supply and TCon board there and just to refurbish the computer I got the main board and now my LCD TV works like I just took it out of the package, crystal clear screen, bright new picture. And i got each for under $80.00 each.
icethepenguin is offline
post #5 of 5 Old 05-14-2012, 07:31 PM
laxman1100's Avatar
I'm in the same boat. Vertical lines on the screen. My serial number is: 9125012 which should be this board: 1-857-240-11.
Where is the best place to buy one?
laxman1100 is offline
Reply LCD Flat Panel Displays
