Firmware Hack And Firmware updates LG LH/LF Series - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 718 Old 03-09-2010, 12:48 PM
Timmeh4's Avatar
I bought a LG 32LH3300 but i cant get in to the service menu or start a update.
When i lookup my firmware version it says 1.00.00 so i want to update it to 3.15 for the usb hack but i cant get it to work. For the service menu i tried holding both the menu and the ok button on tv and remote and with updating i tried: in the menu then to options and press fav or 7 7 times but it all does not work.
please help me and thank you in advance.
Timmeh4 is offline
post #182 of 718 Old 03-11-2010, 12:30 AM
Georgie3's Avatar
Originally Posted by doctorwest View Post
Hi Sangos,
I entered the Tool Option 2 menu (using my PDA, NoviiRemote Deluxe and the Codebases listed in the forum) and there was a Bluetooth entry set to 0. I just changed it to 1 and that was it. I turned off the TV and next time I turned it on, the Bluetooth submenu was active. It says I can use it to connect wireless headphones, so I'll look for a set to try it.
Anyway, I'm still trying to find the Tool Option 3 or any other method to activate USB MKV playback. I hope to get an answer or suggestion before the trial time of the NoviiRemote Deluxe is over. Any ideas?
Raul
People, be careful in those service menus please! I tried to turn Bluetooth on for fun and it put my TV in a 10-second reset loop. Just barely could get back in and turn Bluetooth off in time. Best case your TV doesn't have the right hardware and the option does nothing.
As for tool option 3, if your TV doesn't have it either the DivX option is in another place or you're out of luck. I assume USB photos and music work on your set, right? (i.e. your USB option in the main menu has only 2 media choices, not 3)
Georgie3 is offline
post #183 of 718 Old 03-11-2010, 12:45 AM
Georgie3's Avatar
Originally Posted by Perplex View Post
The only way to do this hack is to slap on a old firmware right? with the LH40 models, doesn't this bring back the Lip Sync problems?
Are there any hacks for the 4.50.00 firmwares?
Do not try to load European firmware (3.15, or any 3.x) on your LH40 or other North American model TV. You will kill it.
You can enter the service menus by sending the right IR remote code. See this guide http://lgusb.wikispaces.com/IR+Hack
For a more complete list of remotes that work see http://www.avsforum.com/avs-vb/showt...4#post18034174
G
Georgie3 is offline
post #184 of 718 Old 03-11-2010, 05:50 AM
Perplex's Avatar
G
Thanks Georgie for your reply! Question: So I can go into the service menu's and enable the hack without having to downgrade my firmware? Thanks!
Perplex is offline
post #185 of 718 Old 03-11-2010, 08:28 AM
sangos's Avatar
You got it...once you are in the service menu you are good with the TVs regular remote
sangos is offline
post #186 of 718 Old 03-11-2010, 08:45 AM
mustafacan46's Avatar
i have 32lg5000 lcd tv.
can i use usb port for service only ? I Want a play movies on my usb ?
please help me
mustafacan46 is offline
post #187 of 718 Old 03-12-2010, 07:11 AM
gigipresh's Avatar
My remote lags (sort of).
Product 37LH4010 firmware 3.55 more than 200TV channels.
Sometimes I have to press the buttons on remote more times to have result.
Also, when I'm accessing the USB for movies, the menu (play for example) loads very late.
Tried to change the batteries, same crap happening.
gigipresh is offline
post #188 of 718 Old 03-12-2010, 08:25 AM
jimmiee's Avatar
hey i just bought a lg 22lh2000, and did step by step via tutorial everything seems fine, except subtitles dont work. if i press the red button i can't place on the subtitle language. is there any other options to do this? i got 3.55fw now.
please help
jimmiee is offline
post #189 of 718 Old 03-12-2010, 09:13 AM
gigipresh's Avatar
The file names MUST BE the same except the extension.
post #190 of 718 Old 03-13-2010, 05:46 PM
jecgino's Avatar
I just bougth in Colombia, southamerica, a LH20R TV; it was manufactured in Korea. I have read several forums and I have downloaded many FW 3.15 to downgrade my 3.24 FW version. I put it into an USB LG_DTV folder. To get access to the tv update software, I press menu, then over option press seven times the number 7.
The problem is that the tv doesn´t recognize the 3.15 or any other FM in my usb to update. it only appears the current software App (R) 3.24 and boot (R) 1.01.
The usb's format is fat32.
jecgino is offline
post #191 of 718 Old 03-14-2010, 12:05 AM
gigipresh's Avatar
The hack works only on EU models.
Be careful and read the tutorial form A to Z.
post #192 of 718 Old 03-14-2010, 10:27 AM
giuby's Avatar
Is there some kind of change log for different firmware?
giuby is offline
post #193 of 718 Old 03-14-2010, 10:41 AM
pantzini's Avatar
My question exactly. LG seem to have removed the firmware downloads from their website.
pantzini is offline
post #194 of 718 Old 03-14-2010, 07:14 PM
Scampa's Avatar
Bought a male to female USB cable to make it easier to plug my mem stick in as the USB port is more or less centre of the back, however this doesn't work has anyone got a solution?
Scampa is offline
post #195 of 718 Old 03-15-2010, 03:55 AM
brodev's Avatar
I have a 42lh2000 with v3.55. I downgraded to v3.15 applied the hack and upgraded to v3.55 again apparently successfully. When I try to show .avi movies I get the message "this file is invalid". Any suggestions?
brodev is offline
post #196 of 718 Old 03-15-2010, 04:29 AM
gigipresh's Avatar
Scampa: I also have USB extension, ant my stick without any problems.
brodev: "this file is invalid" - because the ratio of the video is not supported.
post #197 of 718 Old 03-15-2010, 04:45 AM
brodev's Avatar
Thanks Gigipresh for your reply. What do you mean by ratio? As I am an OAP I am not very with it. The hack says .avi files are supported.
brodev is offline
post #198 of 718 Old 03-15-2010, 04:52 AM
gigipresh's Avatar
Qoute from the user guide:
Movie files are supported as follows
Resolution : under 1920x1080 WxH pixels
Frame rate : under 30 frames/sec(1920x1080), under 60 frames/sec(under 1280x720)
G Video Codec : MPEG 1, MPEG 2, MPEG 4, H.264/AVC, DivX 3.11, DivX 4.12, DivX 5.x, DivX 6,
Xvid 1.00, Xvid 1.01, Xvid 1.02, Xvid 1.03, Xvid 1.10-beta1, Xvid 1.10-beta2
post #199 of 718 Old 03-15-2010, 09:10 AM
brodev's Avatar
Only photo(JPEG), music (MP3) and movie(DAT, MPG, MPEG, VOB,
AVI, DIVX, MP4, MKV, TS, TRP, TP) (Only 32/37/42/47LH49**,
32/37/42/47/55LH50**, 32/37/42/47LH70**, 42/47LH90**,
50/60PS70**, 50/60PS80**, 42/50PQ35**, 42PQ65**,
50PS65**) are supported.
The above taken from the user manual says that avi is supported. Is there something I am missing? I am aware that I can sometimes not see the wood for the trees.
brodev is offline
post #200 of 718 Old 03-15-2010, 09:14 AM
gigipresh's Avatar
Yes sir, but:
- not everything that has .avi extension is avi encoding
- the movie has to have an accepted ratio (HxW)
post #201 of 718 Old 03-15-2010, 09:40 AM
brodev's Avatar
Thanks again gigipresh. I think I understand. I don't know what the WxH is. they are just a couple of short videos taken with my wife's coolpix camera.
brodev is offline
post #202 of 718 Old 03-15-2010, 09:43 AM
gigipresh's Avatar
width height
post #203 of 718 Old 03-19-2010, 06:19 AM - Thread Starter
Devil-Strike's Avatar
New firmware on new builded lf/lh/lu series, version 3,63 if some 1 can find this please contact me.
Devil-Strike is offline
post #204 of 718 Old 03-21-2010, 08:36 AM - Thread Starter
Found new firmware 3,63 only for -LH2000,LH3000,LH4000,LH5000,LF2500,LH9000 All inches - Not for LH7000 and SL8X00!
Download: V3.63 http://members.chello.nl/devilstrike/LG_DTV_v3.63.zip Mirror: http://devil-strike.host22.com/LG_DTV_v3.63.zip
Changelog:
Beter Performance DVB-T/DVB-C Tunning and channel switching
Beter remote support faster response.
Audio fix for Xvid.
post #205 of 718 Old 03-21-2010, 02:34 PM
alconada's Avatar
hola me he comprado este modelo con el fiware 3.40.0 mi pregunta se le puede hacer algo par ver pelis con pen, y como ayudarme si podeis gracias
alconada is offline
post #206 of 718 Old 03-21-2010, 05:33 PM
xvidmaster's Avatar
Originally Posted by vws View Post
I recently purchased a 42LH40 with firmware ver. 4.30.1. I was able to access the service menu with my Philips PM335 universal remote and successfully enabled Divx playback at first try.
Whats key you push in the Philips PM335 universal remote to enter secret menu?
Regards
xvidmaster is offline
post #207 of 718 Old 03-21-2010, 09:22 PM
vws
vws's Avatar
Regards
I simply program my remote with the first LG TV code "0002" from the manual. By pressing the Guide button and entering the 0000 password, the "EZ Adjust" menu pops up.
Incidentally, I've exhausted all LG codes & buttons on this remote and I still can't get the other two service menus ("In-Start" & "In-Stop").
vws is offline
post #208 of 718 Old 03-22-2010, 01:40 AM - Thread Starter
Please English only.
post #209 of 718 Old 03-22-2010, 03:35 AM
VANTWP's Avatar
Changelog:
Audio fix for Xvid.
Big thanks Devil-Strike
I add this fw to my mirror
btw. anybody hear about AUO panels in new LG LH series??
FW for LG LH-3/4/5000 EU series
v3.75
v3.67
v3.15
VANTWP is offline
post #210 of 718 Old 03-22-2010, 11:28 AM
rioachim's Avatar
what is auo? and do these series have shuffle for mp3 / pictures ?
rioachim is offline
Reply LCD Flat Panel Displays
Lg 47lh90 , Lg 55lh40 55 Inch Lcd Hdtv , Lg 42 Lh40 42 Inch Lcd Hdtv , Lg 47lh40 47 Inch 1080p 120 Hz Lcd Hdtv Gloss Black , Lg 42lh50 42 Inch 1080p 120 Hz Broadband Lcd Hdtv Gloss Black , Lg 32lh30 32 Inch 1080p Lcd Hdtv Gloss Black , Lg 32lh20 32 Inch 720p Lcd Hdtv Gloss Black
