TV above fireplace mounting dilemma - need a TV mount that does.... - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 93 Old 01-28-2014, 10:00 AM
Mariea's Avatar
We have the mantle mount up and is holding a 60" LCD  I like it alot.  We haven't had to lower it but it lowers very easily and raises up equally as easy.  This mount is definetely a good deal.  Other mounts out there that lower as this one does are considerbly more expensive.  WE love ours,it was not hard to install at all.  I attached a pic of our finished fireplace -- that wall started out as a plain drywall wall leading to garage in our basement.  I think it turned out well for a couple who never laid a stone in their lives  HAH
Mariea
Fireplace1.jpg 34k .jpg file
Mariea is offline
post #62 of 93 Old 01-30-2014, 06:19 AM
BrutalBodyShots's Avatar
Quoted: 353 Post(s)
Liked: 85
I feel the mantle mount is a great product. I've raised/lowered mine probably 15 times in the past 2 months and it works great. I've got a 70" Sharp which weighs about 90 pounds and the mount handles it fine.
BrutalBodyShots is offline
post #63 of 93 Old 03-31-2014, 07:04 AM
R0tten's Avatar
I'm wondering if the mantlemount wall mount lowers further orrrr is it about that same as the down and out wall mount?
R0tten is offline
post #64 of 93 Old 03-31-2014, 03:17 PM
Quoted: 353 Post(s)
Liked: 85
Not really sure. The mantlemount lowers about 25-27" though.
post #65 of 93 Old 04-22-2014, 08:51 AM
kingmatt's Avatar
I've been meaning to post an update forever... all in all, I love the Mantle Mount. Very solid piece of hardware and it provides a nice clean look.
The only drawbacks I've found:
1) our electrical plug was in the way. The way the mount is designed the middle portion of your wall has to have 6.5" wide available. Our plug happened to be there... we moved it one stud over and all was well.
2) our TV's plug was also in the way. This was a bigger issue... the lowest horizontal piece of the mount (on the TV side) has to be centered in order for the TV to self balance. Unfortunately our LG's power plug sits exactly where this bar needs to go. Tried a few different things and eventually borrowed a buddy's dremel. Made some sparks, cut off part of this bar and voila, all good.
All in all this mount is well worth the $200. It still baffles me that there aren't more online reviews available but hopefully this one helps people out in future...
kingmatt is offline
post #66 of 93 Old 04-26-2014, 11:09 AM
Quoted: 353 Post(s)
Liked: 85
It looks like the Mantlemount has been sold out for about 4 months now. Not sure what the issue is there with production. On the front page of the web site is the same message they posted in late December; it has not been updated.
post #67 of 93 Old 05-27-2014, 03:06 PM
jdubs101's Avatar
Question for anyone with a Mantlemount. I just installed mine and I love it however I cannot get the tilt function to work. It seems to be permanently tilted forward which is a problem as I want to rest my center speaker on top of the tv and need the TV to be straight or it will fall off. Are there some screws or knobs I need to twist in order to get the tilt functionality to work?
jdubs101 is offline
post #68 of 93 Old 05-27-2014, 05:53 PM
Quoted: 353 Post(s)
Liked: 85
As far as I know the tilt wasn't adjustable; I think it was an 8 degree or so tilt in the "up" position no matter what. I'm pretty sure you can't eliminate the tilt feature which unfortunately for your situation creates a problem.
Resting the center speaker on top of the TV seems a bit of hassle though, no? Then you'd have to take it down every time you lower the TV or it would likely fall off? How big is your center channel/how much does it weigh? If it's not a monster you could always run a strip of velcro the full length of your speaker on top of the TV. You'd never see the velcro, but it would probably be more than strong enough to keep your speaker in place at the 8 degree angle.
post #69 of 93 Old 07-03-2014, 02:01 PM
fastsvo's Avatar
Quoted: 31 Post(s)
bump!
In the same situation now...
fastsvo is offline
post #70 of 93 Old 07-13-2014, 08:51 AM
LSUfaramir's Avatar
Do you mind telling us how you were able to get the mantel mount? The website still shows sold out and the phone number doesn't work?
LSUfaramir is offline
post #71 of 93 Old 07-25-2014, 07:08 AM
jdubs101's Avatar
Sorry for the late reply, I actually purchased my mount in December of 2013 before the stock ran out, I have nothing but great things to say about it, now that I've been using it for some time.
jdubs101 is offline
post #72 of 93 Old 07-25-2014, 07:10 AM
jdubs101's Avatar
Also I used the velcro solution. I just made sure I had enough slack with my speaker wire so I can raise and lower the mount without removing the speaker. No problems yet.
jdubs101 is offline
post #73 of 93 Old 07-25-2014, 02:30 PM
jbchi's Avatar
How big of a TV do you have attached to it, and how many studs is it anchored to? I have a 65" 60lbs TV on the way and putting it on an articulated mounts sounds good, but also a bit scary.
jbchi is offline
post #74 of 93 Old 07-27-2014, 07:32 AM
bman3241's Avatar
I have a similar issue as my fireplace takes up 85% of the main wall to put my Pioneer PRO-111 (74 lbs), from the forum it looks like I have the following options:
Mantle Mount - Currently out of stock and has a permanent tilt to it
Comfort Vu - Motorized mount that will likely be more expensive than other options
Down and Out Mount - expensive but might be the best option
Has anyone else found other options that I can add to my list?
Bob
bman3241 is offline
post #75 of 93 Old 07-30-2014, 12:18 PM
[DT]'s Avatar
FYI, MantleMount products will be available very soon. I’ve gotten a couple of email blasts about availability recently and they’re indicating a date of Aug 18th for some initial shipments.
I did a quick search and found this to be the most active and recent thread with MantleMount being discussed, so figured I’d just drop this info here.
"In the end, life and business are about human connections. And computers are about trying to murder you in a lake. And to me, the choice is easy."
~Michael Scott
[DT] is offline
post #76 of 93 Old 08-18-2014, 08:03 PM
Liked: 0
Hey guys, I hail from Singapore and am new to this forum. I came across Mantle mount in Kickstarter, and this was a campaign that was just launched! As I am also interested in a vertically adjustable tv mount, was sniffing around the web for some other alternatives before I found you guys.
Yall may want to check them out at the link below, seeing how you still have interest in their product.
https://www.kickstarter.com/projects...unt-is-for-you
p/s: I can't see the Sears link that was posted, were they going for cheaper before? They are selling for about 199-299, depending on when you get them.
LittleJim is offline
post #77 of 93 Old 08-19-2014, 12:51 AM
Liked: 0
Originally Posted by David_M_Clary View Post
Well, the previous illustration I included was the TV mount in the up position. Here is a photo of my first protype in the down position. Slightly different design but basically the same.
Wow thi sis amazing. I really liked the idea.
waltermoss123 is offline
post #78 of 93 Old 10-18-2014, 10:43 AM
SwedishPimple's Avatar
Great thread. We were thinking about lowering our fireplace mantel, but may not have to with some of these options. For those of you with MantelMount, ComfortVu or Dynamic Mounting, how high is your mantel?
I'm trying to figure out what should be maximum mantel height for one of these products. For reference, maximum viewing distance is only 10' (would lose ~2' when mount lowered).
TIA
SwedishPimple is offline
post #79 of 93 Old 03-07-2016, 02:11 PM
pixelation's Avatar
I want to mount my TV on my fireplace. My fireplace currently looks like image attached.
I want to remove the mantel shelf and simply hang the TV on top, partially covering the bricks. I also plan on getting a cabinet like this to put in front of the fireplace:
http://www.ikea.com/us/en/catalog/products/S29083132/
But I don't feel like spending $400 on a mantel mount. Do I really need it or a simpler, swivel mount will do? With the mantel shelf removed, the fireplace is about 4" from the wall surface.
e.g.
http://www.amazon.com/dp/B00QOPG5MC
pixelation is offline
post #80 of 93 Old 03-07-2016, 03:23 PM
Jasonn B's Avatar
Quoted: 313 Post(s)
Liked: 121
Forget the swivel mount. Not needed, and sticks way far out from wall. Just a mount you can tilt down. That's going to look great!
80" Vizio LED - (60" Vizio plasma - retired)
Harmony 890 Remote
X10 Commander Iphone App = full control of lights, fireplace, pool, shades, from Iphone
X10 IR543 controller
Hunter Douglas motorized shades
Jasonn B is offline
post #81 of 93 Old 03-07-2016, 05:22 PM
pixelation's Avatar
No offense but it is not what I wanted. I want to watch TV without stressing my neck.
post #82 of 93 Old 04-25-2016, 07:07 PM
Timobkg's Avatar
Quoted: 23 Post(s)
I didn't feel like spending the money on the Mantel Mount either, but I am so glad I did (and so are my family's necks). With a tilt mount, you're still craning your head to look up. Lowering is the only comfortable solution, and with a 4" mantel you'll be able to drop it down by 2' or so. I'd recommend getting the Mantel Mount, it's absolutely worth every dollar, no regrets.
Timobkg is offline
post #83 of 93 Old 06-23-2016, 07:47 AM
Liked: 0
I felt your pain about 6 years ago when I got my first 42" plasma TV. Since then I designed and built 2 working prototypes of a wall mount to solve this exact problem. The later is currently in use on my wall over a ~64" tall mantle. It rotates out and down in front of the fireplace. The mount is only 3" deep when up and closed, mounts flush to the wall and fully hides behind the TV when the TV is up. It uses pneumatic springs to offset the weight of the TV, 80 lbs in my home application. I am nearly two years into a patent application process and still haven't heard from a patent examiner(backlogged). I can't get any real interest from the major mount manufacturers, which is very frustrating considering the obvious need for such a product. I see posts like yours all the time and design show after design show where they mount TVs over fireplaces at unreasonable heights. If there are more of you out there then please let me know.
If you want to see my design you can find it on the uspto site under description "Wall Affixed Vertically Articulated Flat Panel Display Mount". I would also love feedback on the design. The patent pending design has an option for automatic lifting/lowering with an additional linear actuator.
Anyone know if David ever came out with his product or if there is a way to contact him to purchase one directly? I've looked at other options out there but they are all over 4.5" deep and I need one that is 3.5" or less, making David's the only one I've found that would work for my very specific needs.
dambo29 is offline
post #84 of 93 Old 06-23-2016, 08:15 AM
Liked: 0
Ditto, anyone wanna build this for me?
dambo29 is offline
post #85 of 93 Old 06-23-2016, 11:30 AM
pbc
pbc's Avatar
Quoted: 374 Post(s)
Liked: 208
That mantle mount product looks quite interesting. Expensive though for what may be an unproven product over time (especially if over time the ability to move it up/down on the hydraulic arms ceases).
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #86 of 93 Old 11-23-2016, 09:29 AM
Liked: 0
Dynamic mounting vs Mantlemount
I tried to find a good comparison between the Mantlemount and Dynamic mounting. I liked the price of the Mantlemount and the handles but in the end I opted for the Dynamic mount to provide better customization. I get 29" of travel and in the up position the TV is out 5" from the wall and 7" at the top with the small amount of tilt I have it set with. The Mantlemount has fixed tilt at 7 degrees and less overall travel.
I have a wood burning stove and wanted it to not stick out too far (in the path of the blower's air) and this worked well. I ended up purchasing a temperature alarm that sits on the back of the TV (magnetic) and lets me know if it gets too hot.
It wasn't cheap but I have no regrets with the mount.
I also purchased the dynamic mounts speaker attachment. I read it's kind of like an erector set and it certainly is. For the center channel I was trying to mount it just wouldn't work so I created my own mount which works great and I'll just return their speaker mount.
Photos are at icloud.com/sharedalbum/#B0NG4TcsmG3Prhd
John Sharp is offline
post #87 of 93 Old 01-07-2017, 12:33 AM
Liked: 0
I ordered my Mantle Mount on Amazon to be delivered tomorrow. Any tips on what equipment I need to mount it to a brick wall? Their website just says to use some concrete anchors but no specifics (eg. size, length) vs. a sleeve? Also will need to pre-drill a hole in the brick so will need to get a masonry drill bit but what size bit and how deep? I'm very worried of drilling too deep and penetrating the chimney flue which I'm guessing would make my fireplace unusable ever again. I've never done this before (although I did mount my own TV on drywall in another room) so just want to hear from anyone else's experience going through this.
jabronee is offline
post #88 of 93 Old 01-07-2017, 11:46 AM
Jasonn B's Avatar
Quoted: 313 Post(s)
Liked: 121
Lag bolts.
Harmony 890 Remote
Jasonn B is offline
post #89 of 93 Old 03-06-2017, 07:19 AM
Quoted: 45 Post(s)
Anybody using the Monoprice Fireplace Mount? https://www.monoprice.com/Product?p_...FQsQgQod6nIB5Q I've got a 66 lb. TV mounted, and even with the tension dialed in, it is a bear to push back up.
misterhanky is offline
post #90 of 93 Old 03-28-2017, 07:05 AM
amatuerholic's Avatar
Quoted: 524 Post(s)
Liked: 287
I was reading about this as well; see the last post on this thread:
https://slickdeals.net/f/9538732-abo...=4#commentsBox
amatuerholic is offline
Reply LCD Flat Panel Displays
Tv Above Fireplace , Lg 55lh90 55 Inch 1080p 240 Hz Led Backlit Lcd Hdtv Glossy Black Infused Blue , Lcd Hdtv
