THE Official LG "55LHX" Owners Thread - Page 104 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #3091 of 3105 Old 09-19-2015, 01:17 AM
andy582's Avatar
Quoted: 46 Post(s)
Liked: 26
Originally Posted by BillyVegas View Post
What settings are you using? Im working on dialing mine in... nothing solid yet.
I'll try to post later.. A lot of the difference was just in taking the media box out of the equation. And I tried what someone else suggested, to put the brightness low and the backlight high (they might be at 30 and 70-ish for me). Blacks are much much deeper, though the image gets a little dark. Colors still a little off. But I had an overly bright, fuzzy image before, and now it feels dialed much closer to where it should be, with more sharpness and contrast..
Mostly I'm just a convert to tinkering with picture settings.. Someday maybe someone can explain why TVs come with so many options, bad pre-sets, and just enough rope for users to hang themselves..
andy582 is offline
post #3092 of 3105 Old 11-10-2015, 09:10 AM
Scot Kight's Avatar
Quoted: 39 Post(s)
Fan noise
Anyone have any ideas for a silent fan replacement on an LHX? Mine has decided to get louder over the years, even though it was cleaned out. It isn't quite objectionable yet, but it is obvious when the set is running.
Scot Kight
"Don't touch that, this isn't your house and that isn't your tv!" she says.
"But look at it, the contrast is completely blown out, the color is all off and that tint. This will only take a sec..."
Scot Kight is offline
post #3093 of 3105 Old 12-04-2015, 06:40 AM
andy582's Avatar
Quoted: 46 Post(s)
Liked: 26
Thinking about whether to pick up a new short-term TV, probably a Vizio E-Series, to tide me over until OLED/HDR sets come down in price. Given this TV is five years old, but also FALD and a higher-end model, would a 2015 E-Series (1080p) actually be much of an upgrade over this set?
andy582 is offline
post #3094 of 3105 Old 01-27-2016, 07:44 AM
aviator79's Avatar
I have been trying to update my TVs firmware and seems that my USB input must be shot as I get the update screen and it shows no files. I have tried two USB sticks. I know files are good as I have sent them to others on here and they used them. Oh well I guess...not sure what else to do.
aviator79 is offline
post #3095 of 3105 Old 01-27-2016, 11:59 AM
aviator79's Avatar
Finally got it.
post #3096 of 3105 Old 05-31-2016, 10:10 AM
Liked: 0
55lhx not working
only the power light comes on. must be the power supply or the main board, right?
where do it get replacement boards? should I consider used?
I do not use the media box.
thanks for any help,
greg
gregdilger is offline
post #3097 of 3105 Old 06-03-2016, 09:20 AM
p5browne's Avatar
Quoted: 3134 Post(s)
Liked: 2448
greg
http://www.shopjimmy.com/catalogsear...?q=eay58476101
Have bought 2 of these from these people. Keep one as a spare. Gifted the other.
What you may want to try first is, the take the back cover off, check all the connections to the board are tight.
We also found, the screws holding the power supply board to chassis were very loose. You may just have to tighten these to get the grounds back.
UN65HU9000 with SEK-3500U in UJS9000 Mod Mode. SDR Input at 1080P 60HZ 444. 4K separate HDMI input - Mine
UN75JU7100 / UN55HU7250 with SEK-3500U in UJS9000 Mod Mode / UN32EH5300 (On floor and up for sale) / 2 X LG 55LHXs / New addition UN40J5200AF - Wife's
PN64F8500 still up for sale
p5browne is online now
post #3098 of 3105 Old 06-03-2016, 11:40 AM
Liked: 0
I did check for tightness of the board per your previous post. nothing was loose.
is it very likely that it is the power supply board vs the main board?
shopjimmys has a used power supply board but no main board. I am not much of a trouble shooter. the power supply board did show the varies low voltage output pins as ok (ie the 5v and 12v and 24 v were as marked)
thanks, greg
post #3099 of 3105 Old 06-03-2016, 12:27 PM
p5browne's Avatar
Liked: 2448
thanks, greg
The 2 boards I got were also used, but certified good with 180 day guarantee. So originally swapped out mine to test. Didn't bother re-swapping, but then wife's LHX starting showing the signs you say were happening to yours, so swapped mine now, for hers. Both working OK.
Also tightened all the screws on the PS Board re heat sinks. (2 finger rule)
To bad you weren't closer. We could have tried it with the spare PS Board I have. Keep the spare since I have 2 55LHXs.
Did you try putting the Main Board Part number on Google?
post #3100 of 3105 Old 06-04-2016, 05:41 AM
Liked: 0
yes there are some main boards for sale. is it likely that I need one? i guess i will buy a power supply board first, which is more likely the problem, i assume.
greg
post #3101 of 3105 Old 06-04-2016, 06:27 PM
p5browne's Avatar
Liked: 2448
greg
All the issues myself and another Member had, were related to the PS Board.
post #3102 of 3105 Old 08-08-2016, 07:16 PM
Scot Kight's Avatar
Quoted: 39 Post(s)
Anyone know of a common cause for snow on hdmi5 after the set has been running for an hour or two? Not coming from the source and tried multiple cables, no luck.
Scot Kight
post #3103 of 3105 Old 08-10-2016, 06:17 PM
p5browne's Avatar
Liked: 2448
I would take the back cover off. 2 finger tighten ALL screws, check all connectors are seated properly and while there, blow out the little vent fan.
(If still using the Media Box, bypass it and go straight into HDMI 5. Note, HDMI 5 will have to be selected for the Source or the set will keep looking for the MB!)
post #3104 of 3105 Old 12-02-2016, 03:36 PM
Liked: 0
Hi.
I've been enjoying this tv for a while now. A few months ago the image begun to look glitchy. I sent it to an official LG provider and they replaced the motherboard. The image looks good now, but the mediabox doesn't turn on when I press 'on' on the remote, only the screen. I have to turn it on manually, and it takes a few minutes to connect to the screen.
Is there anything I can do to pair the mediabox and the screen again?
thanks in advance!
deushl is offline
post #3105 of 3105 Old 12-13-2016, 12:49 PM
p5browne's Avatar
Liked: 2448
Originally Posted by deushl View Post
Hi.
thanks in advance!
Both of my Media Boxes are in the closet. Note: They would NOT interchange!
Both the panel and box must be FW updated with the same FW #.
When the MB was changed, this may have killed the MediaBox TV inter connectivity. Much better PQ with AVR attached to HDMI 5.
A new calibration of both my sets, greatly improved the PQ: New Calman software, new meters, and new improved calibrating procedures.
Too bad about the CMS - very frustrating trying to calibrate when the third item to be calibrated is missing.
Reply LCD Flat Panel Displays
Samsung 55 Inch Led Hdtv Un55b8500 , Lg 55lhx 55 Inch Lcd Hdtv
