Which Local Dimming LED LCD to get? (VF551XVT vs 55SV670U) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 25 Old 02-01-2010, 09:41 PM - Thread Starter
aznphatb0i's Avatar
Hello-
I'm in the market for a 55"+ local dimming LED LCD
I've pretty much narrowed my choices down to:
UN55B8500
55SV670U
VF551XVT
Though I include the UN55B8500 (it's very sexy ) it's actually pretty much out of the picture due to cost unless some crazy deal comes out on it. So actually don't take it into account.
I can get the VF551XVT at the best price, with the 55SV670U being a little more.
Are there any advantages of the 55SV670U? From my reading it seems like the VIZIO set is actually the better choice - is this true?
I came across the claim in some threads that the VIZIO set uses the exact same panel as the set of another manufacturer (Samsung? LG?) What panel does the VIZIO set use?
I've also ran across the 55LH90 - but excluded it because it didn't seem to have any benefit over the VF551XVT / 55SV670U and is considerably more expensive - any reason to change my mind about this?
I would like to make the purchase in the next few weeks (have 'heard' that deals on displays happen right after the super bowl - but regardless of this i still wish to make the purchase soon)
TL;DR:
I want a 55" LED LCD! VF551XVT and 55SV670U are in my price range (VF551XVT cheaper / longer warranty) - which one! (or suggest another set!)
aznphatb0i is offline
post #2 of 25 Old 02-02-2010, 07:50 AM
baldbear's Avatar
I just bought the VF551XVT, it has an AMAZING picture. (hate the bottom speaker bezel though). Just make sure to turn the Auto-Dimming on (I turned it off not realizing that was the local LED lighting option). I got it at Sam's Club for 1599.
baldbear is offline
post #3 of 25 Old 02-02-2010, 08:31 AM
gwsallen's Avatar
comparing between VIZIO VF551XVT and Toshiba 55SV670U, buy the VIZIO VF551XVT http://www.amazon.com/VIZIO-VF551XVT-55-Inch-XVT-TruLED/dp/B002JPEWOO/ref=sr_1_1?ie=UTF8&s=electronics&qid=1265124461&sr=1-1
i've seen 55SV670U, i am not impress at all.
gwsallen is offline
post #4 of 25 Old 02-02-2010, 09:07 AM
BFJ 96's Avatar
Quoted: 59 Post(s)
Liked: 36
670U- Ultra Clear Panel. (Somewhat reflective when light hit's it) IMO doesn't take away from the picture
551- Matte Screen. Very good with bright rooms as it's non-reflective.
670U- Offers 96 LED Zones
551- Offers 80 LED Zones
670U- IMO Offers a better asthetic. More pleasing to the eye. Looks really nice
551- Asthethic looks OK. Sound Bar detracts from it's design.
670U- Offers a nice amount of User Adjustments for Calibration. Including the adjust the Primary & Secondary Colors via the User Menu
551- Also offers User Adjustments, but not as extensive as the 670U.
Lastly if you can see both of them, do so.
BFJ 96 is online now
post #5 of 25 Old 02-02-2010, 09:32 AM
topr's Avatar
Since the firmware upgrade Toshiba owners seem to be super happy with their displays. There may be a few things that each does better than the other but the biggest difference are the screens....matte vs gloss. If I were to choose between the two, the amount of ambient light or windows in the room would weigh heavily in my decision.
topr is offline
post #6 of 25 Old 02-02-2010, 10:06 AM
Mark Danger's Avatar
I owned the Toshiba and the local dimming was fantastic, but I exchanged it for an edge lit Samsung 8000.
The "240" Hz on the Toshiba cannot compare to the real 240 Hz of the Samsung. I wanted the 3D effect and I could not be happier with my decision.
I hardly notice the loss of local dimming.
Mark Danger is offline
post #7 of 25 Old 02-02-2010, 03:16 PM
fast200's Avatar
FWIW, I own the 46" 670U and I am very pleased with the set. The local dimming and overall picture are excellent. The reflective screen could be an issue for you if you have lighting in front of the set.
fast200 is offline
post #8 of 25 Old 02-02-2010, 07:13 PM - Thread Starter
aznphatb0i's Avatar
I actually had ordered a UN55B8000 at a crazy price a while back but it was canceled due to a 'price mistake.'
I was considering that set but decided against it due to the lack of local dimming and that it commands a hefty price premium over the VIZIO / Toshiba.
But I do love the UN55B8000's looks - so would you say in general the picture is significantly superior? I was under the impression that local dimming gave a noticeable gain in contrast over edge-lit.
At the moment [barring any super deals on the Samsung UN55B8X00] i'm really leaning towards the VIZIO - seems as if Toshiba has better 'on paper' specifications but i don't know if that's worth the price premium - especially as it looks as if the VIZIO operates and is calibrated better 'out of the box' - The CNET 'geekbox' test shows the VIZIO handily out performing the Toshiba (I'm very unlikely to spend hours calibrating myself unless there is a guide / utility for me to run so i can simply input settings)
My room is an open one and will be lit most of the time, though the blinds are decent enough to prevent sunlight directly impacting the set.
post #9 of 25 Old 02-03-2010, 09:17 PM - Thread Starter
aznphatb0i's Avatar
post #10 of 25 Old 02-05-2010, 08:34 AM - Thread Starter
aznphatb0i's Avatar
post #11 of 25 Old 02-06-2010, 07:22 PM - Thread Starter
aznphatb0i's Avatar
post #12 of 25 Old 02-06-2010, 08:07 PM
hhaller's Avatar
Quoted: 72 Post(s)
Liked: 51
The LG LH90's are basically the same price now.
hhaller is offline
post #13 of 25 Old 02-07-2010, 03:30 PM - Thread Starter
aznphatb0i's Avatar
The LH90's are a little more than the Toshiba but still a good chunk above the Vizio.
Is there any reason to get the LH90? How many LED zones does the LH90 feature / any comments on the panel? I've read that it has the same number of zones as the VIZIO and that the VIZIO is almost a 'clone' of it.
The price jump from LH90 to UN55B8000 is again doable.. but is the UN55B8000 preferable from PQ standpoint in spite of the lack of local dimming?
post #14 of 25 Old 02-09-2010, 01:43 AM - Thread Starter
aznphatb0i's Avatar
bit on the Vizio from Costco. Purchased it with AMEX too so 3 year warranty.
still in the box at the moment.. Costco has 90 day return policy so holding out for a bit to see if any deals come around.. but i might get weak and open it
post #15 of 25 Old 02-22-2010, 05:30 PM - Thread Starter
aznphatb0i's Avatar
OPENED!
Any guides for calibration / settings?
I still do have a 90 day return period so if any of you think i should return and purchase something else - let me know!
post #16 of 25 Old 02-26-2010, 04:18 PM - Thread Starter
aznphatb0i's Avatar
OKAY!
So it looks like the price on the 55SV670U has dropped by a significant amount at a store - so I can actually get it for CHEAPER than the VIZIO now - and I can return the VIZIO to Costco still
So: should I?
I'm really worried about the bad 'geekbox' scores at CNET - though hometheatremag gives a glowing review of the 46" version of the Toshiba.
Stick with the VIZIO or go for the Toshiba?
post #17 of 25 Old 03-12-2010, 07:56 PM - Thread Starter
aznphatb0i's Avatar
bump
post #18 of 25 Old 03-12-2010, 08:40 PM
cawgijoe's Avatar
Stick with the Vizio. It's a very nice set and you do get that extra warranty.
cawgijoe is offline
post #19 of 25 Old 03-12-2010, 08:41 PM
cris619's Avatar
another vote for sticking with the Vizio.it's really an amazing LED TV.
cris619 is offline
post #20 of 25 Old 03-14-2010, 08:30 PM - Thread Starter
aznphatb0i's Avatar
Any specific reasons guys?
This is the glowing review of the 46" version of the 670U i was referring to: http://www.hometheatermag.com/flat-p...670u_lcd_hdtv/
The price difference between the VIZIO and the Toshiba will now allow me to get a 'free PS3' / have cash to go towards an HTPC with the money saved
The Toshiba seems to have better technical specifications on paper than the VIZIO - but the CNET review geekbox scores are bad - but the HTM review is excellent
I think the gloss on the Toshiba will make the picture 'pop'? I'm able to control lighting in my room if necessary.
The VIZIO does have that additional extra year warranty - but I don't value that as high as getting a better set.
Comments?
post #21 of 25 Old 03-15-2010, 01:19 PM
MPF
MPF's Avatar
The Vizio is a great set, and unless you find something out of spec with regards to its performance, I would keep it. Try not to game costco's return policy because you cant do all your research up front, or find that you can save money elsewhere on the set you really wanted after 90 days. I'm not saying that its not technically outside the bounds of their policy to do, but that its killing the goose that lays golden eggs kinda thing. We used to have Costco have a great policy on their laptops and other electronics, and because of abuse we now dont have the same ability any longer - and thats a shame.
If you have a bad set thats one thing - thats why costco has their policy, but it sounds like you were never that sure of your decision in the first place. Some vendors dont deal with costco becuase of their pro consumer policies - the more they are abused the fewer of them we will be afforded. If everyone did that costco would have the same policy as all the other retailers, and that would be a real shame to loose as well.
MPF is offline
post #22 of 25 Old 03-15-2010, 01:52 PM
M5Rahul's Avatar
Very well said!!
To the OP, keep the Vizio!! I know it's hard to not give into the temptation, but you have a good set! There will always be better sets and pricing will keep coming down further, even if you exchanged your TV.. It's just the way technology is!! I own an edge-lit samsung UN55B6000 and it has exceptional PQ!!
I believe I got one of those nice sets that has very little flashing and great off angle viewing.. Now, even though I'm well within my return period and can probably get the B8000, or LH90 for not a huge difference in price, I'm gonna keep the B6000 because I'm perfectly happy with it!!
M5Rahul is offline
post #23 of 25 Old 03-15-2010, 02:39 PM
MPF
MPF's Avatar
What helps me is once I purchase something, I dont read reviews any more, I dont even visit these forums (at least the ones regarding the product i purchased) unless I need help or have a problem. All our conversations here are great, but man they can play head games with you - cause you to loose perspective. Of course the pruchase made 3 months ago is the incorrect when look at through the lens of today. Once you open the box, just try and make the best of your decision, and be happy.
MPF is offline
post #24 of 25 Old 03-15-2010, 03:29 PM
dpalbsp's Avatar
There is one more thread that was going on about LED choices, it talks about Vizio and Toshiba, check it out -
http://www.avsforum.com/avs-vb/showthread.php?t=1227532
dpalbsp is offline
post #25 of 25 Old 04-18-2010, 10:34 PM - Thread Starter
aznphatb0i's Avatar
Hello again guys :]
IF YOU'RE READING THIS - I need advice before the first week of May (return policy) So thank you in advance
Still have my VIZIO.. and was considering holding onto it (because it is fairly nice, and I got lazy - i'm not as altruistic as you guys about not using my costco powers )
BUT!
The TV seems to have a problem, on HD channels the audio will work intermittently - meaning there will be no audio, but if the TV is turned on/off audio may/may not work.
I've down troubleshooting with other cables etc. etc. and isolated the problem to the TV itself..
So now I have to either get a replacement of the same model... or a different one!
As of now: I can get the 55SV670U at the best price - but under $100 difference from the 55LH90 - so the price difference is not relevant between those two sets at this point - sooo i'm leaning towards the 55LH90
Any new 55"+ LED LCD sets I should be looking at??
I've also opened up my parameters to non-LED LCD's if the size is 60"-65"+ and in the same price range (a good quality set of course) - heh once the TV was in my room I realized my wall was pretty big - at the moment i've come across the LC-60E77UN and LC-C6077UN within my price range [similar prices between both models] (I think they're nearly identical sets spec wise...?)
Any advice would be appreciated!
Reply LCD Flat Panel Displays
