Curtis LCDVD326A 32" blinks 7 times. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-09-2010, 08:22 PM - Thread Starter
fommy100's Avatar
the tv blinks 7 times... when you turn the tv on after it gets to 5 blinks the back lights turn on but no picture. then it blinks 2 more times, for a total of 7 blinks.
I know its a power board issue but I am having no look in finding a service manual to trouble shoot this TV.
Ive already replaced the low power side caps and mofets. still blinking 7 times.
Power board # FSP205-4E03
fommy100 is offline
post #2 of 2 Old 12-22-2011, 09:55 AM
unspun01's Avatar
Sorry to post in an old thread, but I want to share my experience with repair of this power supply.
Unless they were shorted, you did not need to replace the mosfets in the secondary...
Since you have already replaced the bad capacitors in the 12V and 24V secondary, check if you have 5V standby voltage.
If you have 5V standby, please try replacing capacitor EC4 (near the lower transformer in the middle of the board). It should be a 33uF/50V capacitor, but mine tested out-of-spec at only 15uF. Replacing with a new 33uF/50V should restore functionality to this power supply and allow you to turn on the TV.
unspun01 is offline
Reply LCD Flat Panel Displays
