Burning smell from tv? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-21-2009, 01:05 AM - Thread Starter
vexious's Avatar
Hey all,
I have a 46z4100 and when i smell the vent holes on the top right, it smells what i would consider a cent of burning plastic?
Is this normal?
I've had no issues at all with the tv, just noticed it when moving the tv. No vents are covered or obstructed.
Also my tv is about a year old.
vexious is offline
post #2 of 7 Old 11-21-2009, 01:18 AM
Extreme_Boky's Avatar
Originally Posted by vexious View Post
Hey all,
Is this normal?
that is normal.
Boky
Extreme_Boky is offline
post #3 of 7 Old 11-21-2009, 03:46 AM
MrEastSide's Avatar
Quoted: 25 Post(s)
Liked: 55
It's just the plastic heating up. Smell any hot running electronic device after it's been on a while. None of them smell good. Take a whiff near the vents on a high powered audio receiver after it's been on a good half hour or more. They stink bad. LOL!
As long as you're TV isn't smoking I wouldn't be worried.
Of course, I got it modified with the TK-427, which cheeks it up another, maybe, 3 or 4 quads per channel.
MrEastSide is offline
post #4 of 7 Old 11-21-2009, 07:55 PM - Thread Starter
vexious's Avatar
My room is about 12 x 12. If i leave my tv on for like 5 hours and walk out and back in the room, the room smells of burning plastic. It's not just smelling directly in the vents.
vexious is offline
post #5 of 7 Old 11-21-2009, 11:02 PM
frito's Avatar
my sony 32xbr6 did this when it was brand new for a few weeks, it stopped stinking up the room though but yeah if i smell the vents at the top sure it smells like it, completely normal
If you're a gamer or interested in using an LCD TV as a primary monitor take a look at my thread on Input Lag
frito is offline
post #6 of 7 Old 11-22-2009, 08:22 AM
sitlet's Avatar
then it should still be under warranty. if you are concerned about it, call and get it looked at. you paid good money for the tv and it came with a warranty: USE IT.
sitlet is offline
post #7 of 7 Old 11-22-2009, 10:57 AM
ocrazor's Avatar
Actually, I would try to avoid smelling it-- if it really is a normal smell, it is probably due to outgassing of the plastics and other components. Just like a new car or new shower curtain. But- those fumes can be bad for you so I wouldnt stick my nose right in there until the outgassing has slowed down.
ocrazor is offline
Reply LCD Flat Panel Displays
