Color anomalies in Panasonic TC-L42U12? - AVS Forum
post #1 of 1 Old 11-04-2009, 04:17 PM - Thread Starter
newby64's Avatar
I recently got a Panasonic TC-L42U12. When I connect my DVD player (through the component video connection), the color is way way off. I have to adjust the tint control to +50. Then when I switch back to TV input, I have to re-adjust the tint control.
I called Panasonic, and I was told this shouldn't happen and I should take the TV back to Best Buy. I did, got another, and the same thing is happening.
Is this normal? Is there a fix so that I don't have to spend time re-adjusting the tint every time I switch between DVD and the TV?
thanks
newby64 is offline
Reply LCD Flat Panel Displays
User Tag List
