Mitsubishi owners - LT46149 OR 46249 OR 46151 OR 46153 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-10-2009, 07:27 AM - Thread Starter
neutronn's Avatar
Mitsubishi owners
this is my quick comparison, reading product spec
LT46149 - has a cable-slot ready + TVguide per the spec
LT46249 - new & expensive.
LT46151 - NetCommand is not available per spec
LT46153 - pretty much same as 149 per spec.
please recommend a model between 149 , 151 & 153.
Since 249 is little expensive not looking at it right now.
thanks in advance.
neutronn is offline
post #2 of 7 Old 12-16-2009, 09:35 PM
inteller's Avatar
Originally Posted by neutronn View Post
Mitsubishi owners
thanks in advance.
get the 46149...it is AWESOME. In fact, AFAIK it is the only 120hz 1080p cablecard TV made.
inteller is offline
post #3 of 7 Old 12-16-2009, 10:29 PM
Servicetech571's Avatar
Unless there is a specific feature/installation requirement that only Mits can fill there are many less expensive sets that are just as good.
Servicetech571 is offline
post #4 of 7 Old 12-22-2009, 04:59 PM
Fiasco's Avatar
Is there anyway to control the output from the audio out jacks with the TV volume? (lt46249)
St Louis, MO - Lutron certified
www.jag-es.com
Fiasco is offline
post #5 of 7 Old 01-19-2010, 01:03 PM
dnslammers's Avatar
I have a LT-46151 got it as a warranty replacement from Mits. I like it.
dnslammers is offline
post #6 of 7 Old 01-19-2010, 01:10 PM
dnslammers's Avatar
here's a review of the Mits model(s)
http://www.soundandvisionmag.com/hdt...-lt-46153.html
post #7 of 7 Old 09-25-2012, 10:19 PM
size14d's Avatar
Quoted: 24 Post(s)
Got a green line on the right side of the screen which has turned red and then disappeared. I got a line issue right out of warranty in 2009 which Mitsubishi fixed. I think once the line decides to stay I will replace it with a 70" 3D tv. Just don't know if I am going DLP or LED LCD. The 5-7 years these TVs last seems to hold true. Even my sister's DLP wheel blew up and it was more cost efficient to get a new TV.
size14d is offline
Reply LCD Flat Panel Displays
