opinions on a sony KDL52VL150 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-29-2010, 01:05 PM - Thread Starter
billycole's Avatar
I found this set at sam's club, its 120hz and about 3-400 cheaper then the normal v series TVs. Is this a stripped down tv for sams or is it a good tv. I have been looking for a tv between 50-60"s and under $1,500. Currently have a kdl-40w3000 and we are looking to upgrade.
billycole is offline
post #2 of 8 Old 01-29-2010, 01:23 PM
BoilerJim's Avatar
Quoted: 55 Post(s)
Liked: 118
There is at least one existing thread on this TV if not more.
BoilerJim is offline
post #3 of 8 Old 01-29-2010, 02:51 PM
engycanuck's Avatar
It should be equvalent to a V5100 series or possibly slightly better. The guts look to be the seem, but they quote a higher dynamic contrast ratio (FWIW), but they use a nicer cabinet from the Z5100 instead of the V cabinet.
engycanuck is offline
post #4 of 8 Old 01-29-2010, 03:06 PM
BoilerJim's Avatar
Quoted: 55 Post(s)
Liked: 118
cabinet = bezel
post #5 of 8 Old 01-29-2010, 04:32 PM - Thread Starter
billycole's Avatar
I did use the search function and there is not a lot out here in regards to this tv. The vl150 is going for 1200 and the v5000 is going for 1500 in the 52 inch range.
post #6 of 8 Old 01-29-2010, 07:39 PM
EricU's Avatar
I was wondering about this model also as I found it on Costco's website, I was looking at a KDL-52V5100 but after reading the extensive thread I am now not so sure about it's reliability.
EricU is offline
post #7 of 8 Old 01-29-2010, 07:44 PM
killa2009's Avatar
Hello, i actually have this set which its two weeks old and i am already experiencing problems with this lcd. Besides the red flashing and popping sound when changing channel the picture is beautiful, now i just experience this new issue where there's a three inch transparent bar going down the middle of the tv. i have pics in the 51v series section.
killa2009 is offline
post #8 of 8 Old 01-29-2010, 08:23 PM
nosepass2's Avatar
The early indication of a bad set is your experience of getting a popping noise when changing channels.
It's most definitely a TCON board problem (which I believe is a main section for the picture production)
nosepass2 is offline
Reply LCD Flat Panel Displays
