Firmware Hack And Firmware updates LG LH/LF Series - Page 22 - AVS Forum | Home Theater Discussions And Reviews
post #631 of 718 Old 07-15-2011, 06:00 PM
caam14's Avatar
You can put information about supported models.
Originally Posted by Hridix View Post
HI J flash my 42LH7000 firmware v3.67 with 510907(3.75.00)-LH40_LH90_0.1.57.85_flash_V3.75.epk and cant got tv chanal
trying to downgrade to V3.67 but usb stick file in LG_DTV dont start file only open pictures or move dont see firmware as before last 3.75 Someone help? Thnx!
That TV set is not included in supported models for that firmware, in lg official page you can find the list of supported models:
The latest firmware file for upgrade
[Application Model list]
19/22/26LG3100
32/37/42/47LG21xx
32/37/42/47LH40xx
32/37/42/47LH50xx
32/37/42/47LH30xx
19/22/32/37/42/47LH20xx
32/37/42/47LF25xx
42/47LH90xx
As you can see xxLH70xx is not included.
Originally Posted by tomohawk View Post
i have heard that lh7000 use different firmware than other lh series (that for fw 3.67)
but maybe i have wrong.
You are right.
Best regards.
caam14 is offline
post #632 of 718 Old 07-16-2011, 10:17 AM
tomohawk's Avatar
tomohawk is offline
post #633 of 718 Old 07-21-2011, 05:44 AM
manojgupta's Avatar
i have lg 32lh20r-atr(india) lcd tv with 4.04 firmware. is it possible to mount 3.15 or 3.75 version firmware on it?
manojgupta is offline
post #634 of 718 Old 07-22-2011, 04:02 AM
tomohawk's Avatar
see:
post #1
"Be Aware this hack/trick is on your own risk and only for europe LH/LF and some LU models only."
tomohawk is offline
post #635 of 718 Old 07-22-2011, 08:19 AM
ethan82's Avatar
Has anybody tried to downgrade from 3.68 to 3.15? Thanks
ethan82 is offline
post #636 of 718 Old 07-22-2011, 08:40 AM
tomohawk's Avatar
Yes, i`ve tried. Mine lg 32lh2000 was updated at service to 3.68, and then i downgraded to 3.15 for usb-hach, and other things. After that i upgraded from 3.15 to 3.67, 3.69, and finally 3.75 without any problems. (probably the upgrade works directly from 3.15 to 3.75, but take a look at release.cfg for the fw update files, probably you dont want miss them. I mean fw 3.63-3.67 doesnt include release.cfg, but 3.69, and 3.75 does.)
tomohawk is offline
post #637 of 718 Old 07-26-2011, 02:40 PM
bobo10's Avatar
Hello everyone,
I tried new firmware 3.75 on 32LH5000 and 32LD320.
Both TV's work without any problems with this new firmware.
for 32LH5000 update was from 3.67 to 3.75
for 32LD320 update was from 3.69 to 3.75
some things that might help you
under Menu, select OPTION, like manual update from USB ( 7 times button FAV)
- restore firmware to previous version > press 7 times button 9 and TV will do the downgrade
password for Service Menu:
all versions up to 3.65 - 0000
3.66, 3.67, 3.68, 3.69, 3.75 - 0413
bobo10 is offline
post #638 of 718 Old 07-29-2011, 08:06 AM
rioachim's Avatar
I tried to force downgrade 3.75 (7 times button FAV) and my tv died. no worry, RS232 restore worked like a charm. so, if you encounter any bugs in 3.75, revert to previous version (only use 7 times button 9)
rioachim is offline
post #639 of 718 Old 08-14-2011, 06:07 AM
jasper1422's Avatar
Hello everyone
i have a 37lh2000 (european model) and want to upgrade the firmware from 3.12 to 3.15 to enable the USB . I have looked and can't find 3.15 firmware that i can download without page being expired. Does anyone have a working link or is there a different version i can use.
Or can this be done without upgrading the firmware on this model using a IR remote to get into that hidden menu?
Thanks in advance
jasper1422 is offline
post #640 of 718 Old 08-15-2011, 01:32 PM
Winston75's Avatar
I use LG Lh 7020 What is the last firmware version and who can i find this file. I need the link from this file for updating. I use the version 3.66 and in some video files reset the TV. I hope its from firmware.
And some videos worked by me in 3.55 not in 3.66.
Can i divx codec updating whitout firmware update.
Sory about my horrible english .
Thks
Winston75 is offline
post #641 of 718 Old 08-15-2011, 05:14 PM
Dzoni's Avatar
Hi to everyone !
I have 42LH3000 and I have long time ago hacked USB.
I bought 32LD350 and make hack too. Menu interface on this is much better compared with my LH3000. I do not know what FW version have in both.
So, can I make FW upgrade on my LH3000 that I get same menu interface like in LD350 ?
And need I to hack USB again if I make FW upgrade ?
Thank you for all answers in advance !
Dzoni is offline
post #642 of 718 Old 08-16-2011, 01:22 PM
Dzoni's Avatar
Helloooo have anybody here ? !
Dzoni is offline
post #643 of 718 Old 08-29-2011, 02:29 AM
thontepu's Avatar
Hi All,
I am owning LG 42LH50YR (Indian / Asian model ) and followed all the steps ( like copying latest European 3.67 & US 4.30 .epk files to USB/LG_DTV folder & pressing 7 (> 7 times) while highlighting options).
I got TV software update popup but none of the new firmwares are visible to upgrade.
I am having S/W version 4.04 anfd FRC Version 3.04.
Any help in this regard will be highly appreciated.
thontepu is offline
post #644 of 718 Old 09-08-2011, 12:46 PM
Arquiridium's Avatar
Hi i have a LG 32LH30 Full HD. my Question is if possible to reproduce MKV or AVI's HD (1920x1080)
If possible to upgrade The codecs for this model?
Arquiridium is offline
post #645 of 718 Old 09-30-2011, 02:09 AM
endera's Avatar
Still do not have a solution for DTS?
endera is offline
post #646 of 718 Old 10-13-2011, 01:21 AM
sajid.eqbal's Avatar
Hi Friends,
I am new to this thread. Please help me with the below queries:
1. I have LG - 26LH20R LCD TV running on Ver 4.04 (Asia). I have enabled USB with OK + Ok method. I donot have the option for DIVX and it plays only .avi files using USB. Can anybody tell me how can i play .MKV, .MP4 or other formats?
2. Is there any firmware update that can be installed? Can i try to downgrade it to ver 3.15 to enable HD. Because there is onlt TOOL OPTIONS 1 and TOOL OPTIONS 2 in the menu. ( NO TOOL OPTION 3).
sajid.eqbal is offline
post #647 of 718 Old 10-26-2011, 04:57 PM
orexha's Avatar
i have LG 37LH3000-ZA. can i update my software? i dont know where my tv is from. what does this code mean -ZA? my usb is only for service, can i watch movies???? pls help?
orexha is offline
post #648 of 718 Old 10-27-2011, 08:08 PM
orexha's Avatar
it worked fine for me. i have LG 37LH3000. i downgraded from 3.75 to 3.15 and i did the usb trick. but now im afraid to update again to 3.75. is it important to do this update, because everything works fine for me with 3.15 firmware. what do you think???
orexha is offline
post #649 of 718 Old 11-03-2011, 06:12 PM
H34D's Avatar
Hi, I have 37LG5000 with USB marked as "service only" and I want to unlock/activate/hack it to be able to play movies from USB devices (external HDD). I ve been searching forums for hours, I have red all I can and Im still not sure about few things.
1) Some forums described unlocking USB in the LG series the same way as in LH series (downgrade firmware to 3.15 etc), but the firmware readme files dont mention supporting LG series. Also some forums mentioned that LG series uses *.bin firmware files, not *.epk, so its required to rename the file to "update.bin", which smells fishy.
2) Some forums says that unlocking USB on LG series is not possible at all.
3) Some forums says that unlocking USB on LG series is possible only via IR hack.
4) Some forums describes unlocking USB using COM connection from PC - (damn, cant paste url, so I try it anyway without 3x w...) lg-hack.info/cgi-bin/sn_prntopic.cgi?cid=2674&fid=2677&tid=2714
5) One last interesting metod which Im not sure about - openlgtv.org.ru/wiki/index.php/LH/LG_series_USB_video_player_activation - basicly it says just to upgrade firmware to 3.75 + use LGMOD to add some setings for USB unlock.
Can anyone help me what should I do? The IR metod seems the most safe, but my phone is too old for this, I think. So please help. Thank you.
H34D is offline
post #650 of 718 Old 11-24-2011, 12:41 PM
42LH7000's Avatar
Originally Posted by Devil-Strike View Post
This Thread is for Enable the usb port to watch mkv and xvid HD.
Press menu on remote and go to options but don't press ok, now press 7 times on the fav button now a screen apears with Software update (Expert) download version v03.15.00(not needed if you already have v3.15) and put it on a usb stick now the TV will see the file press ok and it wil downgrade or upgrade to v03.15.00.
Now The Service menu works again.
To acces Servicemenu press ok + ok for 5sec and a pw screen apears pw=0000(this you need to enable usb and xvid-mkv playback), go to option number 3 and set jpeg,mp3 to 1 and divx/xvid to HD.
For in-start (servicemenu)use the menu + menu buttons also 5sec and a pw screen apears pw=0000, Real servicemenu dont use this.
So here is now mkv and xvid enabled on my 37LF2500
Hello Everyone,
My TV is 42LH7000 running on V3.12
On most of the mkv files I receive an error message "sound not compatible".
Also some avi files seem to be corrupt and cannot be played at all although they are fine on computer.
Will the above patch fix these problems? (It seems it only sets divx/xvid to HD)
What is the ideal FW version for this TV?
Thank you for your help in advance.
Danielle
42LH7000 is offline
post #651 of 718 Old 11-24-2011, 12:44 PM
42LH7000's Avatar
I think you should stay where you are happy.
42LH7000 is offline
post #652 of 718 Old 12-06-2011, 06:51 AM
Mayel030's Avatar
Can I watch DivX movies or any other format on my LG 37LG4000? help please!
Mayel030 is offline
post #653 of 718 Old 12-29-2011, 10:14 AM
sincze's Avatar
Just downloaded the latest firmware from the LG website in NL.
Created the LG_DTV folder on USB stick.
Put firmware file in directory.
Put USB stick in TV.
It will immediately ask you to update.
After updating the firmware the TV will restart.
Put my .JPG USB stick back in the TV and everything is still working as it did before on 3.55.
Thanks LG
sincze is offline
post #654 of 718 Old 12-31-2011, 08:33 AM
bobo10's Avatar
hello everyone,
I made an update with version 3.75 and I so that my TV (32LD320) can play now Full HD movies (1920x1080) since the TV come usually with HD Ready (1366x768).
If anyone of you have the same TV and updated to version 3.75 then try to play a Full HD movie and see if it works.
Cheers
bobo10 is offline
post #655 of 718 Old 01-04-2012, 05:31 PM
gimmeluck's Avatar
hello, im in russia now.
i have LG 22" LH2000
fw : 3.40 made in russia 2009
i didint touch fw of tv, so far.
to open MKv and divx play by USB,
what i must do?
do i need a hack fw? or original LG update is letting us already this? thanks
gimmeluck is offline
post #656 of 718 Old 01-05-2012, 09:29 AM
bobo10's Avatar
hi, try to fallow the steps from the bellow link and you don't need to update or change firmware.
img51.imageshack.us/img51/8633/lolavforums(dot)png
If you want alos to update the firmware just create a folder named LG_DTV in a root of a usb stick and mount it on TV.
If the firmware is newer than yours then a window will apper for update.
bobo10 is offline
post #657 of 718 Old 01-05-2012, 11:14 AM
gimmeluck's Avatar
hi but whats that explanation in that link? its mixing more because they use an smart phone there! lol
im3.40 do i need to install 3.15 ?
post #658 of 718 Old 01-05-2012, 05:54 PM
gimmeluck's Avatar
ok i did and openned usb menu and films,
but in 1 mkv film which is 720p, film stops wotrking after some minutes and going back to usb menu,
why it can be?
do i need to upgrade my 3.15 fw?
post #659 of 718 Old 01-06-2012, 11:15 AM
tomohawk's Avatar
hi. for usb trick u need the following things:
- upgrade firmware to 3.55, or 3.65 or 3.75
- downgrade to 3.15
- enter ez-adjust menu
- do the modifications what u need
- exit ez-adjust with return button (not ok button)
- upgrade to the latest fw
OK. So Ez-Adjust (for 32lh2000):
0. Tool Option1:
- header: 16472
- Inch: 32
- Tool: LH20
- Maker: SHARP
- Module Rev.: 0
1. Tool Option2:
- header: 1574
- HDMI Count: 2
- HDMI Switch IC: NONE
- Component Count: 1
- S-Video: 0
- RCA AV Count: 1
- Scart Count: Full+Half
2. Tool Option3:
- header: 53156
- EMF(JPEG,MP3): 1
- Divx: HD
- Bluetooth : 0 (useless, you dont have bt module inside)
- Digital Eye : 1 (for more picture profiles)
- Headphone : 1
- OPC : 1 (some energy saving option)
- EPA: 1
- e-Manual: 1
- Audio Amp: NTP3100
- LED Type: Moving
- New E-Con: 0
3. Tool Option4:
- header: 11872
- Clear QAM: 0
- Local Dimming: 0
- THX: 1 (for extra profiles. For editing later you highlight the thx profile in menu, and press: 8741, L mark on your remote)
- Digital Demod: DRXK
- Analog Demod: TDFWDRXK
- THX Media Director: 1
- Picture Wizard: 1
I dont modified anything else. These settings are safe.
tomohawk is offline
post #660 of 718 Old 01-06-2012, 12:28 PM
NaneVR's Avatar
I need US model firmware for my tv, does anybody have it?
NaneVR is offline
Reply LCD Flat Panel Displays
Lg 47lh90 , Lg 55lh40 55 Inch Lcd Hdtv , Lg 42 Lh40 42 Inch Lcd Hdtv , Lg 47lh40 47 Inch 1080p 120 Hz Lcd Hdtv Gloss Black , Lg 42lh50 42 Inch 1080p 120 Hz Broadband Lcd Hdtv Gloss Black , Lg 32lh30 32 Inch 1080p Lcd Hdtv Gloss Black , Lg 32lh20 32 Inch 720p Lcd Hdtv Gloss Black
